Old Jan 27, 2012, 09:39 AM
pylot2b is offline
Find More Posts by pylot2b
Virginia Beach, Virginia, United States
Joined Jan 2004
Originally Posted by jhroof View Post
I would give them a call. I had a plane crash several years ago because of an elevator that came loose. They sent me a new plane at no charge. Of course they may want the old one back or what is left of it.
I just called horizon and they want me to send it in.
pylot2b is offline Find More Posts by pylot2b
Old Jan 27, 2012, 09:58 AM
brwilkins is offline
Find More Posts by brwilkins
No meat = no pudding
brwilkins's Avatar
Machesney Park, IL
Joined Jul 2008
Originally Posted by rcpilot23 View Post
Has anyone needed to balance the prop?
Mine seems to be well balanced.
Same here. Mine was perfectly balanced out of the box.
brwilkins is offline Find More Posts by brwilkins
Old Jan 27, 2012, 12:32 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Let me know what happens. I still haven't flown mine since the alarm went off.
jhroof is offline Find More Posts by jhroof
Old Jan 27, 2012, 12:50 PM
pylot2b is offline
Joined Jan 2004
I will. Not sure if they will be able to test it. ESC was yanked out and damaged.
Old Jan 28, 2012, 05:54 AM
rcpilot23 is offline
Find More Posts by rcpilot23
rcpilot23's Avatar
Perth, Western Australia
Joined Feb 2007
I have fitted the retracts using the supplied front strut.
Yes it works great thanks.
Ok so for the first flight should I have the stock lipo all the way pushed forward?
What is a good battery position?
rcpilot23 is offline Find More Posts by rcpilot23
Old Jan 28, 2012, 06:04 AM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
United States, FL, St Petersburg
Joined Jan 2011
i suppose it would vary based on rx and esc placement, but yes, my batt needs to be pushed all the way forward and she is still slightly nose heavy...
jdubg23 is offline Find More Posts by jdubg23
Old Jan 28, 2012, 06:09 AM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
i have to tm1000 and dx8 with the scimitar. tm1000 also on my hobby-lobby f18. i have had a few times on both planes where my min/max readings show below 4v for the rx. i have a seperate bec in f18, stock esc/bec in scimitar. so i dont know why my rx volts drops in both planes. im thinking it might be such a slight drop it only lasts for a millisiecond? i even dialed up the voltage on the ccbec to 6v instead of 5v. it still drops from time to time with no frame losses or holds?? and whats funny is i cant repeat this on the ground lol
Old Jan 28, 2012, 01:29 PM
crashguru is offline
Find More Posts by crashguru
crashguru's Avatar
United States, NC, Wilson
Joined Mar 2005
On 5s 3300 with CC ICE 100 ESC using APC 9x9E Prop
Amps WOT - 69.5
Watts WOT - 1240
Stock Motor = about 180 degrees after several 10 second bursts of WOT (no airflow - sitting on the ground) - ambient temp - 60 degrees
I can't find the specs on the motor, so the big question is - can it take it (longer than just my test)?
Inqiring minds want to know...
I'll fly it tomorrow to see what it does in the air.
Crash
crashguru is offline Find More Posts by crashguru
Old Jan 28, 2012, 02:54 PM
dbgood is offline
Find More Posts by dbgood
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Originally Posted by crashguru View Post
Amps WOT - 69.5
Watts WOT - 1240
Crash
Im running a 12x8,cut down to a 9x8,tips are alot wider
so i get alot higher amps,and watts.
i am happy about the speed and thrust now.
DB
dbgood is offline Find More Posts by dbgood
Old Jan 28, 2012, 03:00 PM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Scimitar speeds with 5s
Hi guys,
I wanted to report back to you all stock motor,
Ice 100,and a cut down apc 12x8E cut down to
a 9x8E ,with 5s 3300mah,
we got 2-104mph level passes with the radar
gun this afternoon..
Very happy with this setup..
I just wanted to break 100mph,and i did it today!!
Old Jan 28, 2012, 03:47 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Originally Posted by dbgood View Post
Hi guys,
Im liking the apc 9x9 dont have a radar but i will try to doppler tomorrow
how many amps with your 9x8 ?
hotdog1 is offline Find More Posts by hotdog1
Old Jan 28, 2012, 04:48 PM
rcpilot23's Avatar
Joined Feb 2007
Hi guys,
That's great news. Im yet to maiden my Scimitar but I have a 5S 3300 lipo and 100 Amp speedy and APC 12x8E (which I will cut down to the 9x8E) ready to fit. Was that speed with retracts fitted and up?
I also seem to have found another issue. When the retracts are up and the rudder ATV are at 100% the nose wheel push rod bends because the nose wheel servo is travelling too far but only when turning left. I had to reduce the rudder atv down to 62% to stop it. It still had plenty of rudder movement but is that normal?
I have found the info regarding the nose wheel pushrod issue. I can't believe Horizon have released this plane and not tested it with retracts fitted and seen the nose wheel pushrod binding. The video shows them flying with the retracts.
Old Jan 28, 2012, 05:02 PM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Just looked at the datalogging on the ICE 100,long
speed runs 83-84 amps,1400 plus watts,and RPM's 13000!
Cool in upstate Ny temps were 41 when flying..
DB
Old Jan 28, 2012, 05:05 PM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
No i dont have the retracts for it yet,just fixed gear..
when i do order them and put them on, should be good for 109-110mph flat!
Old Jan 28, 2012, 05:45 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Crash
Hi Crash,
As long as you can collect data quickly, I strongly suggest you keep your static tests to maybe 4 seconds.
Collecting quickly by memorizing what you see on wattmeter, or video of wattmeter screen, or ICE ESC, or Eagle tree data logger
180 degrees is just too hot.
If you want to do repeated tests, then allow motor to get back to room temp in between your static tests.
With data loggers I stay closer to 3 seconds.....WOW, multiple 10 second runs was way tooooo long.
I'm glad you didn't burn motor. Hopefully the KV is not raised some because of your magnets having become a little weaker due to overheat.
Enjoy your 5S flights.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
