Old Aug 17, 2011, 04:10 PM
Gamerjoe is offline
Find More Posts by Gamerjoe
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
Spektrum Transmitter Toggle Switches
I have a Spektrum DX5e transmitter that has a broken toggle switch for the landing gear. All Spektrum Tx's have these switches and I am wondering if these are something standard I can get at Radio Shack and just solder into the TX?
Gamerjoe is offline Find More Posts by Gamerjoe
Old Aug 17, 2011, 04:57 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Yes, they are usually just standard miniature toggle switches and you should be able to find one at Radio Shack. Just measure the diameter of the threaded collar so you get the right size to fit the hole. Most likely just a SPST switch with just two wires, but best to open it up and check first.
jeffs555 is offline Find More Posts by jeffs555
Old Aug 17, 2011, 05:27 PM
Gamerjoe is offline
Gamerjoe's Avatar
Joined Jul 2011
Great, thanks!
I assumed as much, but it is good to hear from someone that knows.
Old Aug 18, 2011, 03:23 PM
phil_g is online now
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
I recently bought a used DX5e which had a broken trainer switch. I emailed Horizon and they sent me two free of charge by return.
Cheers
Phil
phil_g is online now Find More Posts by phil_g
Old Nov 21, 2011, 10:01 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Cheers
Phil
I emailed them and they told me to send it in for $30 per hour. Otherwise I am happy with the service
Rickflaguy is offline Find More Posts by Rickflaguy
Old Nov 22, 2011, 03:28 AM
phil_g's Avatar
Joined Jul 2007
I said could they supply a switch please, and that I was happy to fit it myself. Two switches arrived by return with a compliments slip.
Cheers
Phil
Old Nov 22, 2011, 10:11 PM
Joined May 2011
Cheers
Phil
No reply yet. I emailed them and that may be why I got the reply I did. I will try a call
Old Nov 23, 2011, 04:30 AM
phil_g's Avatar
Joined Jul 2007
I'm in the UK, maybe its a US policy not to allow customers to repair their own. But jeez, its only a switch and two wires. We used to build the whole radio when I were a lad.
Attached is the email chain just fyi
Cheers
Phil
Old Nov 27, 2011, 07:34 PM
Joined May 2011
Horizon Hobby's reply
Hello Rick,
Thank you for contacting Horizon Hobby's Product Support Department.
All transmitters and receivers are service center items only not for consumer sales, unless listed under the products website. This will need to come into the service center for repair. Please see my previous email for instructions on how to send the transmitter into the service center.
For further assistance, please use the URL located on our website's Contact Us page. If you are referencing a past request, please include the following ticket number when prompted: 15,069
Don't forget, our phone staff is available at 1-877-504-0233, Monday through Friday, 8am-7pm CST, Saturday 8-5pm CST and Sunday Noon-5PM CST.
Thank you,
Marc
We help YOU have fun with Hobbies!
Horizon Hobby Product Support
4105 Fieldstone Rd.
Champaign, IL 61822
1-877-504-0233
Old Nov 27, 2011, 07:39 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Based on other posts on here, that seems to be the standard response from them lately .Try here:
http://www.radiosouthrc.com/thumbnail.asp?cid=101
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 27, 2011, 07:50 PM
phil_g's Avatar
Joined Jul 2007
They dont trust you to change a switch? as I said, when I were a lad you'd build the entire radio in your shed. What a pathetic level we've fallen to. How far down can we be dumbed? thankfully it seems some sense of reason prevails at HH UK...
Cheers
Phil
Old Nov 27, 2011, 07:57 PM
Joined May 2011
I think Horizon wants to get some cash from the used tx buyer.
Old Mar 20, 2012, 03:23 PM
jojo3989 is offline
Find More Posts by jojo3989
Joined Mar 2012
New hobbyist here with two broken toggle switches on my DX5e (Trainer momentary switch and the Channel 5 switch). Spektrum would not send replacement switches and the total repair cost (+ freight) is more $$ than a new radio. Bought some switches from Radio Shack. They sell SPST and SPDT.
The SPDT switches have the same three prongs as the original ones in the DX5E, but I notice that there are only two wires being connected to the original switches (the third is left unused). Questions:
1) Does this mean that I can use SPST replacement switches (they have only two prongs)?
2) If I replace them with SPDT switches, how do I know which two prongs to solder the two wires to?
3) In either case (SPST or SPDT) which wire goes to which prong?
Thanks!
jojo3989 is offline Find More Posts by jojo3989
Old Mar 20, 2012, 05:57 PM
Gamerjoe is offline
Gamerjoe's Avatar
Joined Jul 2011
Thanks!
I removed my switch and took it to Radio Shack, and I was able to match it up exactly with one that they had in the store. It was very easy to solder and replace.
The SPDT switch will work if you use the outer two prongs.
Old Mar 20, 2012, 06:04 PM
pmackenzie's Avatar
Joined Dec 2002
The outer two positions on a SPDT switch would never make contact. One wire must connect to the centre connection.
As far as which two to use, just hook it up as it was before.
If a switch is backwards then in the case of a toggle you can either swap to the other outer prong, or simply turn it around.
In the case of a momentary like the trainer, swap the wire.
Pat MacKenzie
Discussion Spektrum Dx6i Trainer Toggle Switch Replacement rarner Radios 7 Aug 22, 2016 03:05 AM
Wanted Broken Spektrum or JR transmitters with working toggle switches 8KCABrett Aircraft - General - Radio Equipment (FS/W) 1 May 22, 2010 02:09 AM
Discussion Toggle switches for 1/6 or 1/7 scale cockpit Seahawk82 Scale Fuel Planes 1 Feb 23, 2009 02:26 PM
Discussion Need replacement JR toggle switches ClimaxPilot Radios 0 Nov 24, 2006 02:35 AM
Discussion Broken Toggle switches on Futaba T8UAP richard donell Radios 2 Sep 25, 2006 01:39 PM
