Old Sep 19, 2011, 06:22 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
So guys, if i understand correctly, the new version G-OSD is actually ready to use with home arrow and all the data (speed, altitude above home, voltages, RSSI) ?
i3dm is offline Find More Posts by i3dm
Old Sep 19, 2011, 06:26 AM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
Originally Posted by Parity View Post
That leads myself to the question why I did not just use the Batt2 with pot to measure my RSSI instead of using Analog3 and Analog4 to calculate the value
Note: RSSI voltage has to be ripple free. I had to flatten the signal of my 2G4 receiver with a opamp and capacitor to get a flat voltage, otherwise I had values jumping all around.
I think you could do that filter in the µP, but an analog filter is probably better.
I haven't tested with a real rssi signal yet.
callelj is offline Find More Posts by callelj
Old Sep 19, 2011, 06:27 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Yes, but my last commit is untested and have some bugs that Parity have found.
So you might want to use his version until I can get a new board working.
Old Sep 19, 2011, 06:31 AM
Parity is offline
Find More Posts by Parity
Parity's Avatar
Joined Sep 2011
It's a bit complicated, as callelj cannot test at the moment, and I kinda developed a own branch based on release 29.
The version I do have on my G-OSD (the hex file i put in this thread) works with all the features. RSSI works, but it is fitted to my receiver. Other receivers could need adjustments. I do not display Batt2, as I do not need it, but it works fine too.
No known bugs at the moment, so I would say it is ready to test-flight it.
I HAVE NOT FLOWN IT YET. Only driven around in the car with it.
Parity is offline Find More Posts by Parity
Old Sep 19, 2011, 06:36 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
I feel better with a opamp in between, as internal resistance is like 100 megaOhm, compared to 100k of the G-OSD. I heard some storys of bad RC-range if RSSI pin gets pulled down to far, and it already drops by 15% on the 100k ohm.
Old Sep 19, 2011, 06:59 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Parity: Ok, then an op-amp is better! Good info btw.
Old Sep 19, 2011, 02:34 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
I got my e-osd + GPS working today with latest revision.
I had some problem programming the eeprom with my avr mkII clone but with the usbasp it worked right away!
See image below for proof:
Old Sep 19, 2011, 02:42 PM
Parity is offline
Parity's Avatar
Joined Sep 2011
Hey. Happy to have you back on board. Nice arrow you have!
Old Sep 19, 2011, 02:45 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Parity: Thanks!
I took me a while to figure out how to draw it. (Maybe i'm just slow )
I like how it uses the full diameter of the circle, and the arrow of course.
Old Sep 19, 2011, 03:32 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
that looks great ! but i think its much better to put the home arrow in the center of the picture (preferabely close to the top) as its a bit more confusing when its on the right side.
just my 2 cents.
Old Sep 19, 2011, 03:35 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Very well, thanks.
How about the different screen layout as discussed before ? can it be done ? something like the attached picture...
If somebody can do this im ready to buy a G-OSDE for my Funjet !
Or can i use my E-OSD with just a GPS module ? if so whats a good source for such a module ? (i do already have a E-OSD at hand).
Old Sep 19, 2011, 04:14 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Just throwing another idea in the thread here, but how about a home built current sensor for one of these ?
all it should take is a shunt resistor (pretty cheap) and then a multiplier in the software of one of the voltage readings.
for example if you choose a shunt resistor of 50 mOhms, thats 0.050 ohm, then for a 0.05V drop the current is 1A and for 0.5V the current is 10A and for 5V the current is 100A.
Question is, whats the resolution that the G-OSD can measure voltage inside the uC ? does anybody know that ?
Old Sep 19, 2011, 04:22 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
i3dm: I will work on the layout but it won't be exactly as in your image.
A current sensor could be added but lets focus on getting the current features working first.
I have only tested the GPS module from G-OSD with the E-OSD so I don't know a good source...
Old Sep 19, 2011, 04:33 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Thank you callelj ! any ETA on the new screen layout ?
about the current sensor, i was thinking about something like this:
http://www.ebay.com/itm/Shunt-Resist...item45fcec114b
lets say we want current displayed resolution of 0.1A up to 50A. this means that the voltage measurement of the G-OSD would have to be 0-0.75mV in 500 incriments, so it should measure at a resolution of about 0.15mV - can you varify if the G-OSD could do this ?
Old Sep 19, 2011, 04:42 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
You can set the reference-voltage on the ADC - but normally you use 5 volt. Atmega uses a 10-bit ADC, so you will read 0-5 volt as 0-1024 (A resolution of approx 4.882812500 mV).
You will need (preferably) an opamp or something like INA169 to amplify the signal from the resistor.
Dennis Frie is offline Find More Posts by Dennis Frie
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
