During radio installation (a true shoe-horn job...!), I managed to snap a cable from the RX circuit board...
....and this is SMALL...!...too small for my old eyes, i.e. I've got to get some help with the soldering....This will delay the fuselage build, so in the meantime I'm going on with the wing.... Vintage plans are.............vintage plans... ....i.e. not always crystal clear, thus leaving space for imagination & common sense...![]() The wing rib drawing on the plan is somewhat rough, but in a book, written before "Gladan" was kitted, the designer says "SI-63008" airfoil.... When looking at the plan, yes I can see the basic shape of said section, but it is slightly modified, possibly in order to simplify building, and/or enable "standard" stringer dimensions to be used.....and, as mentioned, the rib drawing leaves some space for "free interpretation".... Guided by the "real" SI-63008, AND the plan, I've made a rib template that (IMHO), doesn't look too bad, so far.... I intend to use the original L/E, spar and T/E dimensions, i.e. SOME modifications have been made...hopfully in a reasonably stylish/functional way.... To be continued.....
United States, MA, Waltham
Joined Dec 2001
Just read this thread for the first time. What a fun project! I've been thinking about an A1 glider myself.
It occurs to me that, if launching free flight, on days when the air was still, you could put rubber in the line to make it pull in faster, and use a stooge set up to let go when you got a certain amount of tension. The latter might be good for me with large rc until my shoulder gets better! Using that kind of stooge, you'd be able to steer by moving the towline. And if there was enough rubber, you wouldn' t have to run at all, so your chances of falling in a woodchuck* hole and spraining your ankle would be less. My experience with RC gliders that use rudder for turn is that you almost can't have too much rudder throw. On windy days you might find it handy to also have a wing with less camber, so you can get some speed up to come back upwind. An airfoil like this would be very slow, which is just fine for a free flight model. *I don't know if there are woodchucks in Sweden, but I bet you have something that acts like them: http://3.bp.blogspot.com/_9AkJhfq-kY...d-hog-hole.jpg |
Latest blog entry: pics from Winthrop, MA indoor flying...
As expected, the stab was pretty much a "routine" job, so far....I couldn't resist making "bent" tips, in same manner as the wing tips, although these are balsa, for weight saving reasons ....
The twin elevator strips are seen on the photo....reason for the fairly wide "stiff" centre T/E, is an attempt to protect the elevators, if/when the stab (which is rubber retained) is knocked about.... Even the elevator linkage will be "knock-offable"....more on this later on....
Thanks DeeBee1....
....In this particular case I brought the water to boil, switched off the stove, put the plywood sheet in the water, and just let it soak in the slowly cooling water for about 30 minutes....Surprisingly, the plywood doesn't fall apart...it just softens.... Initially I learned this many years ago, when building the DB "Mini-Eros", where I shaped the top rear "cabin" in one piece of 1/64" ply, using this method... Here's a scanned old B/W photo of that build...
| Thread Tools | |
| Discussion Got SCX-10 couple weeks ago and need som advices... | MAFIA | Rock Crawlers | 3 | Aug 19, 2011 06:32 PM |
| Discussion All bets are on. All advices are welcome | biesas | Sailplane Talk | 19 | May 27, 2011 07:30 AM |
| Discussion where to get a bungee/towline? | helifryer | Sailplane Talk | 9 | Sep 08, 2009 07:30 AM |
| Non-Plane R/C Vendors are welcome too! | Don Sims | Vendor Talk | 0 | Aug 15, 2002 09:15 PM |
