Old Feb 04, 2013, 05:51 PM
bladeguy5 is offline
Find More Posts by bladeguy5
bladeguy5's Avatar
United States, MD, Waldorf
Joined Jun 2012
Gotta watch out tho certain parts like the ruder fins have never been in stock
bladeguy5 is offline Find More Posts by bladeguy5
Old Feb 04, 2013, 05:53 PM
bladeguy5's Avatar
Joined Jun 2012
delete
Old Feb 04, 2013, 07:26 PM
AWDstylez is offline
Find More Posts by AWDstylez
Joined Aug 2012
A 7x6 would barely have enough thrust to get the plane off the ground.
AWDstylez is offline Find More Posts by AWDstylez
Old Feb 04, 2013, 07:51 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
You're going from a 10X8 to a 7X6 prop. Unless you can spin that thing 3 to 4 times faster, it's going nowhere. Will it even taxi on lumpy grass?
xviper is online now Find More Posts by xviper
Old Feb 04, 2013, 10:05 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Build this bad boy up. Rather simple and straight forward. Seems well designed and good quality which we would expect from HH.
Used a orange 6ch and a satellite I had laying around. Downloaded QQ dx8 file and changed a few settings. Set the d/r and the TV to the F-stop using n,1 & 2, going to treat this like my helis and idle up/stunt mode.
I dumped the ec3 extension harness and direct soldered. I removed the optional retract extensions. I always place heat shrink over my connection points where extensions are used. Going to balance the prop tomorrow, I stuck it on my balancer its she's off. Also going to throw some tape on my leading edges tomorrow.
Diesel6401 is offline Find More Posts by Diesel6401
Old Feb 04, 2013, 10:46 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Manual CG OK fellas?
Unfortunately all I have is a 4s 3200 20c laying around :thumbdown:
I need to grab some better packs ASAP!
Old Feb 04, 2013, 10:59 PM
Fentonflyers is online now
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Probably would put that pretty far toward the front. I have Turnigy 30c 3300's and a 3600 that I use. I usually line them up with the seam between the fuse and the nose.
Be carefull with that thing too close to the garbage can. That could be some bad Karma
Fentonflyers is online now Find More Posts by Fentonflyers
Old Feb 04, 2013, 11:13 PM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Originally Posted by Fentonflyers View Post
It's pretty easy to land on grass. Paved runways are a lot tougher. Add wind and or cross wind and it can be challenging...
Are you (incorrectly) assuming I am landing in grass?
Garry K.
garryk is online now Find More Posts by garryk
Old Feb 05, 2013, 04:58 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Hey D. You got one of these too huh?
I wound up putting a 4000 ma pack in mine (shoved all the way forward) to get it to balance at the suggested CG.
Maidened it Sunday (no video though) and it flew well at the 560 mm mark. I forgot to switch to low rate on the rudder and a steering correction on landing wound up testing the built in wingtip skids. They work well with no damage done.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Feb 05, 2013, 04:59 AM
Joined Aug 2012
That's going to go as far forward as you can. I've got the stock battery full forward and a 65c 3300 5s at the nose attachment point and those balance at the front of the recommended cg.
Old Feb 05, 2013, 05:38 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I haven't really scanned through this thread (just went looking to see if there was one this morning). You can run 5s with the stock esc/motor'prop setup?
Old Feb 05, 2013, 07:00 AM
Joined Aug 2012
Definitely not. I'm running an ICE 100. It pulls 98amps and 1600w continuous on the bench with an APC 9x9e. I'm not sure how long the stock motor will last once the weather warms up.
Old Feb 05, 2013, 08:15 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
He buddy. Yea picked one up in the sale. Haven't maidened it yet. Glad to know the tip skids work good lol... Thanks for the info.
Old Feb 05, 2013, 09:07 AM
Corsair Captain
Joined Oct 2010
Finally uploaded my maiden landing. Took a lot of expo out of it for a more linear elevator and every landing since has been great.
20130201 113747 (1 min 33 sec)
Garry K.
Old Feb 05, 2013, 09:20 AM
Corsair Captain
Joined Oct 2010
I know it's in reverse order, and for some reason the quality sucks, but you can tell from the comments that the up trim should have been put in about 5 clicks to have a smoother take off. As soon as I relaxed the up elevator after rotation, she wanted to go right back down.
20130201 113145 (1 min 15 sec)
Garry K.
