Old Sep 04, 2012, 11:42 PM
seattlebuoy is online now
Find More Posts by seattlebuoy
seattlebuoy's Avatar
United States, AZ, Flagstaff
Joined Sep 2011
Converting the Sensei to floats for our club's yearly float fly in this weekend. I'll take pix and document the mods. Will be using stock mains for rear mount of float and fabbing an adapter to connect to nose wheel mount. For now, no rudder and the nose wheel adapter will allow for adjustment of float to plane angle of incidence. Planning on starting with about +1 degrees.
seattlebuoy is online now Find More Posts by seattlebuoy
Old Sep 05, 2012, 07:30 PM
zamjohn is offline
Find More Posts by zamjohn
Canada, MB, Steinbach
Joined Jul 2011
Stock motor
There are 14 magnets in the stock motor. I have had 2 of these motors go on me this summer so now I switched to NTM 3530 1100KV and its still hangin in there. I think it is still under-powered but then it isn't a pylon racer.
zamjohn is offline Find More Posts by zamjohn
Old Sep 05, 2012, 09:23 PM
gulio is online now
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I just went to a 11x5.5 prop on my stock motor , but I fly prettly mildly nowadays. That 3530 x 1100 motor is a good one for many things at my place.
gulio is online now Find More Posts by gulio
Old Sep 05, 2012, 09:44 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--Eflight Power 15 works great with a 11x8 and 2200 3s pulling under 33 amps WOT
--Recommend 1/4 plywood firewall also-- just cut 1 inch of foam off the front and gorilla glue
G-Forse is offline Find More Posts by G-Forse
Old Sep 07, 2012, 12:32 PM
Rangie5169 is offline
Find More Posts by Rangie5169
Rangie5169's Avatar
United States, TX, Arlington
Joined Nov 2011
Great customer support Hobbico!
Kudos to Flyzone/ Hobbico on their exceptional customer service.
Was flying my wife's Sensei showing her it could do more than just level circuits. Went inverted, battery hit the hatch and away it went (the hatch) to never never land. i wasnt about to go scouring the farm field to find it. I thought cant be more than $2 online. Was I surprised to find out you can onlt get it with a fuselage replacement to the tune of 60 something dollars!
Well i had to try, I called customer service to see if they could do anything. The rep on the phone went into the warehouse and found an extra and put it in the mail to me free of charge shipping included.
Now thats what I call customer service! Well done guys.
When it comes I will wire it to the inside so if in the future this happens again, I won't lose it.
Rangie5169 is offline Find More Posts by Rangie5169
Old Sep 07, 2012, 12:39 PM
briguyy is offline
Find More Posts by briguyy
United States, CA, Santa Maria
Joined Sep 2006
I was surprised too when i ordered a wing set and it didnt come with the wing joiner (that got damaged in the crash) Called up and the technician sent me out a new one free of charge....called em back too thank em. They are really good about keeping our planes up in the air!
briguyy is offline Find More Posts by briguyy
Old Sep 08, 2012, 01:38 PM
touche is offline
Find More Posts by touche
Canada, MB, Winnipeg
Joined Jan 2006
I always tie my battery hatches with a string or strong thread. easy to do and saves grief.
touche is offline Find More Posts by touche
Old Sep 09, 2012, 12:27 PM
briguyy is offline
Joined Sep 2006
I just ordered a 40amp ESC from HobbyKing to go in the Sensei:
http://www.hobbyking.com/hobbyking/s...ontroller.html
I was wondering does anyone know their shipping times from the international warehouse..i cant get an answer from them and they dont specify on their website.
-Briguyy
Old Sep 09, 2012, 12:32 PM
gulio is online now
That's a funny word
NE Ohio
Joined Apr 2003
I've never lost one , but That would also keep me from leaving it in my pocket or on the bench or grass.
Old Sep 09, 2012, 04:20 PM
Kawi is offline
Find More Posts by Kawi
\_(ツ)_/
Joined Sep 2011
-Briguyy
as long as it isn't backordered, I usually get my stuff in a week.
Kawi is offline Find More Posts by Kawi
Old Sep 10, 2012, 12:19 AM
Rightfly is offline
Find More Posts by Rightfly
I use EXPO and Senior Rates
Rightfly's Avatar
United States, MI, Custer
Joined Jan 2010
Hi! Briguyy,
You probably will not get an answer frpm HK on shipping time based on discussions I have read on other threads. I have not ordered a lot of stuff from HK, mostly their FrSky Fasst receivers. My experience has been in the 3 to 4 week category on shipping time.
Now that Value Hobby carries the FrSky receivers I will buy from them at the slightly higher price. For other electronics I like to use HeadsUp RC. Prices will be slightly higher but all available in USA at $2 - $4 shipping.
Rightfly is offline Find More Posts by Rightfly
Old Sep 10, 2012, 12:20 AM
Rangie5169's Avatar
Joined Nov 2011
Whats the procedure for tightening up a loose nose gear? I have a lot of rotation both ways. Do i need to remove the nose of the fuselage?
Old Sep 10, 2012, 09:24 AM
3rd Try is offline
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
Check your rudder/nose wheel servo. The issue is probable there. To access the nose wheel bracket you must remove the cowel and the motor mount. You then can access the 2 screws that retain the shaft.
Dennis
3rd Try is offline Find More Posts by 3rd Try
Old Sep 10, 2012, 10:22 AM
Kawi is offline
\_(ツ)_/
Joined Sep 2011
also tighten the little collar up against the wheel itself. I found no matter what I did I had a lot of rotation and after I tightened that I noticed a lot of slop went away. You may also be bending the long servo wire somewhere inside the cowl. If you stick a skewer in a strategic spot it will hold the wire tight against the wall of the plane and keep that wire moving tight and straight.
This of course assuming everything is tight and proper inside at the servo horn point.
Old Sep 10, 2012, 11:02 AM
Joined Sep 2011
I ended up changing out the horn for a dubro part and that solved all of my slop issues. The existing horn is pretty wimpy in terms of set screw. Rock solid after that part swap.
Alert Flyzone Sensei wmcneal Foamies (Kits) 7 Sep 30, 2013 04:00 PM
