Old Sep 28, 2012, 08:22 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by ufale View Post
that hand aunch is one way to to motivate people to buy this plane . and to put a more powerful set up in it. although the plane looks draggy im sure with the right set up it can be pushed to at least 130mph . iff hand launched with a smaller props , thoughts anyone.
THESANDMAN is offline Find More Posts by THESANDMAN
Old Sep 30, 2012, 08:08 AM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
Nose in in stock. Maybe in a few more months the canopy will be too! One day she will fly again.
Josef086 is offline Find More Posts by Josef086
Old Sep 30, 2012, 09:28 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Got fed up with waiting all these months and just fixed it myself. Found a nose cone off another plane that fit perfectly over the existing bent up one. Horizon is not doing themselves any favors by taking so long to get parts. The Scimitar isn't the only product with this problem.
xviper is online now Find More Posts by xviper
Old Oct 03, 2012, 08:44 AM
RustySpork is offline
Find More Posts by RustySpork
United States, TX, Odessa
Joined Jun 2011
Another AWESOME flight yesterday! Took her up with a nano tech 4500 4s. Heavier than what I normally use, but with the position about 3/4 inch back I didn't even notice the extra weight. Flies GREAT! Just like a big stryker. Got some tumbles, tried for a flat spin a few times but that part isn't as easy as with the stryker. All in all I got about 5min of flight. Landing is so easy with the brakes set up. Only put 2600mah back in, gonna shoot for 6-7 minutes next time (today?)
RustySpork is offline Find More Posts by RustySpork
Old Oct 17, 2012, 04:30 PM
Joined Jun 2011
Bump? I've been out a few times over the past couple of days. Still using the 4500mah 4s. Getting up to 12 minutes, even with lots of full throttle.
Old Oct 20, 2012, 12:42 PM
BigEast is offline
Find More Posts by BigEast
Enjoying life through flight
Joined Mar 2012
Rusty, what is the behavior of the scimitar when you deploy brakes? Does it pitch up or pitch down? I've almost given up on the scimitar but I still have hope.
BigEast is offline Find More Posts by BigEast
Old Oct 20, 2012, 01:14 PM
robusp is online now
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
BigEast,
I have 2 settings for my brakes: light and extreme and both cause the plane to pitch up. I just simply mixed some elevator down with them.
It slows down so much I even elevator it vertically to land. Just once to try it. It is heavy plane especially with 5000mAh, but it worked.
Most of the time I use the brakes on final approach to bleed the speed, but I release them right above the ground to gain full rudder control.
Rob
robusp is online now Find More Posts by robusp
Old Oct 20, 2012, 02:25 PM
BigEast is offline
Joined Mar 2012
Originally Posted by robusp View Post
BigEast,
Rob
Thanks! What are your percentage values on the brakes and on the pitching up compensation? Mine are currently at 60% and 10% but I haven't tried it out yet.
Also, I 'm debating whether or not to take off of the 2 inch grass or hand launch.... My little wheelie bar on the tail skid helps but the prop still gets nicked...
Old Oct 20, 2012, 02:49 PM
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Your values might be different due to overall throw.
I say try it at different speeds (all except wot) and you'll know.
I am flying mine on APC 9x7.5 and have no problems with nicks.
Rob
Old Oct 20, 2012, 04:20 PM
BigEast is offline
Joined Mar 2012
Rob
Thanks again!
Old Oct 21, 2012, 10:56 AM
BigEast is offline
Joined Mar 2012
What's been the general success rate with grass/stock prop?
Old Oct 21, 2012, 11:03 AM
Canada
Joined Jul 2009
You mean taking off from grass? It works but the Scimitar becomes a lawn mower. Gravel runways are a complete prop destroyer. I'm still getting up the nerve to discus throw it.
Old Oct 21, 2012, 11:25 PM
pipertec is offline
Find More Posts by pipertec
Joined Jun 2008
Just bought one yesterday and got it put together today. Can't wait to fly it.....w/retracts!!!!
pipertec is offline Find More Posts by pipertec
Old Oct 22, 2012, 08:00 AM
BigEast is offline
Joined Mar 2012
You'll love it! It 's really a great plane. Add some speed brakes like I did and it will be able to land in relatively small spaces. Good luck!
Old Oct 22, 2012, 02:42 PM
Joined Jun 2011
BigEast,
Rob
Yep, everything Rob says is exactly as it is for me. Pitches up, not unmanageable without a mix but the mix will help. I would advise against doing maneuvers with them deployed, as it can get pretty slippery in turns, but they're perfect for bleeding off speed/altitude on your landing approach. I also release them before touchdown.
Good to see this thread a little active again!!
