Joined Sep 2009
Google coordinates
I had a similar problem. The first digit after the '.' had to be '0' for properly show the location in google maps - however the leading zero is not printed. I submitted a patch to fix it by email to cl-osd@googlecode.com on the 22/11/11 but so far I haven't received a reply. |
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Voltage is available already since r1...
New is current and mAh. In theory but the resolution will suck... Either move RSSI to voltage 2 and that resolution will suck.... Or remove the voltage divider on voltage 2 and change some defines. |
Joined Apr 2011
2. Connect that wire to your current sensor output pin. 3. Add "#define ANALOG_IN_3 2" to line 62 in hardware.h Might work... Yes, the G-OSD can support all three but either RSSI or current sensor will be a bit low in resolution. |
Joined Apr 2011
Opt: Thanks!
You can see all the changes I have made here: http://code.google.com/p/cl-osd/source/list |
| Thread Tools | |
| Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video | tom66 | Video Piloting (FPV/RPV) | 1927 | Apr 03, 2013 09:45 AM |
| Discussion Open Source Remote Control System (OSRC) | Gizmoman31 | Radios | 152 | Apr 24, 2012 06:01 PM |
| Discussion Open source OSD for FPV | UFO_MAN | Video Piloting (FPV/RPV) | 75 | Sep 07, 2011 02:03 PM |
| Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... | Schatham421 | Multirotor Talk | 14 | Apr 12, 2011 05:22 PM |
