Black friday sale @ tower!
Hey guys!
Tower is having a BLACK FRIDAY SALE and you can save $50 on the Rx-R (Receiver Ready) Go To: http://www3.towerhobbies.com/cgi-bin...?&I=LW8004&P=3 |
Latest blog entry: E-Flite Retract Y-Connector Cable...
United States, OR, Bend
Joined Oct 2011
Had my eye on this bird for a while now... and that there's just too good a deal to pass up! Super excited - merry christmas to me! Very excited to get hands on this plane, been flying the HZ Super Cub for a few months now, and I can fly her ok... This should be a great next step for me. Thanks to all those who contribute to this thread, there looks to be some great info on here. |
Enjoy! Carlos
hey guys. im not sure if this is the right place to be posting this, but i was thinking about the RxR version of this plane. What i would do differently though, is use a lifepo4 battery. i was just wondering, would this battery work in it, or is it too big/ too low of a voltage? if its too low of a voltage, would it still be able to fly?
http://www.hobbyking.com/hobbyking/s...ehouse%5F.html |
Capacity: 2100mAh Voltage: 3S1P / 9.9v Discharge: 30C Constant / 40C Burst Max Charge Rate: 2C Weight: 218g (including wire, plug & case) Dimensions: 137mm x 45mm x 17mm Balance Plug: JST-XH Discharge Plug: XT-60 Connector Interesting: http://en.wikipedia.org/wiki/Lithium...sphate_battery Greater Safety and Longer Cycle Life assuming you can have an adjustable Li Charger (Assuming the same Charging Methods of those Li-Ion / Li-POLY take in effect for these newer packs) and then, you need to adjust a lower Voltage level as a final charge cycle due to it's lower Voltage capacity. I would read up as much as possible on these new Lithium Iron Phosphate Batteries over at the Power System section for more specifics. The SENSEI already suffers from a low STOCK Pitch-Speed Propeller (10 X 5) and using a lower Voltage Flight Battery pack at its peak Off-The-Charger Voltage will result in very disappointing flight characteristics. My 0.02 cents worth.
I would not in anyway go beyond the Maximum Voltage capacity of the STOCK ESC and STOCK Motor. For 4-Cell operation then, I would buy an Airframe replacement and install your own power system components. The model's size makes it look like a slow flying model but, I would say that the larger the model the slower it looks but, in actually it is moving at a good clip. FYI... Carlos
10 X 7 will increase AMP draw but, nothing that requires different Electronics unless of course you guys are considering to deviate from the recommended battery cell count and Li Type. Visit: http://www.rcgroups.com/forums/showp...3&postcount=94 My personal best propeller "is" the Park Zone 9.5 X 7.5
Again, those were David's (dbc) when he owned the model that I have presently. He measured those values..... ![]() Perhaps you meant to ask, gulio ? |
| Thread Tools | |
| Alert Flyzone Sensei | wmcneal | Foamies (Kits) | 4 | Apr 01, 2013 11:52 PM |
