Old Aug 18, 2011, 04:27 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
I see that this plane uses the same servos as the troubled Carbon Z Yak 54 which had numerous reports of crashes because of these servos failing.
Has this been addressed?
cjbucher is offline Find More Posts by cjbucher
Old Aug 18, 2011, 04:31 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
Looks awesome, and definitely a unique plane. Wonder why it wasn't designed with 2 axis thrust vectoring though.
Figuring out the cost in my mind through, $320 for a PNP(have plenty of lipos and a spare RX), $120 for retracts, and $100 for 4 x HS-85MGs $540 is kinda steep for a reliable PNP with retracts, although if it flies well, might be worth it. Out of the 2 dozen or so EFLR7140s and DSV130M(all failures on servos made within a year, the same servos from older models have held up without a problem)s that came with my planes, I've had about 8 fail, and cause 2 crashes, one was a total loss of a CZ Yak, I don't trust them at all, hopefully the larger 7145 mini servo this has doesn't have that problem, and I'll risk the servo on the nosewheel.
alucard0822 is offline Find More Posts by alucard0822
Old Aug 18, 2011, 04:39 PM
AggressorBLUE is offline
Find More Posts by AggressorBLUE
Park Stormer
United States, NJ, Brooklawn
Joined Jul 2008
Originally Posted by slyfoxflyer66 View Post
What does that on/off switch in the air cooling picture do?
Just throwing this out there: Maybe it turns the plane on
anyway,
It's neat, but too rich for my blood in it's current state. I'd happily plunk down $120 for an airframe only option though. Namely because I can't comment on e-flight/Parkzone servo quality once you move up to these applications, but I have had an excellent service record with Hitec servos. In this price rage, I'd prefer to "go with what I know." Same applies to motors, ESCs, and retracts.
I'd also personally delete the TV on mine, as that feature sits outside my skill level. (Bet you could pull some crazy knife edges though)
as an aside, to me it looks great from every angle but one: side profile.
Those under-wing rudder...things, look out of place. I think if they matched the taper of the top rudder, they'd look less gawky.
AggressorBLUE is offline Find More Posts by AggressorBLUE
Old Aug 18, 2011, 05:26 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
I think she looks like a PIG on the side view!! lol When i was looking through all the pictures,i was like!! Awwww, Ewwwwwww,Niccceeeee!!!
Then seen that one and ran out the room lol...
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Aug 18, 2011, 05:44 PM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
What an ugly plane , another non seller
scousethief is online now Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Aug 18, 2011, 05:47 PM
slyfoxflyer66 is offline
Find More Posts by slyfoxflyer66
You torquing to me?
slyfoxflyer66's Avatar
Vancouver, WA
Joined Mar 2010
go back under your bridge.
But why add a switch for that? neither PZ or E-flite has done that in the past.
slyfoxflyer66 is offline Find More Posts by slyfoxflyer66
Old Aug 18, 2011, 06:10 PM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
The new E-Flite ESCs come with that ON/OFF switch pre-soldered. So they just moved it to the side for easy access.
Dude I totally agree! Those fins on the bottom are enormous and damn ugly. They must be extremely important for flight characteristics because otherwise they just make the plane look really ugly from that angle. I always assumed these bottom fins on the Stryker were just designed for protection on landings. But if you are going to be using the landing gear on this plane, maybe you can cut them down a little bit to make it look better...unless they are designed for flight characteristics.
sickwitit is offline Find More Posts by sickwitit
Old Aug 18, 2011, 06:59 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
I'd say they are Designed for drag(SFG) They have to be at that size. They incorporated quite abit from the SQ. If they were cut in half and was attached too the landing gear main arm would of looked cool.
Then when LG is up, act as a cover!!
They'll soon have some Vid's i would imagine. Is this the only Thread around on this Plane?
Chucky does it again...
Well be interesting to see some videos for sure.
Old Aug 18, 2011, 07:33 PM
Seeya is offline
Find More Posts by Seeya
Aircraftus Fragmentum
United States, IL, Naperville
Joined Nov 2009
F-27Q has one
Seeya is offline Find More Posts by Seeya
Old Aug 18, 2011, 07:48 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Originally Posted by Seeya View Post
F-27Q has one
Mine came off the ESC pretty easy, I CA'd it back on. But i was thinking of filling out a small square from the Forward side if the Plastic housing.. Its easy to get at on the ESC but would be better mounted on the inside of the Plastic. Hmm may do that tomorrow!!
slyfoxflyer66 the 40A esc comes with a On/Off Switch
http://www.e-fliterc.com/Products/De...rodID=EFLA1040
Old Aug 18, 2011, 07:55 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
The 60 amp E-flite come with an on/off switch that's what you see. It's just molded into the foam.
I really like this one. The Q will be for warm up on 3s and this one will be for wild 4 or even 5s. It's a definite must have for me.
kuczy is offline Find More Posts by kuczy
Old Aug 18, 2011, 08:17 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
A local friend has thrust vectoring on his stryker 27C, he made a custom mount, and the motor moves from center and goes either up or down, let's just say it does some wild flips.
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Aug 18, 2011, 09:04 PM
Fyrcap59 is offline
Find More Posts by Fyrcap59
"Oh the humanity!"
Fyrcap59's Avatar
Clovis California
Joined Aug 2006
As I sit here looking at my Stryker Q I feel like one of those people in that TV commercial. "BUT, I JUST BOUGHT THIS!" "SON OF A.....!"
Fyrcap59 is offline Find More Posts by Fyrcap59
Old Aug 18, 2011, 09:05 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Carbon Z
What is Carbon-Z technology? (12 min 46 sec)
Thank you Dave Eichstedt for providing this link earlier today.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Aug 18, 2011, 09:19 PM
SmartMartY is offline
Find More Posts by SmartMartY
York, England
Joined Jan 2010
Yea id pay that for it if the re tracks were stock... $500 bones time the re track are bought... PASSSS....
Looks nice though!! lol
+1 here mate. Nice bird but too rich for me, even more so in 's, unless it's twice as good as the Q (which I doubt)
SmartMartY is offline Find More Posts by SmartMartY
