Old Jan 25, 2012, 07:01 AM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
United States, FL, St Petersburg
Joined Jan 2011
Originally Posted by n411x View Post
Has anyone been able to preform the spinning top ie the very fast flat spin that is on the advertisement video ????
i have done it a couple times.... havent been able to repeat the stick movements though, you have to hold a little elevator i think...
jdubg23 is offline Find More Posts by jdubg23
Old Jan 25, 2012, 06:10 PM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
when you really get it goin it almost maintains altitude in the spin
Old Jan 26, 2012, 12:45 AM
dbgood is offline
Find More Posts by dbgood
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Retracts
Hey guys,
Do you think i can put the eflite retract 15-25 size on my Scimitar that i
have lying around?
I know they call for the 10-15 size,seems like the only difference
is the strut size goes 3mm to 3.5 for the 15-25 series.
Bending the nose strut looks like a pain to fit it in the wheel opening.
Weight also looks about the same as on the horizonhobby site.
Maybe i can put the 15-25 on it soon..
Let me know what you think,
thanks guys,
Dan
DB
dbgood is offline Find More Posts by dbgood
Old Jan 26, 2012, 06:01 AM
rcpilot23 is offline
Find More Posts by rcpilot23
rcpilot23's Avatar
Perth, Western Australia
Joined Feb 2007
Got my scimitar today with the eflite retracts
just found out I need to buy the scimitar front retract strut. EFL1018017
Do I have to use the optional scimitar front strut?
rcpilot23 is offline Find More Posts by rcpilot23
Old Jan 26, 2012, 07:36 AM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
the only difference in the struts is the scimitar strut is "bent" you can easily bend the strut that is included with the retracts and save $5
Old Jan 26, 2012, 11:29 AM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
I concur. I was disappointed in the EFL1018017. It is easy to cut down the strut that comes with the retract set and bend your own custom strut.
If the EFL1018017 had the "flats" cut into it for mounting the wheel axle, then it might be worth it, as the flats need to be accurately cut. Honestly, I don't know why Horizon bothered. The EFL1018017 I bought didn't even line up the wheel correctly, it was tilted!
Nick
nioa is offline Find More Posts by nioa
Old Jan 26, 2012, 03:22 PM
rcpilot23's Avatar
Joined Feb 2007
Ok thanks guys for the info.
Turns out that the strut is not even in stock in australia anyway.
So problem solved thanks.
Just need to get a day here in Perth that is not 42 degrees C so I can fly it.
Old Jan 26, 2012, 05:24 PM
crashguru is online now
Find More Posts by crashguru
crashguru's Avatar
United States, NC, Wilson
Joined Mar 2005
Nick
I think it was tilted to clear the steering pushrod when in the retracted position. It was tilted way too far in my opinion. it looked silly when it was in the down position. I ended up taking the regular retract strut, bending it and cutting it straight. It works like a charm and just misses the steering pushrod. Don't bother buying the special strut!
crashguru is online now Find More Posts by crashguru
Old Jan 26, 2012, 05:46 PM
pylot2b is offline
Find More Posts by pylot2b
Virginia Beach, Virginia, United States
Joined Jan 2004
I agree. I modified the stock strut bent a 45 and used a dremel to grind the flats and trim off the extra length. It lasted one flight when mine crashed on it's maiden. I think I am one and done on this plane. Too expensive to replace an airframe. I had high hopes for this plane! Still not sure what happened to mine.
I will probably sell the spare parts. Motor and a few of the servos are still good. Wings seem to be fine.
pylot2b is offline Find More Posts by pylot2b
Old Jan 26, 2012, 07:42 PM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
unless im mistaken you can get all new foam parts for under $150... if you already got 320-400 into it might as well fix it for 150
Old Jan 26, 2012, 08:07 PM
pylot2b is offline
Joined Jan 2004
I priced it about $180 plus a few servos and 2 retracts. Well over $200. Not sure if I am going to get back on this horse. Maybe in time. But to watch $550 snap spin violently from 200' into the ground will be hard to recover from!
Old Jan 27, 2012, 08:49 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
I have telemetry setup on my Scimitar. The other day I was flying it and the alarm started going off. I landed without problems and found it was the Rx voltage alarm that was sounding. The voltage was reading 4.2. The alarm is set at 4.8. The voltage dropped when I increased the throttle. This was a good battery with a fresh charge and the voltage on the battery was way above the alarm voltage. I haven't had time to recheck everything with a voltmeter just to verify. Is it possible some of these ESC's may have a bad BEC circuit? I could go with a separate BEC, but I don't know if I trust the ESC. I have telemetry setup on other planes and I have never had the Rx voltage alarm go off.
jhroof is offline Find More Posts by jhroof
Old Jan 27, 2012, 08:57 AM
pylot2b is offline
Joined Jan 2004
Very interesting find! Wondering if that's what happened to mine. I can't go back and check because the ESC was damaged in the crash. Wondering if I have cause enough to call Horizon about it.
Old Jan 27, 2012, 09:12 AM
jhroof is offline
Orlando, Fl
I would give them a call. I had a plane crash several years ago because of an elevator that came loose. They sent me a new plane at no charge. Of course they may want the old one back or what is left of it.
Old Jan 27, 2012, 09:23 AM
rcpilot23's Avatar
Joined Feb 2007
Has anyone needed to balance the prop?
Mine seems to be well balanced.
