Old Nov 27, 2011, 05:20 PM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
erazotropa: See the wiki FAQ here
callelj is offline Find More Posts by callelj
Old Nov 28, 2011, 07:55 AM
Consti is offline
Find More Posts by Consti
Schweiz, ZH, Hausen am Albis
Joined Oct 2011
Originally Posted by chatch15117 View Post
sorry to be a nagging nancy but I've noticed the GPS info is 3-5 seconds behind. The home arrow is always lagging behind and I have to travel in one direction for 5-10 seconds to get an accurate reading.
Would increasing the speed to 4Hz make a difference? I am back on stock 1Hz refresh rate.
I don't think so. I tried it with 2 Hz, but it's a problem of the cheap 1 Hz GPS module.
I will try it with the DIY 10 Hz GPS module attached to my ArduPilot in the next few days.
Consti is offline Find More Posts by Consti
Old Nov 28, 2011, 08:46 AM
aSa2 is offline
Find More Posts by aSa2
Joined May 2010
Any directions on calibrating bat2 on E-OSD with cl-osd firmware?
http://www.rcgroups.com/forums/showp...&postcount=854
aSa2 is offline Find More Posts by aSa2
Old Nov 28, 2011, 01:13 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
See FAQ, link in my previous post.
Old Nov 28, 2011, 02:10 PM
aSa2 is offline
Joined May 2010
Oh, thanks for adding that to FAQ, but as i don't know the language i still want to clarify:
if ADC_MULT and ADC_DIV are arrays
#define ADC_MULT 1,1
#define ADC_DIV 1,1
the aquasion:
ADC = (IN[x] * ADC_MULT[x]) / ADC_DIV[x]
so if x=0 then ADC=(IN[0] * 1) / 1 so IN[0] (is that input of voltage reading? i dont get that) is unchanged
what do you mean by: "mult 9 and div 10"?
do i have to add values to arrays or what?
The question is: what is "x" and what an array is "IN"? That would explane me a lot, but not for all
Sorry if that is a dumb question, but that would help me
Old Nov 28, 2011, 03:46 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Ok, maybee it was on a bit high level.
Updated the wiki, please see if it answers your questions... :-)
Old Nov 30, 2011, 02:48 AM
RonSpooner is offline
Find More Posts by RonSpooner
Australia, VIC, Kurunjang
Joined Jan 2011
avrdude: initialization failed, rc=-1
I am using a usbtiny programmer and it can't access my g-osd atmega88v chip. It has support for the atmega88 chip.
With this command avrdude -c usbtiny -p m88 I'm getting this error avrdude: initialization failed, rc=-1
Searching the internet this appears to be a wiring problem but I have checked the wiring several times and I'm sure there is no error.
I am using Linux but I have tried on a Windows machine with exactly the same result.
When I plug the g-osd in I get a solid red light on the g-osd and when I run the command the red light goes out briefly.
usbtiny pin 1 --> miso
usbtiny pin 2 --> +5
usbtiny pin 3 --> sck
usbtiny pin 4 --> moso
usbtiny pin 5 --> rst
usbtiny pin 6 --> gnd
RonSpooner is offline Find More Posts by RonSpooner
Old Nov 30, 2011, 03:12 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
you got the pins mixed up somehow or they are shorted. the light should blink rapidly while plugged in but idle and I can't remember what it does when flashing. it might go solid on but not sure. I'll be flashing tonight with a 4Hz firmware so I'll post a video of me flashing it and what it looks like
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 30, 2011, 03:16 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
That error is probably one of the worst I know. I gives no help at all on what could be wrong. But it sound like you might have the wiring wrong. The image in the wiki of the pinout on the programmer is from the top, are you sure you haven't mixed it up?
See here: http://www.bot-thoughts.com/2011/07/...-attiny13.html
Old Nov 30, 2011, 04:39 AM
Joined Jan 2011
I'm sure I have it right. I can see it's possible to be confused when looking at the cable and the header pins. I checked the voltage on wire 2 and 6 = 4.77v
I thought I may have damaged the g-osd but I just connected it up and it's working fine. I am going to resolder and check the wiring. I will then post a photo and maybe someone can see the problem.
Old Dec 01, 2011, 12:11 AM
Joined Jan 2011
I tried another programmer, it's a usbasp (10 pins) and I can now access the chip with a new error
sudo avrdude -p m88 -c usbasp -U flash:w:cl-osd.hex -U eeprom:w:cl-osd.eep
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e930a
avrdude: safemode: Verify error - unable to read lfuse properly. Programmer may not be reliable.
avrdude: safemode: To protect your AVR the programming will be aborted
avrdude done. Thank you.
Any help appreciated.
Old Dec 01, 2011, 03:00 AM
matjazb is offline
Find More Posts by matjazb
Slovenia, Maribor
Joined Oct 2005
I had similar problem. In my case GND pin was troublemaker.
Check
Open usbprogramer and check if pin6 is realy GND on pcb. I should select diferent GND pin (pin10 i think).
matjazb is offline Find More Posts by matjazb
Old Dec 01, 2011, 03:59 AM
Joined Jan 2011
Check
Thank you all
Working perfectly now
Old Dec 01, 2011, 05:13 AM
msev is online now
Find More Posts by msev
Joined Sep 2010
Matjazb I sent you a PM .
A bit off topic question for all you guys who are very fluent in electronic knowledge, does anyone know what is the difference between this two gps's:
FGPMMOPA6C (PA6C) and FGPMMOPA6B...First one is selling for 15eur+vat+shipping (trenz electronic) the other one is selling for 25eur + 3$ shipping (flytron)...
If in a project the B version works would also the C work, where is the difference? (in initialization or where)
msev is online now Find More Posts by msev
Old Dec 01, 2011, 01:11 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Yes this is a bit of topic. Couldn't you create a separate thread for this?
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
