Old Jan 28, 2013, 12:10 PM
Rightfly is offline
Find More Posts by Rightfly
I use EXPO and Senior Rates
Rightfly's Avatar
United States, MI, Custer
Joined Jan 2010
Not to wear out a discussion, but there has been some discussion on the wing bolts recently. I just accidently discovered a source of nylon bolts that everyone probably has locally. A few years ago I stopped in at a Auto parts store to buy license plate bolts for my pick-up. Not one to read the fine print, I bought bolts that "fit most imports" and they did not fit my Ford F150. I put them in a drawer for future use maybe. Today they were rediscovered and in futher reading the fine print they are 6 x 25 mm black nylon bolts. So now I have 4 extra nylon wing bolts for probably a dollar or so.
So if you chose to stick with the nylon bolts try your local auto parts store for license plate screws.
Good Flying,
Roger
Rightfly is offline Find More Posts by Rightfly
Old Jan 28, 2013, 02:22 PM
accel8or is offline
Find More Posts by accel8or
Mark Beltran
accel8or's Avatar
United States, CA, Westminster
Joined Dec 2010
Rightfly/Roger, that's real helpful. I will write that down on the manual, thanks.
While on the subject of alternate parts, I wonder if there are any plastic cowlings out there that will fit on the Sensei? What about the Apprenctice's cowling?
accel8or is offline Find More Posts by accel8or
Old Jan 28, 2013, 02:28 PM
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
Originally Posted by Danny_l View Post
+1 .fly it stock
definitely fly it stock first and see if u wanna upgrade. with the stock, i too get 10 minute flights. also inverted low flybys, rolling circles, cuban 8's, stall turns, and immelmans with the stock motor.
Old Jan 28, 2013, 03:07 PM
3rd Try is offline
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
It's easy to make one with just a little effort. Model builders have been using plastic bottles and a heat gun/hair dryer for decades. You can use your original cowling or make a custom shape using a balsa block. Start with the bottom of a plastic bottle that will fit over you form, fitting as close as you can find, and longer than your form. Apply heat slowly and evenly and watch it shrink and take the shape of your form. After it cools you trim the open end to fit, open holes in the front for prop and air flow and paint to match. It will take some practice to get the best results.
Dennis
3rd Try is offline Find More Posts by 3rd Try
Old Jan 28, 2013, 05:14 PM
Rightfly is offline
Rightfly's Avatar
Joined Jan 2010
Hi 3rdTry
How much heat do you need to use? A hair dryer or paint removing tool?
Also, if I did this over my existing good cowl would the process damage the cowl. I had not heard of that process before but it sounds simple enough.
Roger
Old Jan 29, 2013, 01:42 PM
Valkyrie. is offline
Find More Posts by Valkyrie.
United States, MI, Plymouth
Joined Aug 2012
Here is an update to my earlier post about motors. While checking the stock prop (10x5) and the 9.5x7.5 I noticed that the esc started to smell like burnt electronics. So off to the LHS and I came home with a new park 480 1020 kv motor, I had a 30a e-flite esc at home to use with it. The interesting thing is that while looking at the new sensei at the LHS I noticed that the esc was moved from inside the battery compartment to under the motor mount and held in place by a zip tie.. I placed a call to FZ and they confirmed that this is the new location for it and they are also sending me a new esc. Below are some pictures of how I mounted mine. I also had to extend the battery leads and use an ext. to reach the RX. As far as props go I went with the recommended 10x7 and will see how this flies.
How much does the old motor weigh as I need to find the difference to the new motor so I can adj the weight in the cowl? How many weights had to come out?
Howard
P.s. horizon hobby said not to check the wattage while the plane is secured on the ground as it gives a false higher reading as the plane is not allowed to freely move thru the air and an on board unit would be better.
Valkyrie. is offline Find More Posts by Valkyrie.
Old Jan 29, 2013, 01:45 PM
3rd Try is offline
Joined Jul 2012
Originally Posted by Rightfly View Post
Hi 3rdTry
Roger
Roger, I had not done shis on the foam parts previously so I experimented with a damaged cowl that I still have. Based on my experiment I would not recommend using your good cowl as a form. The heat brought out the grain in the foam more than I would consider acceptable. If you were using a damaged cowl that you were no longer going to use however it does not destroy it. Years ago I did this with a blow dryer, 900w I believe, to form a cowl that I had broken. My experiment today was done with a T/H heat gun (900w). The technique is similar to that used to cover compound cures with mono/ultra kote on balsa. I hope this has been helpful.
Dennis
Old Jan 29, 2013, 01:56 PM
3rd Try is offline
Joined Jul 2012
Howard
Howard, I installed the Park 480 also, back in September. There was no need to remove any weight from the cowl. The performance of the 480 will make you ask why you didn't do it sooner. I bought my Sensei in July and the ESC location was as you described on my original setup. As to burst testing the model static. You will have a higher amp reading and as long as your static reading is within your system limits you can feel confidant that when the prop unloads your amp draw will always be within a safe range.
Dennis
Old Jan 29, 2013, 04:08 PM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
...The interesting thing is that while looking at the new sensei at the LHS I noticed that the esc was moved from inside the battery compartment to under the motor mount and held in place by a zip tie.
Howard,
Mine came from the factory with the ESC under the motor mount. Maybe this is one of the things they did to improve reliability of the components. I haven't had any issues with mine, plenty of power and not too bad on batteries.
Thanks for the info, that is a good one to remember.
Kevin
ruff1 is offline Find More Posts by ruff1
Old Jan 29, 2013, 04:18 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Howard
The motor is 73 grams and the steel mount is 20 grams. The weights are about 11 grams each.
gulio is offline Find More Posts by gulio
Old Jan 29, 2013, 07:42 PM
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
Dennis
Thanks. Didn't know you could do that. I got a monokote heat gun that might work.
Old Jan 29, 2013, 07:44 PM
Joined Aug 2012
Thanks Gulio,
With a 2200 mah battery and two of the weights removed from the cowl, the cog of the plane was level. I added one of the weights back in to make it a little nose heavy and will adjust it after I fly it. Am I on the right track?
I reinstalled the cowl using four Velcro tabs, and with the esc in its new location I had a small gap between the cowl and the fuse. Not that it would hurt anything it just bothered me to look at it. I had some white monokote left over from another project so I used it over the gap
So now I have the old motor and FZ is sending me a new esc, I was thinking about using in my Hobbyzone super cub lp. It is a lighter plane and my not tax the system as much. It would be a complete rebuild as I would need new servos as well.
Howard
Old Jan 29, 2013, 07:58 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
You'll be fine as the balance has a huge range.
Old Jan 29, 2013, 11:05 PM
Danny_l is offline
Find More Posts by Danny_l
Danny_l's Avatar
South Africa, WC, Cape Town
Joined Oct 2011
Howard
Hi Howard,
That is exactly what I have on my Sensei. I think it has probably 150 flights (at least) with that setup. you can use safely any of the props (10x5, 9.5x7.5, 10x7, 11x6)I've tried them all, they all work fine and no problems .
The ESC is still the stock, I repladed the stock motor after it dropped a magnet.
Have fun,
Danny
Danny_l is offline Find More Posts by Danny_l
Old Jan 31, 2013, 09:06 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
So for a faster motor replacement over stock the Firepower 480 sport? I just want to use the existing mount. I know I will have to upgrade the ESC.
Is it a good motor? Any others that just fit? I saw the park 480 but think it doesn't fit the stock mount?
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Alert Flyzone Sensei wmcneal Foamies (Kits) 7 Sep 30, 2013 04:00 PM
