Old Aug 17, 2011, 07:59 PM
TruSpeed is offline
Find More Posts by TruSpeed
United States, TN, Franklin
Joined Jul 2011
When to and How to use mixing control with DX6i
I think the title says it all. I have the Dynam A10 4 channel plane. Will I benefit from using the mixing control?
TruSpeed is offline Find More Posts by TruSpeed
Old Aug 17, 2011, 08:31 PM
H2SO4 is offline
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
The ability to mix one channel into another is simply a tool. Most 4ch planes can fly with no mixing at all, but judicious use of the transmitter's mixing capabilities can potentially make the pilot's life easier, more interesting, more entertaining, or all of the above.
The details are almost always plane-specific, and as such your question would probably be answered with more authority on a "Dynam A10" thread where it's most likely to get attention from a bunch of people who are very familiar with the airframe and its idiosyncracies. If such a thread doesn't exist (I don't know), you might wish to consider starting one.
H2SO4 is offline Find More Posts by H2SO4
Old Aug 18, 2011, 03:38 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Here's a couple of possible mixes, but as H2SO4 said, it depends on the plane.
Mix rudder in with aileron, to give slightly smoother flatter 'coordinated' turns. But you should be using both sticks to fly well anyway.
Mix elevator in with throttle, can be useful on ducted fan models where the thrust line cannot be adjusted, and the trim changes with max throttle. But there is nothing to stop you using the elevator trim anyway.
When it comes to precision aerobatics, (and the right sort of model), then there are other mixes that can be helpful.
eflightray is online now Find More Posts by eflightray
Old Jun 14, 2012, 01:58 PM
appa609 is offline
Find More Posts by appa609
made of foam
appa609's Avatar
Ontario, Canada.
Joined Aug 2008
I like using elevon mix for aerobatic planes. I don't know about an A-10.
Flaperons are always helpful.
appa609 is offline Find More Posts by appa609
Old Jun 18, 2012, 02:32 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
If you must ask the answer is absolutely NOT... Now, after you get some stick time and have an idea what's happening then maybe....
rtbates is offline Find More Posts by rtbates
Old Jun 18, 2012, 02:45 PM
helifreak1 is offline
Find More Posts by helifreak1
Joined Jan 2012
RE: Mixing
THe most common mixing is of course rudder + aileron. The main reason for the mix is because it does make the take off a little easier for some.
1) Using the rudder to steer as you are taxing to take off, the ailerons do help a bit on the steering part
2) some do a better job steering as they take off using ailerons
He is an example: A friend of mine uses that mix as he is taking off.As he gets off the ground i've seen him stugle with getting it under control.If you are lifting off the ground and still using the rudder to steer it straight the plane will bank and in most cases crash. By using the aileron mix he is able to steer and keep the plane in complete control while lifting off the ground
helifreak1 is offline Find More Posts by helifreak1
Old Jun 18, 2012, 05:59 PM
H2SO4 is offline
H2SO4's Avatar
Joined Jan 2011
I understand why mixing in a bit of rudder with the ailerons can be used to effect "coordinated" turns once the plane is well and truly up in the air, thus gaining the ability to bank, but I don't understand why ailerons would be of any help on the ground.
While taxiing, wheels are presumably remaining on the ground during turns, unless you get a little wild
Why would the ailerons have any positive effect on turning ability before the plane is high enough to roll? Given the slow speeds, the amount of aileron would presumably have to be massive to produce any effect at all. Wouldn't the added drag just hamper smooth rudder turns on the ground?
Old Jun 19, 2012, 12:30 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I would go so far as to say his statement is flat out incorrect. I've been doing this many years and the most common mix I've seen in use is Ailerons->Rudder. That is, moving the ailerons causes the rudder to move (in the same direction). Rudder->Aileron mixing is almost never used. The second most common things I've seen is Throttle->elevator which is common on motor gliders - we don't want to trim the elevator permanently because we want to maintain the proper trim for gliding, but when the plane is under power it can have a strong tendency to pull up and stall, so we mix a little down elevator with the throttle.
Flaperons and delta mixing is a permanent setup which the plane would always need, so it's not a mix that you would put on a control switch. If the plane is a flaperon or delta type, it doesn't change, as that's a property of the airframe itself and if the plane needs that type of control, it is always needed.
jasmine2501 is offline Find More Posts by jasmine2501
Old Jun 19, 2012, 03:56 PM
ArneHu is offline
Find More Posts by ArneHu
Balsa Builder. With some foam.
ArneHu's Avatar
Eastern Norway Scandinavia
Joined Dec 2009
I think its fun to experiment with mixes. But I didn't start playing with mixes before after flying for some time. On some fast gliders, spoilerons can be useful. When you want to land it in front of you, and not float the whole field.
ArneHu is offline Find More Posts by ArneHu
Old Jun 19, 2012, 06:33 PM
H2SO4 is offline
H2SO4's Avatar
Joined Jan 2011
My understanding of helifreak1's post is that he's mixing aileron into rudder input (the option you described as "almost never used"), in order to have the ailerons somehow help with the rudder's directional control on the ground.
I'm not saying it's incorrect. I just don't understand the mechanics of why it would work, and I was hoping that helifreak1 or someone else would explain.
Old Jun 21, 2012, 09:14 AM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
This might be true if the plane has a 1:1 or more thrust/weight ratio and the motor is nearly WOT but your average powered scale plane won't have enough airflow over the ailerons at takeoff (or landing) to make them effective.
If the plane is banking at takeoff your friend needs more finesse. Even short takeoffs can be done smoothly without mixing. What I would do is stop using the rudder while the plane is in transition from steering with the wheel to steering with the rudder. Once the wheels are off the ground then make small corrections with the rudder until enough airflow is over the wings to make the ailerons effective.
The wings do drop a little when the rudder is used. Too much deflection at a slow speed will result in a wing dropping a lot and if you are barely off the ground a crash is likely. Using the ailerons to prevent the inside wing from dropping only works if there is a lot of airflow over the ailerons.
GooberSB is offline Find More Posts by GooberSB
Discussion Help with Mixing my DX6i DLuXXX Electric Plane Talk 2 Jun 28, 2011 11:59 PM
Help! How do use LP5DSM for Elevon/taileron mixing? Razors edge 29 Radios 16 Jun 07, 2011 02:12 PM
Question DX6i, mixed to control tank-like motors with single stick? marhar Beginner Training Area (Aircraft-Electric) 3 May 16, 2011 12:01 AM
Question Brand new DX6i won't allow use of differential when in Elevon mode??? kctrading Radios 14 May 05, 2008 08:43 AM
How good is GWS gearbox when use with brushless motor hty GWS (Grand Wing Servo) 32 Apr 04, 2005 01:27 PM
