David,
I am shocked and surprised that no one has opened a thread on this nice trainer model and I looked and looked everywhere and nothing. Seems like you are the first to discuss this model. I almost picked up one at the local Hobby Store last weekend and can tell you that this model is very well designed. The model does not need flaps as it comes in very nice for a landing and foam construction is first rate and easy to repair. I noticed that the Cowling is made of the same Foam material and not made of plastic or fiberglass so, it is my recommendation to tack on the piece with spot glue points so, you can remove it should you find reason to remove the cowling like in an ugly nose first crash during Training sessions. I would use the rubbery glue that Park Zone uses for this job. ![]() Now that you have one, I will wait patiently in case you might want to part with it sometime in the future. ![]() Here is Fly Zone's Video of this model:
Latest blog entry: E-Flite Retract Y-Connector Cable...
Joined Apr 2008
I found another thread under Electric Plane Talk about the ST Discovery:
http://www.rcgroups.com/forums/showt...trainer&page=5 This is the Sensei. But be careful. There's some questionable "information" (more like misinformation) about the plane here. Flew a couple more batteries today with some moderate breezes that were a little gusty. I'm impressed with the way the Sensei handles wind; especially considering it's very light wing loading. It's bumped around a little but remains manageable and it had no stability problems. Put a wattmeter on it and it drew 260 watts at 22.5 amps. Prop RPM was 9030 for a calculated thrust of 41 oz. I substituted an APC 11x5.5 electric prop for the stock 10x5 and power draw increased to about 300 watts at 26.5 amps. 7980 RPM and calculated thrust of 44 oz. I put the stock prop back on as the power increase would not be very significant and it's adequately powered with the supplied prop. |
On Wednesday I too be acquiring this wonder model.
![]() Can't wait to entertain the little ones at the RC Club field with the drop hatch! ![]() Just what the Doctor ordered!
I just came back from a nice gentleman who has posted here and got myself a like "New" Sensei with a Parachute and EC3 -to- Ultra Deans harness for a cool $100 plus physical pickup.
![]() I am putting her together as I type! ![]() Have fun with the T-Shirt! |
My new Sensei!
Hello.
I just acquired one extremely like 'new' Fly Zone Sensei Rx-R (Receiver Ready) from a good friend a few miles away. I have not seen such a well designed Foam (EPP) model ever until I laid eyes on this one from Fly Zone. It has a very smooth finish to the foam and the wings are very stiff and has spars running throughout the wing assembly and best of all it has a very smart method of joining the two halves of the wing together with a overlapping joiner with plastic tabs. The Main landing gear goes on with two screws and the entire tail (Horizontal & Vertical Stabs) get inserted with a foam keel and held by one machine screw. The servos are pre-installed and control horns all done for you. This must be the Fastest Build I have ever done! Fly Zone Web Site: http://www.flyzoneplanes.com/airplanes.html Fly Zone Sensei: http://www.flyzoneplanes.com/airplan...535/index.html Fly Zone Sensei Manual: http://manuals.hobbico.com/hca/hcaa2535-2536-manual.pdf A few Pictures of my specific Build: Model came inside the original BOX: ![]() ![]() All parts and and hardware accounted for: ![]() Used the Castle Creations BERG 7-Channel Super Narrow 72Mhz FM Rx: ![]() Inserted some white and flexible foam on both sides of RX Crystal: ![]() ![]() Receiver Final Installation: ![]() ![]() Control Horn Plastic Locks: ![]() ![]() Used a Turnigy 3-Cell, 2200mAH, 25C discharge, Li-POLY: ![]() Showing Velcro inside the FUSE / Battery Compartment: ![]() ![]() Battery tucked inside the FUSE / Battery Compartment: ![]() Battery Plastic Hatch Closed: ![]() Another item of deviation was the propeller as I just do not think a propeller of "5" pitch is sufficient speed for this model so, I selected the APC "Slow Flyer" 10 X 7 as this propeller will provide balanced amount of airspeed and thrust: ![]() ![]() ![]() Model is complete and ready to fly! ![]() ![]() Stay tuned for the Flight Video!!
Maiden Flight
Here is my Maiden Flight with the Fly Zone Sensei R-Rx (Receiver Ready)
The Setup: Stock Motor /ESC Stock Servos and linkages Receiver: Castle Creations BERG 7-Channel DSP 72Mhz Super Narrow Band Battery: Turnigy / Zippy 3-Cell, 2200mAH, 25C discharge, Li-POLYs Other: EC3 -to- Ultra Deans Connector Propeller Used: APC "Slow Flyer" 10 X 7 Summary: I can not stop talking about this model as it is perfectly designed and if you see inside the FUSE and the manner in which it goes together Wow, just a few minutes is all you need. The Flight characteristics is majestic at best. She is a true Floater more like a Super Large GWS E-Starter with the Tri-Cycle gear and lots of improvements! In the following Video, I did not do too much stuff with it because that CHEAP Plastic Spinner did not seat well and I did not dare to Throttle UP too much. Here's the Video:
David,
Later this afternoon I will Upload another Video that Gerry captured from our visit to the RC Club this morning ...it is on the way to work!!![]() Since I did fly the model late yesterday early evening and right before the Sun set. I had the opportunity to remove the APC "Slow Flyer" 10 X 7 and Returned the STOCK 10 X 5 propeller. Once the batteries topped off the model was commanded for take off in rather windy conditions with a Party Streamer and a small Rock at one end a-fixed with rubber bands. The model flew like a champ and it gained altitude in no time and I released the streamer by flipping the Bombay Door Switch (5th Channel) That Streamer must have been at least 200 feet because it took a very long time to come down!Okay, today I flew the model with more Zest Appeal and again stay tuned for the Video(s)!! Carlos
| Thread Tools | |
| Alert Flyzone Sensei | wmcneal | Foamies (Kits) | 4 | Apr 01, 2013 11:52 PM |
