Old Dec 12, 2012, 09:41 AM
Tomster79 is offline
Find More Posts by Tomster79
Tomster79's Avatar
Germany, HE, Schöneck
Joined Dec 2012
Originally Posted by Fentonflyers View Post
The aileron mix with rudder is to compensate for the roll effect the rudder has when deflected far. It makes knife edge flight possible without a lot of compensation with the sticks. You might check the manual but I set all of my surfaces to zero mechanically.
Ok , then i trim my Surfaces mechanically , too ..
so i was right with the Roll Compensation during Rudder Deflection..
But i found another Mix in QuiQue´s Setup
RuD -> Flap
Rate 125
Rate 125
Sw: Mix0
For what is that Mix ?
LG Tom
Tomster79 is offline Find More Posts by Tomster79
Old Dec 12, 2012, 11:08 AM
Tomster79's Avatar
Joined Dec 2012
RuD -> Flap
Rate 125
Rate 125
Sw: Mix0
LG Tom
Hi,
Ok i understand now ,
Flap is Aux1 and so, it's the Mix for the VT
And i found 2 unamazing things :
1. Two Servos are faulty . During mixing of the VT , the VT Servo is stucking sometimes for a second.
And the left Elevon Servo has Freeplay.. More than all other Servos
When moving the Elevon , this can be feld..
And the Servo generates a sound when shaking the Elevon by hand..
2. During setting up the Servo travel and D/R Settings ,
I found the left Elevon travelling much more than the right one in both directions..
I now reduced the travel adjust to 80% !!
Is that normal ?
LG Tom
Old Dec 14, 2012, 01:47 AM
Tomster79's Avatar
Joined Dec 2012
Hello ,
Now i am on Page 51 of 88
I am using the Stock BNF AR600 RX..
Yesterday i solved the Problem with the Bind of the Nose Gear Linkage.
I reduced the Rudder Travel to 70% and set the Linakge of the Rudder Servos to the outer Hole of the Servo Arm to get still the High Rates..
Just waiting for an answer from my Shop because of the 2 faulty Servos..
Edit : I had to readjust the VT Servo Linkage, it was not trimmed correctly..
Greedings Thomas
Old Dec 15, 2012, 06:49 PM
Tomster79's Avatar
Joined Dec 2012
Hi,
Not so much Action here
At that Moment , i finished reading all 88 pages
I also watched serveral videos on youtube how to handle ( and not to handle )
the Scimitar during TO , approach and landing..
To use Rudders for bleeding off airspeed would be a nice option..
But i have the stock 6ch rx , so this is not possible for me
An AR8000 would this made possible ..
Does someone use bigger wheels on the retracts ?
Is it posible to adjust the Angle of Attack during taxi und rollout by shorten the nose Strut a little bit ?
Tom
Old Dec 17, 2012, 08:44 PM
RustySpork is online now
Find More Posts by RustySpork
United States, TX, Odessa
Joined Jun 2011
I used different wheels. They're DuBro... not sure which exactly but they're rubber, low bounce wheels that are bigger, and work great
RustySpork is online now Find More Posts by RustySpork
Old Dec 18, 2012, 01:52 AM
mnavarro is online now
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
Just picked one up from advantage hobby for 220 shipped! Good deal compared to what they used to be. I'm going to test it out stock and may on to 6s. I have a setup that works well on a sundowner 36 and a falcon 25 so I think it will work well on this too with a 9x9 prop at close to 16K rpm. I'm just not sure a 6s 3300 will fit until I can get into it. I might purchase this too: http://www.customrcparts.com/index.p...roducts_id=103
mnavarro is online now Find More Posts by mnavarro
Old Dec 18, 2012, 06:14 AM
Fentonflyers is online now
Find More Posts by Fentonflyers
Fentonflyers's Avatar
United States, MO, Fenton
Joined Jan 2012
6s 3300 ought to fit. Battery area is huge.
Fentonflyers is online now Find More Posts by Fentonflyers
Old Dec 18, 2012, 08:30 AM
Tomster79's Avatar
Joined Dec 2012
Hi,
So the thread is not yet dead
Today my prebent nose strut arrived..
So i will use a dremel today , to get flat spots on all three struts to tightly mount the axles..
Has someone tried different strut length on the Nosegear ?
Perhaps it´s possible to compensate the bounce effect during touchdown a little bit..
Tom
Old Dec 18, 2012, 09:06 AM
Joined Jan 2012
Hi,
Tom
Doesn't seem to help that much.
Old Dec 18, 2012, 12:17 PM
Tomster79's Avatar
Joined Dec 2012
Shure ?
I thought , the angle of Attack of the Scimi during Touchdown is one of the reasons to bounce back in the air due to an impulse of air stream to the lower side of the wing..
Tom
Old Dec 18, 2012, 09:03 PM
Joined Jan 2012
Shure ?
Tom
For me it is simply being just over stall speed to keep it from bouncing. It doesn't seem to start off as a bounce. It just rotates back up in the air unless it is too slow to fly. You have to have a pretty high angle of attack to get the speed way down. Simply said, shortening the nose gear from stock doesn't seem to help. It does make rotation when you want a bit troublesome. The Scimitar doesn't like to fly off the ground without a pretty good pull on the elevator. It will rotate and then fall back to the ground. When the angle of attack is nose down it just enhances this characteristic.
Old Dec 19, 2012, 09:47 AM
Tomster79's Avatar
Joined Dec 2012
Ok, so i installed my Struts now with the normal length..
I tightend the screws which attach the axle to the strut well now..
When i have my dremel back , i will install flat spots to the struts on the mounting points..
I´m still wondering , why e-flite has no optional prebent struts for the Scimi..
This was so easy with my P47 Thunderbolt an d the restracts..
Tom
Old Dec 19, 2012, 09:49 AM
Joined Jan 2012
Tom
http://www.horizonhobby.com/products...tar-EFL1018017
Old Dec 19, 2012, 10:24 AM
Tomster79's Avatar
Joined Dec 2012
This strut i have already installed..
I mean struts for the Main Gear , which were bent at the mount point for the wheels..
These are for the Thud :
http://www.google.de/imgres?imgurl=h...QEwAQ&dur=1595
I will try to use 2 stock Nose Gear Struts, which are already prebented , to install to the Maingear Servos..
Old Dec 19, 2012, 11:02 AM
Joined Jan 2012
I am not sure I understand. Are you trying to make a bend in the strut so it serves as an axle too?
