Old Oct 04, 2011, 03:31 PM
Galamaga is offline
Find More Posts by Galamaga
Joined Jul 2011
Originally Posted by callelj View Post
I'm sorry to hear that so many are having problems with programming the chips but it's hard for me to trobleshoot via the internet...
Could someone without any problems please write so I know it works at all...
Galamaga: Sounds like you either have to low a voltage connected to the E-OSD or your regulator is bad.
chatch15117: Not to much to be honest, I started programming on my E-OSD since it was the cheeper of the two boards and I keep the support for it when I started programming on the G-OSD. But you can add a GPS to make it more interesting plus since you have the source you can change things.
My connection for USBASP are next, not same as showed on ebay )
But Syberian version works good, I have tried with 2s and 3s battery.
Galamaga is offline Find More Posts by Galamaga
Old Oct 04, 2011, 03:33 PM
Galamaga is offline
Joined Jul 2011
Originally Posted by (Jo)Hannes View Post
Thanks for your help and this great Project!
Just tried that, looks a bit different but seems to habe the same problem:
I have similar problem, but this problem was solved after recompiling sources with 21000000 CPU speed, (24000000 by default).
Old Oct 04, 2011, 03:38 PM
(Jo)Hannes is online now
Find More Posts by (Jo)Hannes
http://der-frickler.net
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
OK, could you send me your hex file for testing?
To late for today to setup the compiler and stuff....
(Jo)Hannes is online now Find More Posts by (Jo)Hannes
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
(Jo)Hannes: Thanks! Yes, that looks just as bad...
Galamaga: Hmm, strange...
A thought juts occured to me:
I wonder if there are different board revisions with different pinouts?
For those of you having problems with the firmware, test Syberians code and see if that works. (Thanks Galamaga!)
callelj is offline Find More Posts by callelj
callelj is offline
CL-OSD developer
Joined Apr 2011
Galamaga: Aaaa, different crystals!
Edit: 24MHz is actually over spec for the µP.
Old Oct 04, 2011, 03:40 PM
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
My Crystal says 24000
Old Oct 04, 2011, 03:42 PM
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
By the way, has anybody the original hex and eep files to restore the OSD?
Old Oct 04, 2011, 03:44 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
The original code is read-protected. Sorry...
Old Oct 04, 2011, 03:47 PM
Galamaga is offline
Joined Jul 2011
Here compiled for 21mhz
Old Oct 04, 2011, 03:51 PM
Galamaga is offline
Joined Jul 2011
Yes, I know it's much more then needed , but from the config.h
Code:
#define F_CPU 24000000UL
Old Oct 04, 2011, 03:56 PM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
Hi,
I am attempting to load cl-osd and am having an issue. I am using a pololu pgm03a v1.06, http://www.pololu.com/catalog/product/1300/pictures and AVR studio 5 using STK500.
The pololu LEDS indicate that connection with PC is fine (solid green LED) and that the GOSD is ready to program (blinking yellow led.) In AVR studio I can connect to polou (STK500, ATmega88PA, ISP) but as soon as I try to read or write I get an error. The yellow LED continues to blink indicating connection to GOSD is good and the red LED starts flashing, indicating that programming mode failed because voltage is too low (as best I can tell.)
I have triple checked cabling, all looks good. I know trying to diagnose something like this over the internet is near impossible but I thought I would throw it out here anyway. Does anyone have any suggestions? I am wondering if perhaps my soldering is not up to scratch and may be causing this.
This is a great project, keep up the good work!
Cheers,
Gimmer
Gimmer is offline Find More Posts by Gimmer
Old Oct 04, 2011, 03:58 PM
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
No, as expected the 21MHz does not work either, it totaly destrois the signal/picture
Old Oct 04, 2011, 04:00 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Gimmer: If it complains about voltage getting too low then try removing VCC / +5 V between OSD and programmer and add external power to the OSD.
Galamaga: Yes, but my crystal is 24MHz so that's why I have that there...
Old Oct 04, 2011, 04:04 PM
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
By the way, what does the LED do in the normal CL-OSD firmware?
Mine blinks from time to time...
OK, blinking was only while the progger was still connected
Old Oct 04, 2011, 04:05 PM
Galamaga is offline
Joined Jul 2011
And signature of my chip is 0x1e 0x93 0x0F so it is atmega88P, not atmega88PA
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
