http://www.horizonhobby.co.uk/aeroon..._eflm7400.html look under the specs motor size http://www.horizonhobby.com/products...r-pnp-EFL10175 |
Mahomet, Illinois
Joined Aug 2007
http://www.horizonhobby.com/products...r-pnp-EFL10180 I will let the web team know. Page 3 of the manual correctly lists the motor as 1010 Kv, as well as the product page on horizonhobby.com for the replacement motor: http://www.horizonhobby.com/products...010kv-EFLM7400 Since you're referencing the hh.co.uk website, I take it you're in the UK? My department represents the source of the information - product development. The information you received is downstream of that source, whether it was consumer sales in the US or anybody at Horizon UK. If there is a typo on the web that we didn't catch, then that is the information the people you talked to will have and they will not know any better. So I repeat, the Scimitar motor is 1010 Kv, not 1150. The information stating 1150 is incorrect. |
I had 2 flights again yesterday (partially cloudy) before sunset with my back toward the sun and again experienced very minor instances where I couldn't tell plane direction on turns. Hopefully additional design and color will help. I also believe it might just be just because of the plane shape (having three sides looking very similar). |
I did a static run with a 5S 3000 40C battery today. The numbers are: 1420 watts, 68 amps
I am planning on swapping the ESC out with a 70 amp Hacker so that I don't fry the stock one. A flight report will be posted in a few days after I fly it. Should be a little rocket ship then!
Thank you for the data. We can easily give you an approximate idea of speed increase. Needed info (besides data from your post above): A) Stock 4S Watts? B) Stock 4S speed? ( I assume near 80 MPH???) *** Hopefully others will reiterate their measurements. _______ Mean while, don't plan on over 15 MPH speed increase. Gryphon |
