Old Feb 14, 2013, 06:21 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
crashguru,
Sometimes people run a test and read the Wattmeter's displayed results (such as Wattsupmeter) after the test...for peak Watts, Peak AMPs, and minimum voltage.
As you may already know that is somewhat misleading.....but better than nothing.
In cases like this people should raise the throttle gradually in order to minimize the peak AMP "Spike" (due to motor spool up) as measured by a Wattmeter.
ICE ESC's logged data often shows the AMPs a little higher than actual but it is still one hell of great tool.....Way better than a Wattmeter.
I usually go about 1 second (or a bit more) after the peak AMP spike and take my measurements.
For testing people should consider setting the logger to 10 samples per second.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 15, 2013, 05:01 AM
AWDstylez is offline
Find More Posts by AWDstylez
Joined Aug 2012
Originally Posted by crashguru View Post
Wow! 98 amps? The Amps x Volts = Watts formula does not seem to work.
Here are my static results with the stock motor and pretty much the same setup:
On 5s 3300 with CC ICE 100 ESC using APC 9x9E Prop:
Amps WOT - 69.5
Watts WOT - 1240
Crash
I can post the logs if you want. It pulls 59amps bone stock, only a ten amp increase seems small when jumping to 5s. Someone earlier in the thread had almost identical numbers to mine, but you're right the math doesn't work out unless there's huge voltage sag.
AWDstylez is offline Find More Posts by AWDstylez
Old Feb 15, 2013, 03:25 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Turbine Scimitar Thread:
http://www.rctodayshow.com/forum/vie...6&p=2259#p2259
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Feb 17, 2013, 02:55 AM
windsheer is offline
Find More Posts by windsheer
Joined Feb 2007
Just got mine in today Pnp. Only took maybe an hour to get it ready. Hope to fly it Tuesday. It's fixed gear for now. I'll go retracts if I like it. I used 8 channels. Gear(fixed for now)2 rudder, TV, and nose stearing. She's a good looking bird.
windsheer is offline Find More Posts by windsheer
Old Feb 17, 2013, 03:24 AM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Great way to set it up. Hope your maiden goes as well as mine did. Use a lot of up trim before you take off. You can always trim back down, but the first take off is a lot different than most other planes. Use tons of expo on the steering, she's real sensitive.
Good luck pilot windsheer.
Garry K.
garryk is online now Find More Posts by garryk
Old Feb 18, 2013, 09:26 AM
USA, GA, Atlanta
Joined Nov 2008
+1 to what garry said.
Do not let up on the up-elevator, till you have a good bit of air under you and get her trimmed out.
Old Feb 18, 2013, 10:33 AM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
I bought 2, totaled one when I lost orientation. It was circling sweet and calmly for a few minutes. After trimming I decided to do a loop and it rolled to one side (can't remember -top and bottom are a mix of red, black, and white). I ended inverted, panicked, pulled another loop and yet again it rolled so I panicked again and nosed into the ground.
Anybody mod it to help with orientation? Maybe paint the underside completely black?
voxel is offline Find More Posts by voxel
Old Feb 18, 2013, 11:03 AM
Blucross is offline
Find More Posts by Blucross
Gravity is a cruel mistress...
Blucross's Avatar
United States, FL, Orlando
Joined Mar 2011
I used some 2" strips of yellow and black Zagi tape from Graves to make stripes on the bottom of mine. No more orientation issues and its completely removable. plus the tape gives a little extra strength and abrasion resistance.
Blucross is offline Find More Posts by Blucross
Old Feb 19, 2013, 02:45 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Rainy day here, so I put together my PNP Scimitar today.
Should I bother with the stock prop or upgrade to an APC?
Also, I downloaded the DX8 setup from the Spektrum community website. Everything works perfect, but, I am wondering about elevon movement when applying rudder. If I use full right rudder, I notice the right elevon moves down. Left rudder=left elevon down. Is this differential?
wavekatcher is offline Find More Posts by wavekatcher
Old Feb 19, 2013, 02:52 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Nothing wrong with the stock prop. Use it. If your runway is gravel or grass, it'll get chewed up quick enough. Then you can try another prop.
I didn't like the rudder to elevon mix. I took it out. You should try it to see if you like it.
xviper is online now Find More Posts by xviper
Old Feb 19, 2013, 02:53 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
It's a mix to help during knife edge.
jhroof is offline Find More Posts by jhroof
Old Feb 19, 2013, 04:02 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Not having any disorientation issues at all...the model is mostly red on top and mostly black and white on the bottom. Plenty of differentiation for me.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Feb 19, 2013, 10:06 PM
splais is offline
Find More Posts by splais
Yuma, AZ
Joined Oct 2003
Alternate props
I have read through many pages of this thread and can't find any comments on what prop, other than the stock one, works best on a stock motor and esc. Can anyone help? Looking for an apc substitute for the stock prop. My Scimitar is not yet hear yet, but I'm getting ready. Thanks.
splais is offline Find More Posts by splais
Old Feb 19, 2013, 10:14 PM
Canada
Joined Jul 2009
I've switched to these lately. Seems to work fine and they are much cheaper and easier to get than the stock prop.
http://www.hobbyking.com/hobbyking/s...idProduct=5365
Old Feb 19, 2013, 10:58 PM
Doodie is offline
Find More Posts by Doodie
Un Registered User
Doodie's Avatar
Canada, BC, Chilliwack
Joined Feb 2013
Now that looks sick!
Doodie is offline Find More Posts by Doodie
