Old Aug 19, 2011, 07:14 AM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
Question
Brand-New DX8 Won't Hold a Charge
Hi there,
Got my brand-new DX8 and charged it up overnight. Everything was great setting up my new 3DHS Edge, so it was on for maybe about an hour - if that. Go to use it today to set up my quad and the battery is down to 3.4v and the alarm sounds.
It was definitely switched off, so that isn't the cause. Also when I turn it on, it kinda "blips" and then turns on properly. Is this normal?
TIA
banzi28 is offline Find More Posts by banzi28
Old Aug 19, 2011, 07:32 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Did you charge it overnight before starting? The batteries come with only partial charge.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Aug 19, 2011, 08:23 AM
banzi28 is offline
Joined May 2011
Yes I did.
Old Aug 19, 2011, 08:34 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
I would call Support and tell them. You'll probably get a new battery.
Andy
Site Sponsor
Old Aug 19, 2011, 08:47 AM
banzi28 is offline
Joined May 2011
Many thanks Andy,
I'll give them a call when they open.
Old Aug 19, 2011, 09:21 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Recycle battery a couple of times and see if it comes to life. It may have been sleeping too long.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Aug 19, 2011, 09:23 AM
banzi28 is offline
Joined May 2011
I was just thinking of doing this with the cycle mode on my charger. Just don't have the correct cable.
Old Aug 19, 2011, 09:24 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Good idea. But if it does come to life treat with care. Sometimes they die again. I would call Horizon anyway.
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 19, 2011, 09:44 AM
banzi28 is offline
Joined May 2011
They want me to leave it on the charger until the blue light goes out again.
Old Aug 19, 2011, 09:59 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Using a servo extension and removing the case around the end with the pins works perfectly. The end spacing is the correct one for the stock battery connector. Just be careful to double check the polarity.
freechip is offline Find More Posts by freechip
Old Aug 19, 2011, 10:04 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The blue light will not go out with a NiMH pack installed. It only goes out on LiPo packs.
Charge it for 10-12 hours, then see how it does. You should see a rapid drop from the start voltage (5.3-5.6V) down to a level around 5.0V, then it will take "forever" to drop down to 4.5V.
Andy
Site Sponsor
Old Aug 19, 2011, 10:10 AM
banzi28 is offline
Joined May 2011
You're kidding me? So the bloody support guy was wrong?
I'll try charging it one more time and then call them back if it doesn't hold a charge. One thing I did notice is that the battery icon bar is only at 50%.
Old Aug 19, 2011, 10:23 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Normal for the battery bar graph to show that because its also used for the lipo battery. The bar will be full with a fully charged 8.4v 2s lipo.
Old Aug 19, 2011, 10:24 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Don't you just hate humans?!?!?
The LiPo batteries have been so overwhelmingly popular he probably forgot the difference between NiMH and LiPo behavior on the LED.
Andy
Site Sponsor
Old Aug 19, 2011, 10:25 AM
banzi28 is offline
Joined May 2011
For the love of...
Is there a direct number for Spektrum support, or is it handled all by Horizon?
Discussion New E-Flite 3S 11.1V 3200mAh Lipo - "Low Voltage" Won't Charge? itsme2 Batteries and Chargers 4 Oct 16, 2014 05:07 PM
Discussion 6-cell NiMH 900 mAh won't hold much charge Wormwood Batteries and Chargers 4 Apr 04, 2007 03:22 PM
Help! Batt won't hold charge bizzo Batteries and Chargers 12 Aug 24, 2006 11:38 AM
Why won't my brand new NiMH Aerohawk batteries charge correctly? ucsdgemini Batteries and Chargers 14 Mar 13, 2004 07:21 PM
CP1300s won't hold a charge mumblety-peg Power Systems 7 Jan 16, 2002 11:25 AM
