Old Dec 11, 2011, 03:52 AM
gbvideo is offline
Find More Posts by gbvideo
Joined Aug 2011
Calle .... you think is a problem due to the quartz is located on the G-osd?? and how should it be?
I remind you that before upgrading my G-osd worked well and you could superimpose the data, the only drawback that I had the GPS data began to work after 30-35 min ... too much to wait for a flight. ... you think .... so I decided to update the firmware ....
gbvideo is offline Find More Posts by gbvideo
Old Dec 11, 2011, 03:55 AM
gbvideo is offline
Joined Aug 2011
I think the problem is somewhere else .... we have the information but do not align with the scanning of the video signal
Old Dec 11, 2011, 05:17 AM
gbvideo is offline
Joined Aug 2011
i like more, how do it?
Old Dec 11, 2011, 05:43 AM
gbvideo is offline
Joined Aug 2011
Resolve?
DO YOU think that i can return to the original firmware on g-osd?
Old Dec 11, 2011, 05:50 AM
gbvideo is offline
Joined Aug 2011
result
hi i like more your code but i have put it in my g-osd and the end this is the result....can you help me to resolve this problem....or return to old firmware of original g-osd...
if you can help me show me step by step how i resolve....thanks
Old Dec 11, 2011, 06:02 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
lol we don't know and NO you cannot revert to original firmware
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Dec 11, 2011, 06:42 AM
superjelli is offline
Find More Posts by superjelli
Joined Sep 2011
Are you guys sure you flashed the correct firmware? There are three different .hex and .eep files. One for G-OSD, one for E-OSD and one for E-OSD with GPS. Are you positive, that you took the right one?
superjelli is offline Find More Posts by superjelli
Old Dec 11, 2011, 08:15 AM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Also are you sure you haven't changed the fuses? I don't remember the command to print the fuses now. Maybee someone else do?
Edit: found it!
avrdude -c usbasp -p m88 -U hfuse:r:high.txt -U lfuse:r:low.txt
Upload the files here.
Also could you try this firmware?:
http://code.google.com/p/ardupirates...eOSD.zip?r=767
callelj is offline Find More Posts by callelj
Old Dec 11, 2011, 12:19 PM
Elthi is offline
Find More Posts by Elthi
Elthi's Avatar
Belgique, Bruxelles, St-Pieters-Woluwe
Joined Sep 2010
Hi Callej,
When I entered the command line, I had:
C:\Prog\avrdude>avrdude -c usbasp -p m88p -U hfuse:r:high.txt -U lfuse:r:low.txt
avrdude: warning: cannot set sck period. please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e930f
avrdude: current erase-rewrite cycle count is -25413616 (if being tracked)
avrdude: reading hfuse memory:
Reading | ################################################## | 100% 0.01s
avrdude: writing output file "high.txt"
avrdude: output file high.txt auto detected as invalid format
avrdude: invalid output file format: -1
avrdude: write to file 'high.txt' failed
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Elthi is offline Find More Posts by Elthi
Old Dec 11, 2011, 12:57 PM
gbvideo is offline
Joined Aug 2011
i have used only code .eep and .hex for G-OSD, i have read that if i use the E-OSD code can broken chip....
I HAVE FOLLOW attempt the pdf....
Old Dec 11, 2011, 12:58 PM
gbvideo is offline
Joined Aug 2011
very sorry but what the FUSE?
Old Dec 11, 2011, 01:03 PM
gbvideo is offline
Joined Aug 2011
Fuse????
Perhaps you meant this for FUSE
Old Dec 11, 2011, 01:56 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Elthi: Try this:
avrdude -c usbasp -p m88pa -U hfuse:r:high.txt:h -U lfuse:r:low.txt:h
Yes, that will work as well. Did you press "Read all" before taking a picture?
Old Dec 11, 2011, 02:37 PM
Elthi is offline
Elthi's Avatar
Joined Sep 2010
Originally Posted by callelj View Post
Elthi: Try this:
With m88pa it doesn't work but I tried m88p and now you can find the 2 files in attachment.
Thanks for your help.
Old Dec 11, 2011, 03:44 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Elthi: It looks as if your fuses are wrong.
But changing the fuses might brick your board.
On the other hand it's kind of bricked right now anyway...
Try this:
avrdude -p m88pa -c usbasp -U lfuse:w:0xF7:m -U hfuse:w:0xDC:m -U efuse:w:0xFF:m
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 12:07 PM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 07:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 03:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 06:22 PM
