Old Oct 03, 2011, 04:16 PM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Parity: I tested r57 on my new G-OSD just now and it works like a sharm. And btw this board has a atmega88pa chip.
Are you using PAL and could you test another camera?
callelj is offline Find More Posts by callelj
Old Oct 03, 2011, 05:01 PM
Parity is offline
Find More Posts by Parity
Parity's Avatar
Joined Sep 2011
Testing I have done so far:
I tried a different camera, a cheap Sony 1/3 CCD: Same problem.
I tried moving the lines up and down a bit: Same problem.
I tried lowering TEXT_LINES to 3: Same problem.
May it be the length of my connection wires?
I have two wires on the Cam, each 20cm. One to the TX, one to the OSD.
But then why should it only appear with the new revisions.
Parity is offline Find More Posts by Parity
Old Oct 03, 2011, 11:53 PM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
I installed avrstudio and was able to compile after putting in the basic settings in config.h now I really want to load it on the device
Anyone else having trouble getting the E-OSD board talking with avrdude? I can't connect to it with my usbtiny (known working, I have used it to burn chips with arduino ide). I have triple checked my solder and pin connections with multimeter. The OSD lights up when its connected (I'm powering it from my programmer but also tried with an external power source).
any ideas? Also I tried this on my windows 7 32 box and on my macbook both yield the rc=-1 error
avrdude -c usbtiny -p m88
Tried slowing it down didn't make a difference.
avrdude -c usbtiny -p m88 -b 32
avrdude -c usbtiny -p m88 -b 250
I have a 2nd E-OSD I could test, but it isn't soldered up yet.
Charlie
charlienofun is offline Find More Posts by charlienofun
Old Oct 04, 2011, 01:05 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
E-OSD with GPS
teopbako is offline Find More Posts by teopbako
Old Oct 04, 2011, 01:15 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Parity: Might be the cables but as you said why should the revision change make any difference? I made some major changes in r53 regarding text layout and drawing so there must be an error there somewhere. Have you tested without connecting the gps?
charlienofun: If the E-OSD still work (shows text) then there must be a bad wire somewhere. Did you swap MISO and MOSI?
If the E-OSD do not work you might have changed the fuses and changing them bad is really hard.
Old Oct 04, 2011, 04:25 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Charlie
i had some trouble with this line also, and got rc-1, but when i put all files in c: and ran the command to flash them - it worked with AVRdude and USBTINY. i have a copy of the line in a past post by me in this thread. can you try it ?
i3dm is offline Find More Posts by i3dm
Old Oct 04, 2011, 06:47 AM
(Jo)Hannes is offline
Find More Posts by (Jo)Hannes
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
So, i got my E-OSD this days and i want to use the CL-OSD GPS fimware with it.
I allready have experience in SMD soldering and AVR programming. If i got it rights this is all i need to do:
1. Attach the ISP to the right pins
2. flash the cl-osd.hex
3. solder TX of the GPS to RX of the mega88 (pin 30)
Thats it? do i have to change the fuses of the chip?
Johannes
(Jo)Hannes is offline Find More Posts by (Jo)Hannes
Old Oct 04, 2011, 07:04 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
It is important to flash cl-osd.hex into flash AND cl-osd.eep into Eeprom.
Only with Flash and Eeprom flashed cl-osd can work.
Do not change fuses! (unless you really know what you are doing)
Parity
Old Oct 04, 2011, 07:18 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Parity
OK, must have missed the part with the Eeprom file.
I know what i am doing, not the first time i flash an AVR.
If the fuses are allright as is, i don't need to flash them.
Johannes
Old Oct 04, 2011, 07:19 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
I would say don't change fuses even if you know what you are doing.
I broke the soldering on my E-OSD+GPS yesterday so I took it to work today to repair.
It proved quite hard since some parts of the pcb had been torn of. But I took some pictures that might help others solder the connection.
Don't know if this is the best approach but it works...
Edit: First picture is a board with broken µP, second and third is another board with the soldered GPS pins beeing fixed. Just added the first to give some idea about how it looked before soldering.
Old Oct 04, 2011, 07:29 AM
schumixmd is online now
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
nice approach callelj. I didn't think about that and was dealing with tiny wires that breaks very easy.
schumixmd is online now Find More Posts by schumixmd
Old Oct 04, 2011, 07:32 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
True, true. But I couldn't write that, as I changed fuses (activated EESAVE) and I am happy with it.
But generally speaking: Do not change fuses, it will work perfectly if you leave the fuses what they are.
@callelj: nice soldering skills, at least with the repair
Old Oct 04, 2011, 07:33 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Thanks. But this is quite easy to break as well so you must make sure it stabilized good.
The best approach must be to solder tiny muti core wires and place the connector somewhere stable. But that's a bit much work for me.
Parity: Thanks! But it's so much easier with a microscope! I soldered the connector without microscope the first time thought...
Old Oct 04, 2011, 07:35 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Nice idea to solder it that way ;_)
I Think ill solder a small wire to keep the footprint of the osd small.
Ill show some pics if i have it ready.
Old Oct 04, 2011, 08:46 AM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
G-osd issue
hye all,
I've received my g-osd
have a pb power it with 3S and after a while I still have the camera pictures but all OSd informations diseppear
Like a remzibi I've solder a huge wire of copper on 78L05 big ground pin, in order to dissipate a little more. But another trouble came : after a while osd informations dissepear or osd made a reset loop
do you think I can power it directly with a 5v from immersion video Tx and bypassing the 78L05 ?
fr3d-nexus is offline Find More Posts by fr3d-nexus
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
