Old Feb 16, 2012, 05:51 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
here is the wiki:
http://code.google.com/p/cl-osd/w/list
and weather you need new code or not depends on what you want it to do!!
if you don't want/need any of the new stuff, then no you don't
I want the new stuff, I'm going to try to get the current sensor to work (it is doing something, but not quite working yet)
yzguy is offline Find More Posts by yzguy
Old Feb 16, 2012, 06:13 PM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
i just need lod & azimuth ... i have no current sensor.
i'll check
thank you for the replay.
can you please explain the operation of this software ?
when i start walking with the plane in hand, there is some data in the middle of the screen ( los / speed / .. ) then it disappears .. after few second come back ... and go on.
edit:
i programmed the last code to the unit.
it looks the same.
the arrow pointing to home is not working ?
thank you
guy1a is offline Find More Posts by guy1a
Old Feb 16, 2012, 06:25 PM
Opt is online now
Opt
Find More Posts by Opt
Opt
New Zealand, Auckland
Joined Oct 2010
Originally Posted by Opt View Post
Does anyone know what the problem might be? What does the fast flashing red light mean?
I'm on CL-OSD r72
Anyone? Fast flash / slow flash??
Opt is online now Find More Posts by Opt
Old Feb 17, 2012, 08:02 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
in my system ( that i have no idea what version is )
it means that no video stream is connected to osd.
Old Feb 17, 2012, 09:18 AM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
i'll check
edit:
it looks the same.
thank you
it by default does not show azimuth. I suppose it could, but I assume you are talking about home arrow, and distance.
The stuff in the middle of the sceen is the flight summary. The osd reads 0 speed, and thinks you are done flying, and is trying to show things like, flight time, max alt, and max distance. This is one of the things you can turn off if you want. You can also adjust when this shows up, I think there is a min speed, and a time, so say after 10 seconds of being under 5mph, it shows the summary.
First be sure you are getting a good gps fix, see what the sat count is. Next you have to be moving for the home arrow to work. There is no compas sensor, so it has no idea what direction you are facing, only what direction you are moving, and the more you are moving the better. The home arrow turns into an X if it can't tell what direction you are moving (sometimes will even happen if turning sharply or in a dive or flying into the wind with a very low ground speed)
Best way to test is to get a god GPS fix, and get in a car. (easier if someone else is driving, so you can look at the OSD)
Old Feb 17, 2012, 09:53 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Hi..
Thankx for the input.this is great !
I will put it to the test. As soon as the rain stops.
Old Feb 21, 2012, 03:35 AM
vinnygogo is offline
Find More Posts by vinnygogo
Joined May 2010
is there anyone who already has or is willing to make a video tutorial about how to flash the g-osd? that would be great!
vinnygogo is offline Find More Posts by vinnygogo
Old Feb 21, 2012, 05:15 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
what os you use ?
Old Feb 21, 2012, 05:28 AM
Joined May 2010
windows 7 or windows xp
Old Feb 21, 2012, 05:46 AM
Opt is online now
Opt
Opt
Joined Oct 2010
I think my problem is a cracked circuit board
If anyone needs a GPS module, or has a spare G-OSD board, let me know.
Old Feb 21, 2012, 05:51 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
yesterday i had a real test flight with the osd.
i think it works perfect !
thank you all for the support and the effort !!!
( the interference is the rc link booster too close to the RX antenna )
Caesarea night FPV 2 (0 min 46 sec)
Old Feb 22, 2012, 12:15 PM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
guys ..
i see in this movie that it is possible to use two batteries and rssi together !
how ?
and is it possible to connect 16 volts battery ?
thanks
http://www.youtube.com/watch?v=XZ6Kse_vGaQ
Old Feb 22, 2012, 05:14 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
it has 3 separate inputs for 2 voltages, and one for RSSI. (I do see that is not specifically mentioned)
the listed specs of the main board are 7.4~12V, not not sure it will like anything other than 2-3S
http://www.hobbyking.com/hobbyking/s...dproduct=19832
Old Feb 23, 2012, 01:49 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
ok, thank you for the input.
can you please detail the v1 / v2 / rssi connections ?
i think i have found something about the pin30 on the cpu to be connected to rssi ?
if so, where is the config for connecting pin30 to v2 ?
thanks.
( though i am not going to change it and connect 4s... thank you for that )
Old Feb 23, 2012, 03:20 AM
Joined May 2010
if you look at the product on hk website(link above your post) you can see on the second picture that the inputs are very clear...
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 12:07 PM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 07:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 03:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 06:22 PM
