Old Dec 19, 2011, 08:26 AM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Thanks, that gives me the information I need.
ruff1 is offline Find More Posts by ruff1
Old Dec 19, 2011, 11:09 AM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
nioa is offline Find More Posts by nioa
Old Dec 20, 2011, 09:28 PM
touche is offline
Find More Posts by touche
Canada, MB, Winnipeg
Joined Jan 2006
Mine came today. Quick inspection shows all seems well parts wise. Get some batteries tomorrow and start the process..
touche is offline Find More Posts by touche
Old Dec 21, 2011, 01:23 PM
Condor63 is offline
Find More Posts by Condor63
Condor63
Condor63's Avatar
Italia
Joined Oct 2011
Congratulations! Have fun with this nice airplane!
Condor63 is offline Find More Posts by Condor63
Old Dec 22, 2011, 06:35 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Sure would love to pull the trigger on the RxR model, if anyone sees a special going on please post here!
Old Dec 22, 2011, 06:43 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Sorry, the good deal (it was used however) auction has ended at eBay, however, here is a brand new one from a respected eBay supplier with FREE SHIPPING!
http://www.ebay.com/itm/NEW-Hobbico-...-/390330420800
I would go to the local hobby shop and gives you a chance to inspect the model before buying not that the one up at eBay has anything wrong with it.
Good Luck!
Carlos
PittSpecial is online now Find More Posts by PittSpecial
Old Dec 22, 2011, 12:35 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Thanks, looks like the price is comparable or close-enough to LHS, the LHS will probably get my business unless mfr has a good coupon for a direct purchase.
Old Dec 26, 2011, 11:56 AM
dandos23 is offline
Find More Posts by dandos23
United Kingdom, England, London
Joined Nov 2011
Well, Santa delivered a nice new watt meter for Christmas so I can now choose a prop with a bit more certainty that I am not going to blow things up.
I have also been thinking that the power 25 1250kv might be a bit better for this plane than the 870kv one that I am using.
I am also planing on putting navigation and landing lights on it but have decided to make them myself.
I will post some updates soon.
dandos23 is offline Find More Posts by dandos23
Old Dec 26, 2011, 12:10 PM
Condor63 is offline
Condor63
Condor63's Avatar
Italia
Joined Oct 2011
Hi all!!
Today I have fit together all the components received in the past days.
The new Fusion 3545/05 compared in size with the stock one.
The propulsion system as fitted onboard:
I have also ascertain that the installation of a motor 35mm dia x 45 mm depth don't needs modifications to the foam because there is enough clearance (about 0,8 mm) in depth.
Through the hole near the centre of image it's possible to see the Esc. Due of its lenght this is the only possible position without doing any modifications to the foam structure.
For the thrust tests I'm thinking to buy also a dynamometer like this:
20g-40kg-Portable-Spring-Electronic-Digital-Hand-Hook-Scale
Now I am going to install the stock prop, modified to fit the new 5mm shaft, before the final balancing of the model.
Old Dec 26, 2011, 12:15 PM
gulio is online now
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Wow, look at that big motor, lol.
I've been a little nervous about flying for a month and it has been cold,wet,windy. I flew 4 planes and 4 nice flights today in 7mph wind. The Sensei was one of them , it was cool.
I had just moved the C/G back a lot and it still acts a bit nose heavy. I think I'm going to try removing the weights w/out removing the cowl and then re-trim the elevator.
I still run 2 packs and can't imagine using just one , lol. Still on low rates , but getting a lot more comfortable with it. Funny , even though I can see that it is underpowered I get along fine with it so far.
Merry Christmas , guys.
gulio is online now Find More Posts by gulio
Old Dec 26, 2011, 12:31 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Looks good!
Though be prepared to replace the motor mount... I did pretty much the same as you and found the motor mount couldn't take it.... The foam got weak and the firewall/mount got loose.
So at least make sure your prop is perfectly balanced.
struggleforlife is offline Find More Posts by struggleforlife
Old Dec 26, 2011, 01:21 PM
smoggysasquatch is offline
Find More Posts by smoggysasquatch
Joined Oct 2011
That motor mount is definitely a weak link.....I have had to remove the cowl about 5 times and re bend the mount back. I got fed up with this and a buddy made a plate that goes on the outside of it and welded it. Also strengthened the legs (i guess that is what you call them). Yes it added some weight, but definitely worth it.
smoggysasquatch is offline Find More Posts by smoggysasquatch
Old Dec 26, 2011, 05:00 PM
Condor63 is offline
Condor63
Condor63's Avatar
Italia
Joined Oct 2011
The same weather here. It's not a cold winter after all, but the weather changes totally day by day and is difficult to plan a fly with acceptable conditions.
Very difficult operation without removing the cowl, in my opinion, because the weights are hard glued with silicone and is uncomfortable to work only through the small lower air intake.
Believe me: the cowl removing it's not a arduous operation and is the open door for more enjoyable modifications.
I wish you Merry Christmas.
Old Dec 26, 2011, 05:43 PM
Condor63 is offline
Condor63
Condor63's Avatar
Italia
Joined Oct 2011
I agree with you, guys!
I think it's possible to do something about these problems.
- a sturdy steel made 2 mm thick motor mount (now is 1.4mm), heavier but more appropriate for powerful motors.
- a strip of glass fiber electronic circuit board, located in the battery room and linked to the original firewall by 4 longer screws, instead of original ones. In this mode we can take advantage adding the solidity of the battery wall.
Tomorrow I'll do a check.
Old Dec 26, 2011, 05:47 PM
Joined Feb 2011
Yeah, do the check!
In my case it wasn't the mount itself (that was solid enough), it was the firewall the mount was attached to. This firewall is locked up in foam. but vibrations weakened the foam. The fact that my prop wasn't balanced, probably didnt help though.
Alert Flyzone Sensei wmcneal Foamies (Kits) 7 Sep 30, 2013 04:00 PM
