Old Aug 19, 2011, 07:28 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Firmware for the KK Micro by JussiH or other KK's using the IDG500 gyro
This firmware was adjusted to the KK Micro. Since it came with a 168 I added the possibility to select stick sensitivity with stick commands when arming.
Right stick UP and LEFT: Low for hovering and AP.
UP: Medium for flying around.
UP and Right: Warthox Mode! This really takes advance of the 500 deg/sec maximum of the gyro Expo recommended.
The mode is stored in EEPROM, so it will be effective until changed with another mode.
This firmware will also be useful for the "Nintendo Tear-down Crew" using KK with Wii gyros.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 19, 2011, 08:05 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
lol!
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 19, 2011, 02:06 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
yiiheaa im ready lets take a ride
thanks rolf for the special fw
will test it on weekend..
will there also be a version for quad x?
warthox is offline Find More Posts by warthox
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Thanks...will test when the weather improves a bit here!
JussiH is offline Find More Posts by JussiH
Old Aug 22, 2011, 04:35 AM
jubbee is offline
Find More Posts by jubbee
Joined Nov 2010
Pardon my lack of knowledge, reading ???
but where can you buy the kk boards with idg 500 gyros ? Whats the main Diff`???
Is there any news or future plans for Accelerometers (for autolevel).
regards
Jubbee
jubbee is offline Find More Posts by jubbee
Old Aug 22, 2011, 04:39 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
The board that Warthox has on his quad will very soon be available from KKmulticopter.com and viacopter.eu
No addons for Accel, GPS and similar are planned ATM. For those you can look into Multiwiicopter or OpenPilot.
Old Aug 22, 2011, 06:07 AM
jubbee is offline
Joined Nov 2010
OK Thanks,
So whats the Advantage with the IDG 500?
Old Aug 22, 2011, 06:19 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Better precision, less temperature drift, no need for extra PCB for yaw gyro, simpler assembly, price....
Gyrostars will probably also become unobtanium soon, as the factory that produces them was wiped out by the quake in Japan....
Old Aug 23, 2011, 03:08 AM
jubbee is offline
Joined Nov 2010
Sounds good, thanks for the info.
Any talk or ideas on implementing accelerometers for the KK board so
it can Autolevel.
Old Aug 23, 2011, 03:37 AM
CaLviNx is offline
Find More Posts by CaLviNx
not surprised.........
CaLviNx's Avatar
Cyprus, Ammochostos, Liopetri
Joined Jan 2005
it can Autolevel.
+1 pretty please
CaLviNx is offline Find More Posts by CaLviNx
Old Aug 23, 2011, 03:47 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Well, I am not a coder, so this answer is probably not definitive....
The main issue with the KK controller is the fact that we use the internal oscillator and run it at 8 Mhz. To my knowledge, we are already stretching the ressources of the AVR pretty thin and the angle calculations and filters needed for a proper autolevel is probably gonna be too tall an order for an Atmega running @ 8Mhz on internal clock!
In theory it can be done, as we have 2 free ADC´s available. In practice, I dont think its gonna happen...but you never know
If you want something more advanced with autolevel capability, you should look into Multiwiicopter or OpenPilot CopterControl! Both platforms have autolevel, and a lot of other useful features. I have flown both platforms and they perform very well.
For multiwiicopter there will very soon be a "mini" board available from me. This will come standard with 3 axis gyro and accel, and there is magnetometer and barometer breakouts available for it!
OpenPilot CopterControl is available thru the OP shops....
Old Aug 23, 2011, 04:29 AM
CaLviNx is offline
CaLviNx's Avatar
Joined Jan 2005
Do you have a website or do you supply via P.M. only ?
Old Aug 23, 2011, 05:00 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
www.viacopter.eu
Old Aug 23, 2011, 05:54 AM
nasgul is offline
Find More Posts by nasgul
nasgul's Avatar
United Kingdom, Wales, Gwaun-Cae-Gurwen
Joined Mar 2011
the multiwii board you mention, will that have autolevel as standard? is my thinking that the barometer is for height levelling?
nasgul is offline Find More Posts by nasgul
Old Aug 23, 2011, 06:32 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Yes, that is what Jussi wrote.
LazyZero is offline Find More Posts by LazyZero
Discussion Improved firmware for the KK multicopter, also the HK KK. kapteinkuk Multirotor Electronics 2965 Apr 05, 2016 09:08 AM
For Sale KK Multi Coppter Controller 4.2 firmware, Ver 3 or 4 critters Aircraft - Electric - Multirotor (FS/W) 3 Jun 06, 2011 03:22 AM
Sold Tiny Bright Lights Sub Micro for P-51 or other UM bamabaxter Aircraft - General - Miscellaneous (FS/W) 2 May 22, 2011 05:42 AM
For Sale PNP BRUSHLESS CONVERSION FOR PZ or other Micro Airplanes/SPRING SPECIAL! scharlach Aircraft - General - Radio Equipment (FS/W) 0 Apr 23, 2011 12:19 PM
Wanted Servos - JR DS285's (3) or HS-65MG's - For T-Rex SE (open to other micro options) Steve_C Aircraft - General - Radio Equipment (FS/W) 1 Feb 19, 2007 07:31 PM
