Old Dec 19, 2012, 11:43 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
The main struts shouldn't need to be bent at all, just cut off what's too long. The stock wheels have their own axles. They just mount on the straight strut using stock hardware. Not sure why you need to bend anything on the Eflite retracts.
xviper is offline Find More Posts by xviper
Old Dec 19, 2012, 12:00 PM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
This is why I was asking the question. I am not sure if he realizes that there are axles.
Fentonflyers is offline Find More Posts by Fentonflyers
Old Dec 20, 2012, 03:21 AM
Tomster79 is offline
Find More Posts by Tomster79
Tomster79's Avatar
Germany, HE, Schöneck
Joined Dec 2012
Ok , i try to explain again :
I hate the Axles which are mounted to the straight strut of the retracts..
On my PZ Thunderbolt i had the same straight retract struts ..
After harder landings , the axle was turning on that straight struts..
Then i bought the prebent struts fitted for the Thunderbolt (PKZ5317)
no need to mount the axle to the strut anymore ..
Perferct solution in my optinion..
That´s the reason , i was searching for prebent main struts for the Scimi , too..
I hope this was a little understandable now
It´s hard to explain such technical things in english for a german guy
I installed the retracts already , how you told me , cutted the strut , installed the axles and wheels.. Retracting and extending works fine , without any binding..
Looking forward to maiden it , when the weather is better in Germany
TOM
Tomster79 is offline Find More Posts by Tomster79
Old Dec 20, 2012, 06:31 AM
Joined Jan 2012
Now I understand. Have you tried grinding a significant flat area on the strut so the set screw has sufficient area to grip?
Old Dec 20, 2012, 07:54 AM
Tomster79's Avatar
Joined Dec 2012
No, not yet..
But i will get my Dremel back in a few days..
Tom
Old Dec 22, 2012, 11:35 PM
johnnyjet is offline
Find More Posts by johnnyjet
Prattville, AL,USA
Joined Aug 2000
hi
johnnyjet is offline Find More Posts by johnnyjet
Old Dec 25, 2012, 04:23 PM
Tomster79's Avatar
Joined Dec 2012
Originally Posted by johnnyjet View Post
hi
Hi
Old Dec 27, 2012, 09:00 AM
AWDstylez is offline
Find More Posts by AWDstylez
Joined Aug 2012
So I was able to read through about 50 of the 90 pages in this thread. I just picked up one of these things a couple weeks ago. What do you guys recommend for a small speed upgrade, maybe 100mph? From what I saw while reading it looked like 100a ESC and a 10x9 or 9x9 prop. Has anyone identified a good upgrade motor?
AWDstylez is offline Find More Posts by AWDstylez
Old Dec 27, 2012, 04:50 PM
mnavarro is online now
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
So I did my maiden today. I was underwhelmed by the speed/thrust. I like the power setup on my carbon-z yak 54, but felt the scimitar was almost underpowered. I experienced the take off jump to the ground but solved the problem once it was trimmed and it didn't do it again. Just make sure you stay on the elevator. Flat spins nice. Landings took a little bit to get them nice but the key is to come in slow. I was coming in too fast and the plane would like to bounce. Test how slow you can fly up high and bring it in slow, main gear first and it will be pretty easy.
I know I will be first trying this motor and seeing how it does on 6s and apc 9x9 prop with a 100 amp esc
mnavarro is online now Find More Posts by mnavarro
Old Dec 29, 2012, 03:44 PM
crashguru is offline
Find More Posts by crashguru
crashguru's Avatar
United States, NC, Wilson
Joined Mar 2005
I know I will be first trying this motor and seeing how it does on 6s and apc 9x9 prop with a 100 amp esc[/QUOTE]
Here is some information from my post from January 28, 2012 on this forum. I hope it helps. It was not smart of me to run it for so long on the ground without any airflow on the motor or ESC. However, it is still running fine after a full season (at least 30 flights or so - I have other planes). I like this setup as it seems faster and the vertical is unlimited as far as I can tell (I stop going up when I just about can't see it anymore). With this setup, it does not feel underpowered to me. I get pretty good flight times with throttle management (5-6minutes).
On 5s 3300 with CC ICE 100 ESC using APC 9x9E Prop:
Amps WOT - 69.5
Watts WOT - 1240
Stock Motor = about 180 degrees after several 10 second bursts of WOT (no airflow - sitting on the ground) - ambient temp - 60 degrees
crashguru is offline Find More Posts by crashguru
Old Dec 29, 2012, 04:12 PM
Joined Oct 2010
Good info. I wonder if the temperature you're seeing is much different than stock? Makes me think that 6s will fry motor with an apc 9x9. I have other motors that can handle it fine with same kv and are probably 120-130 mph.
Amps WOT - 69.5
Watts WOT - 1240
Stock Motor = about 180 degrees after several 10 second bursts of WOT (no airflow - sitting on the ground) - ambient temp - 60 degrees[/QUOTE]
Old Dec 30, 2012, 12:43 PM
bladeguy5 is offline
Find More Posts by bladeguy5
bladeguy5's Avatar
United States, MD, Waldorf
Joined Jun 2012
Few vids
12 28 2012 schimitar F1 (6 min 1 sec)
12 28 2012 schimitar F2 (1 min 54 sec)
12 28 2012 schimitar F3 (4 min 50 sec)
bladeguy5 is offline Find More Posts by bladeguy5
Old Dec 30, 2012, 12:58 PM
xviper is offline
Canada
Joined Jul 2009
Previous post fixed. This post no longer needed.
Old Dec 30, 2012, 05:31 PM
bladeguy5's Avatar
Joined Jun 2012
Thanks viper I just fixed the links
Old Dec 31, 2012, 03:58 PM
bladeguy5's Avatar
Joined Jun 2012
1 more flights from today
12 31 2012 schimitar F2 (4 min 56 sec)
