Old Aug 18, 2011, 09:56 PM
dydx is offline
Find More Posts by dydx
dydx's Avatar
Brisbane, Australia
Joined Mar 2006
Vacuum Pump Concept and Demo
Hi Folks
Devising a vacuum pump system is one of the first steps I have taken into the world of composite fabrication esp. vacuuming bagging.
The vacuum pump I've developed is based on a car tyre compressor. I've seen quite a few examples of this on these forums and elsewhere and it seemed like a fairly accessible and cost effective path to take. (if a fridge compressor turns up I might look into that - but I haven't been able to source one for cheap and am a little scared of 240V).
The pump pulls a vacuum of ~23''hg and assuming I can plug some of those leaks should be able to hold it so the pump doesn't need to run all that often. After running the pump for 5mins in the sealed pipe vessel the pump and piston was warm to touch at about 40degC. Running the pump in open air for 5mins while blocking the pressure outlet so that the system was under some stress resulted in about 40degC as well. Based on this, I'm not too concerned about the pump overheating and seizing up and long as it doesn't need to run continuously.
When using the on/off switch to regulate the vacuum by hand (with a good seal on the pipe prior to filming), I was able to maintain 15''hg by cycling on for about 5secs every 40secs.
The next step is to develop a pressure switch in order to maintain a constant vacuum of ~10''hg for white foam and ~15''hg for blue foam. From what I've read, these are the levels I should aim for.
Please let me know what you think and how well you think this will work, is there anything I'm overlooking?
Vacuum Pump Demo (10 min 6 sec)
Cheers
Pete
dydx is offline Find More Posts by dydx
Old Aug 18, 2011, 11:54 PM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Looks good Pete.
I use a freezer pump triggered by a 5A 240v vac-switch from ACP. It was $75 but heard you can get similar for a lot cheaper on eBay. The switch came with instructions so despite having reservations about 240v (same as you) I wired it up and it worked safely. I don't use a reservoir either. Bought one 2nd hand but it works fine without.
I've used it for 3 wings/ 2 tails and it's been faultless. I use aquarium tubing for the system and the inlet into the bag is simply a small hole supported by blu-tac.
HTH,
Chris.
DrFragnasty is online now Find More Posts by DrFragnasty
Old Aug 21, 2011, 03:51 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
There are several threads on these forums describing how to devise and wire up a regulator for your vacuum supply.
Mine uses junk parts and only cost the price of the capacitor accross the micro switch points.
Do a quick search and you will find some. If you have difficulty, let us know and I will have a look. I have contributed to more than one myself, so I know they are out there.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Aug 21, 2011, 07:51 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
I get a kick out of this guys vaccum switch http://www.rcgroups.com/forums/showt...=vaccum+switch
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Sep 04, 2011, 06:08 AM
dydx is offline
dydx's Avatar
Brisbane, Australia
Joined Mar 2006
Regulator Complete
Thanks everyone. I've completed the regulator now. Just need to tidy things up and I should be ready for the next phase.
Any comments on the progress so far would be welcome.
The next phase will be getting some plastic and breather material, sealing things up, connecting the hose somehow. (suggestions on ways to do this would be appreciated)
Cheers
Vacuum Regulator (8 min 54 sec)
Old Sep 05, 2011, 02:00 AM
Ward Hagaman is online now
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
It's a little crude, but you can seal plastic with a caulking gun and the cheapest latex caulk you can buy around the perimeter. You can seal around the hose as well with a big gob of the caulk as well. Works well for big jobs where you don't want to (or can't) use a sleeve type bag.
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Sep 05, 2011, 05:15 AM
Joined Apr 2010
I played around with puddy and sheets of poly enough to learn that the proper clips are worth the money unless you need a large bag [like Ward mentioned above.]
http://www.cstsales.com/vacuum_bag_seal.html
Old Sep 13, 2011, 04:12 AM
jameotron is offline
Find More Posts by jameotron
kids ate my heli budget
jameotron's Avatar
Auckland, New Zealand
Joined Feb 2005
dydx: would you be able to grab a multimeter and tell me how much current your pump draws during operation? I'm looking at building a micro controller based pressure switch, but need to know how big the relay I need is.
jameotron is offline Find More Posts by jameotron
Old Sep 13, 2011, 04:46 AM
dydx is offline
dydx's Avatar
Brisbane, Australia
Joined Mar 2006
jameotron: its a 12V compressor and draws 3 - 5A when running depending on load. But the inrush current spike for these pumps can be really high. I don't have a way of measuring this, but was going to look into a spark suppression circuit:
How are you planning a micro controller system? My first thought was to use an arduino with some kind of pressure sensor, but I could not find any thing cheap that would be suitable for a high vacuum (this was the closest cheap sensor I could find).
If you did have some kind of sensor that would be awesome. You could program hysteresis, log the cycle times, send SMS's if there's a leak, monitor vac-bagging progress remotely. . That kinda thing is more in my realm of expertise, its composites that confuse me.
Old Sep 13, 2011, 04:14 PM
jameotron's Avatar
Joined Feb 2005
Well, I was looking at the Freescale MPXV6115VC6U. According to the datasheet it is sensitive from 0 to -115kPa (~33"hg). Output is a simple 0 to 5V voltage level that can be sampled with an ADC pin. I can throw together a breakout for it, hook it to my Uno. I was also thinking a two-line LCD and buttons for selecting target pressure, and cycle duration (ie be able to set 300hPa (~10"hg) for 48 hours) and hit start and have it automatically handle the whole process. Probably want a piezo buzzer too.
I'm wanting to convert a fridge compressor, but I will be adding a decent sized vacuum reservoir to reduce the duty cycle of the compressor. For my application I will be wanting to use a relay to control the 240VAC mains supply, but for you you may be able to get by with a darlington pair. You might want to do something smart like use two and have one charge up a largish cap to handle your startup current and another to connect the load once the cap is charged.
Let me know if you want to work together to design a board - I have been making them for my other project (axe.io) and it's pretty cheap if you're making a small footprint board.
Also, regarding the board you linked to on DIY drones, 2kPa is only about 0.5"hg, so it's not up to the job.
Last edited by jameotron; Sep 13, 2011 at 04:18 PM. Reason: adding extra about MPXV7002DP
Old Sep 14, 2011, 10:29 PM
jameotron's Avatar
Joined Feb 2005
Actually, this looks like a better bet. Connect one side to the vacuum and leave the other open to atmosphere. It will give you an analogue voltage corresponding to the pressure differential between the two. Although it will need an opamp because the maximum voltage output is only 40mV.
Old Oct 08, 2014, 01:25 AM
c.walker is offline
Find More Posts by c.walker
Joined Jul 2006
Took a stab at building an Arduino controlled pump. Here's the breadboard version, readout is in inches Hg.
arduPump breadboard (1 min 4 sec)
c.walker is offline Find More Posts by c.walker
Sold VACUUM PUMP BAGGING SYSTEM with EXTRAS Shipped CONUS LowWatts Aircraft - General - Miscellaneous (FS/W) 2 Aug 15, 2011 08:03 PM
Discussion vacuum pump and regulater rct Hand Launch 2 Aug 14, 2011 05:48 PM
Sold Vacuum Pump & Carbon Fiber Kit wizzinbya Aircraft - General - Miscellaneous (FS/W) 2 Aug 13, 2011 02:39 PM
Sold Gast Air/Vacuum Pump - FREE!! (Almost) slozuke Aircraft - Sailplanes (FS/W) 2 Aug 09, 2011 01:40 PM
Discussion Sparkfun Vacuum Pump gjbSA Hand Launch 12 May 07, 2011 01:53 AM
