Old Jan 30, 2012, 01:31 AM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
Ok so I got the thing progg'd with AVR Studio 4 real easy.
But now I want to change a couple of things.
So I did what it says and installed AVR 5
I opened config.h and changed a couple of things via notepad then closed and saved the edited config.h file back in its original place.
The file now has a red ! Next to it.
Followed the instruction to compile and it returned no errors but I notice that now the output hex file has a red ! Next to it.
Is this normal or at least ok ?
I changed the coordinates to suit google and that seems to change on the osd screen.
I selected only two of the home pos set options ie
#define HOME_SET_AT_FIX
#define HOME_SET_MIN_SATS 4
I had 9 satellites but still got no home position ??
What have I missed here
Thanks in advance
Ian
BigJimNZ is offline Find More Posts by BigJimNZ
Old Jan 30, 2012, 10:04 AM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
the ! just means you made changes to the file, no big deal. Not 100% sure on the home pos.
yzguy is offline Find More Posts by yzguy
Old Jan 30, 2012, 12:13 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Oh ok thanks. I will keep trying with the code
Old Jan 30, 2012, 02:29 PM
Baggus is offline
Find More Posts by Baggus
Joined Jun 2010
@callelj Any news on the telemetry downlink through the VBI?
Baggus is offline Find More Posts by Baggus
Old Jan 30, 2012, 02:38 PM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Baggus: I did some test with inserting some data in the visible part but and then I tried to create a circuit for extracting the signal on the other end but it I'm not so good at analog electronics and then I haven't done anything more since then. I'm currently working on another project so I doubt if I will resume it. Sorry...
I don't know if you guys know this but I haven't even flown anything with my osd. Still have that last thing I need to fix on my plane...
callelj is offline Find More Posts by callelj
Old Jan 30, 2012, 02:53 PM
Baggus is offline
Joined Jun 2010
Well please tell us what you need to fix, maybe we can help you for a change
Old Jan 30, 2012, 02:58 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
I need some way to extract the signal from the video. Imagine that each line is like a barcode. White, Black, White, Black, White, White etc.
This would be in the VBI section so the background should be black. Only thing needed is to add white.
Old Jan 30, 2012, 03:00 PM
Baggus is offline
Joined Jun 2010
I wasn't just talking about the OSD, what's wrong with the plane? :P
About that circuit, shouldn't an Arduino be able to take a CVBS signal directly on one of the analog ports?
You may need something like a usb oscilloscope (very cheap nowadays) to figure out what kind of signal to look for on the analog port of the Arduino.
Old Jan 30, 2012, 03:32 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Aaa, ok. I just need to do some tweaks to it. No problem.
And learn to fly planes better.
I'm much better at multicopters. But after trying fpv without osd on my tricopter I think it needs an multiwii or simular for me to use it or my quad as an fpv platform. It ended upside down in a field.
Old Jan 31, 2012, 12:06 AM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Ha ha Leave a couple of things in and a couple out and now I have the home pos woop woop
Plenty of things to play with in the config.h.
Hours of fun
Old Feb 01, 2012, 05:51 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
so no one knows why I may be getting
avrdude.exe: ERROR: address 0x2010 out of range at line 513 of cl-osd.hex
even from code pulled down and un modified?
Old Feb 02, 2012, 10:39 AM
fpvwannabe is offline
Find More Posts by fpvwannabe
Joined Dec 2011
try googeling:
"avrdude.exe: ERROR: address" "out of range at line"
i quickly skimmed the results, it seems that while it typically indicates too large a hex file, there are some people reporting it happening with a file known to be of acceptable size; maybe you can find some leads there
fpvwannabe is offline Find More Posts by fpvwannabe
Old Feb 02, 2012, 04:11 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
I did look around there (and just did again). So far I have not found any answers, other than the file is too large.
I will try to check out an old version and see if I can burn that, and maybe start removing some stuff to make it smaller and see what happens....
Old Feb 03, 2012, 12:37 AM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
ok, well I'm an idiot....
the batch file I was using to burn, was hard coded to one path, so even though I was copying it around to different directories with different versions, it kept trying to burn the same one, which is probably to large..... Now that I know I can burn the stock one, I can figure it out.
Old Feb 07, 2012, 04:14 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
hey callelj can you make it so that once I have a home position it doesn't forget it? Sometimes in deep dives I lose satellites and when I come back to level the home position is gone!
This is really hard when I'm 3km out and I now have no home arrow.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 12:07 PM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 07:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 03:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 06:22 PM
