New Zealand, Auckland
Joined Oct 2010
I think I'm going to try this one:
http://search.digikey.com/us/en/prod...1-1-ND/2470595 only 25 amp, but it is a tad smaller and lighter, and will allow for the OSD to read the data with slightly more accuracy since it is 55mV per amp instead of 40mV per amp. I know I'll have to tweak the calcs in the code a bit since this changed. Maybe I'll see if I can make the calcs generic and add variables for things like min V and mV/A so any current sensor could easily be used by setting these numbers (if it is not already). |
Joined Jan 2012
Hello
first of all I want to thank callelj to make this great project. I have successfully tested cl-osd on my g-osd v.II with HK SONY CCD 1/3inch Camera http://www.hobbyking.com/hobbyking/s...mera_PAL_.html Then I tested it with RangeVideo KX-1 Micro color CMOS camera PAL http://www.rangevideo.com/index.php?...910b72b0a22c1b But got only distorted stripes on screen (ghosts lines ...) I read whole thread and try to play with suggested parameters like GRAPICSENABLED, TEXT_LINE_MAX_CHARS, TEXT_LINES, TEXT_TRIG_LINES_LIST but withoud the success. I've only got less stripes on the screen. I've tested KX-1 on Eagle OSD Pro and everything works ok. Sony camera work on 11V and is 582x500 420TV lines KX-1 works on 5V and is 786x576 520TV lines Has anybody idea where coud be a problem? Thank you wery much. |
Joined Jan 2012
DrEvil: you can find pinout and some communication info about EagleTree GPS V4 here http://www.rcgroups.com/forums/showthread.php?t=1257119
I was trying but did not find info how to setup module to 4800 bit rate. You could try change CL-OSD config.h parameter #define GPS_BAUD 4800 to 38400 I did not test this. Maybie in the future. But I did not promise :-) |
I'm totaly noob, so i dont know howe to change anything just yet ![]() But no worries..... Kai |
| Thread Tools | |
| Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video | tom66 | Video Piloting (FPV/RPV) | 1927 | Apr 03, 2013 09:45 AM |
| Discussion Open Source Remote Control System (OSRC) | Gizmoman31 | Radios | 152 | Apr 24, 2012 06:01 PM |
| Discussion Open source OSD for FPV | UFO_MAN | Video Piloting (FPV/RPV) | 75 | Sep 07, 2011 02:03 PM |
| Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... | Schatham421 | Multirotor Talk | 14 | Apr 12, 2011 05:22 PM |
