Espritmodel.com Heli Air
Old Mar 22, 2012, 09:36 PM
Hawkeye2's Avatar
Joined Mar 2012
After.burner, Dr.Tom, could you post the source for the 2Hz Update patch?
I set SCREEN_AND_SENSOR_UPDATES_PER_SEC to 2, but it has no impact on the GPS/Home Arrow speed...
Thanks a lot!
Hawkeye2 is online now Find More Posts by Hawkeye2
Old Mar 22, 2012, 10:06 PM
Joined Mar 2012
Thanks a lot!
that's a hardware limitation, the GPS that comes with it absolutely SUCKS and has a 1Hz update rate. and the data is 3-5 seconds behind.
you need a new gps module(10hz) for better home arrow
FPV Pilot is offline Find More Posts by FPV Pilot
Reply With Quote  (Disabled)
Old Mar 23, 2012, 02:28 AM
marchino65's Avatar
Florence, IT
Joined Oct 2006
Originally Posted by vinnygogo View Post
why would you want to use it with an eosd if you have a remzibi?
Hi,
because it is a clone broken
marchino65 is offline Find More Posts by marchino65
Old Mar 23, 2012, 07:47 AM
Hawkeye2's Avatar
Joined Mar 2012
Thanks, man! Do you have any suggestions for a cheap Higher-Hertz GPS Alternative?
Many greetings!
Peter
Old Mar 23, 2012, 07:52 AM
Went to mow a meadow
frank48's Avatar
Joined Feb 2007
Many greetings!
Peter
I got one of these http://www.ebay.co.uk/itm/1708044201...84.m1423.l2649
Seller accepted £16.00 and has free shippinf
I havent tried it yet but I think the specs are really good
Frank
frank48 is offline Find More Posts by frank48
Old Mar 23, 2012, 08:02 AM
Joined Mar 2012
i would just get the gps module from hobbyking. the one that is supposed to be for the other OSD.
Old Mar 23, 2012, 08:53 AM
Hawkeye2's Avatar
Joined Mar 2012
Thanks! Will try one of these!
Bye! Peter
Old Mar 23, 2012, 08:59 AM
marchino65's Avatar
Florence, IT
Joined Oct 2006
Frank
Hi,
but it is better than to have the Breakout Board ?
http://www.ebay.co.uk/itm/Micro-GPS-...ht_3107wt_1270
Old Mar 23, 2012, 12:22 PM
frank48's Avatar
Joined Feb 2007
Originally Posted by marchino65 View Post
Hi,
Wow - yes thats a good deal, I got mine a few weeks ago before that was listed.
Nice find
Frank
Old Mar 23, 2012, 01:49 PM
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Wow, I go on a holiday and the forum explodes with questions.
I'm sorry if I don't answer your questions but I have a hard time finding time to work on this project right now.
I'm on parent leave at home with my child. And also working on a new project that little time I have.
If any of you find any bugs in the code please make a bug on the google code page here.
For questions regarding config, hardware etc. ask it here and some of the smart guys might be able to help you.
callelj is offline Find More Posts by callelj
Old Mar 23, 2012, 02:21 PM
RC pilot by soul
Joined Apr 2005
Hi,
how much HZ is that module ?
i3dm is offline Find More Posts by i3dm
Old Mar 23, 2012, 02:44 PM
marchino65's Avatar
Florence, IT
Joined Oct 2006
Info seller
• MediaTek MT3329 Single Chip
• NMEA-0183 sentences at 4,800 bps on Tx pin
• L1 Frequency, C/A code, 66 channels
• Supports up 210 PRN channels
• Jammer detection and reduction
• Multi-path detection and compensation
• Dimension: 16mm x 16mm x 6mm
• Patch Antenna Size: 15mm x 15mm x 4mm
• High Sensitivity: Up to -165 dBm tracking, superior urban performances
• Position Accuracy: without aid: 3m 2D-RMS , DGPS (SBAS(WAAS,EGNOS,MSAS)):2.5m 2D-RMS
• Low Power Consumption: 48mA @ acquisition, 37mA @ tracking
• Low Shut-Down Power Consumption: 15uA, typical
• DGPS(WAAS/EGNOS/MSAS/GAGAN) support (Default: Enable)
• Max. Update Rate: up to 10Hz (Configurable)
• Dual interface: UART TTL or USB
• FCC E911 compliance and AGPS support (Offline mode : EPO valid up to 14 days )
• 3.3V or 5V power supply
• RoHS Compliant
Old Mar 23, 2012, 05:58 PM
CL-OSD developer
Joined Apr 2011
Originally Posted by Dr.Tom View Post
wow, 22chars max,
that solved my problems thanks man!
@home, not field tested yet.
Good that you found a solution, but it's a bit weird that you only can use 22 chars...
What type of camera are you using?
Thanks for the beer btw, sorry I wasn't any help...
Old Mar 23, 2012, 07:26 PM
frank48's Avatar
Joined Feb 2007
Frank
Hi,
Info seller
• RoHS Compliant
Ok guys, anyone getting one of these might find this utility useful to set the update rates etc.
Frank
Old Mar 24, 2012, 12:25 AM
marchino65's Avatar
Florence, IT
Joined Oct 2006
Frank
Hi,
thanks for the utility, but I think it takes a signal converter TTL/RS232 to connect to your PC. Correct?
Marco
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 Video Piloting (FPV/RPV) 1927 Apr 03, 2013 09:45 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN Video Piloting (FPV/RPV) 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
