Old Sep 16, 2011, 04:23 PM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
I doubt it, but I can't guarantee...
callelj is offline Find More Posts by callelj
Old Sep 16, 2011, 05:02 PM
Baggus is offline
Find More Posts by Baggus
Joined Jun 2010
Really sorry to hear about your osd's being bricked.
I just hooked up my G-OSD to an AVR programmer (usbasp in device manager).
Driver is installed, what do I do next? :P
There must be a simple GUI program for flashing these?
And if there is, how does one use it?
Just tried kkMulticopter Flash Tool 0.32 but that one doesn't seem to take eeprom files.
and now this happened
Code:
Flash the firmware file.
C:\Users\Tjerk\Desktop\avr\lib\avrdude\windows\avrdude.exe -C C:\Users\Tjerk\Desktop\avr\lib\avrdude\windows\avrdude.conf -p m88p -P usb -c usbasp -B 8 -U lfuse:w:0xe2:m -U hfuse:w:0xdf:m
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e930f
avrdude.exe: reading input file "0xe2"
avrdude.exe: writing lfuse (1 bytes):
Writing |  ***failed;
################################################## | 100% 0.03s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0xe2:
avrdude.exe: load data lfuse data from input file 0xe2:
avrdude.exe: input file 0xe2 contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
avrdude.exe: verifying ...
avrdude.exe: verification error, first mismatch at byte 0x0000
             0xe2 != 0xf7
avrdude.exe: verification error; content mismatch
avrdude.exe done.  Thank you.
Error during setting the fuses.
Flashing of firmware aborted.
tried cl-osd.hex on atmega 88p/pa
Baggus is offline Find More Posts by Baggus
Old Sep 16, 2011, 05:39 PM
Parity is offline
Find More Posts by Parity
Parity's Avatar
Joined Sep 2011
You shouldn't change fuses at all.
ATmega88PA is the right chip.
Edit: Which revision did you try to flash?
Parity is offline Find More Posts by Parity
Old Sep 17, 2011, 03:46 AM
Baggus is offline
Joined Jun 2010
R29, because I read R30 was not tested yet
Old Sep 17, 2011, 04:08 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
Thats okay. r29 works fine.
I'm really sorry for callelj and his bricked osd's. Somehow sacrificed for the community.
Old Sep 17, 2011, 05:39 AM
Baggus is offline
Joined Jun 2010
Could someone please post how to correctly flash the firmware, dying to try it out here!
Already have usbasp installed and correctly connected.
If someone shows me the basic steps I can write a comprehensive tutorial.
Old Sep 17, 2011, 02:08 PM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
If I'm reading your command line right, you're missing -u which is necessary when programming fuses:
"Disables the default behaviour of reading out the fuses three times before programming, then verifying at the end of programming that the fuses have not changed. If you want to change fuses you will need to specify this option ..."
(From here)
FpvKiwi is offline Find More Posts by FpvKiwi
Old Sep 17, 2011, 02:28 PM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
For USBASP programmers I use eXtreme Burner to write .hex files to ATmega's as it's more GUI driven then AVR Dude.
Calle,
You might give it a go, just in case it's able to talk to or recgnoize your G-OSD/E-OSD board.
patricklupo is offline Find More Posts by patricklupo
Old Sep 17, 2011, 04:08 PM
Baggus is offline
Joined Jun 2010
Calle,
Thanks for the advice, but I already tried that program and it doesn't recognize the atmega88pa.
Old Sep 17, 2011, 07:40 PM
Parity is offline
Parity's Avatar
Joined Sep 2011
Argh, nasty bug in myReverse().
The loop in there should be for (i = 0; i <= size/2; i++)
Took some time to figure that out...
It lead to longer numbers getting a bit obscure in the middle.
For instance for a distance from home of 1650 meters you got displayed 1560.
Fixed it in my modified r29. Got RSSI working too.
Parity
PS: I flash the OSD with an AVR mkII (USB) right from AVR Studio. Explanation and pictures wanted?
Old Sep 18, 2011, 12:29 AM
Jancis is offline
Find More Posts by Jancis
Joined Aug 2011
Yes please! Every documentation is valuable, newbies like me need that.
I am just about to get programmer, can I just get the cheapest one off ebay (like this one: http://www.ebay.co.uk/itm/USBASP-USB...#ht_3870wt_907 )?
Jancis is offline Find More Posts by Jancis
Old Sep 18, 2011, 07:23 AM
Baggus is offline
Joined Jun 2010
I second that!
And I already have the programmer in your link
Old Sep 18, 2011, 07:34 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
So in a very short form here is what to do with a AVR mkII in AVR Studio. AVR Studio is free.
1: Download cl-osd.hex and cl-osd.eep
This is the compiled program (and eeprom memory). If you do not want to make changes in the code of the program, you will not need any other files.
2: Connect programmer to G-OSD and USB-Port of the PC, then connect battery to the G-OSD.
3: Start AVR Studio, choose Tools -> AVR Programming (see picture)
4. Final window, choose your programmer from the list, choose the ATmega88PA and ISP, then click "Apply".
4b. (optional) You may want to check connection to your chip by clicking "Read" next to device ID. If G-OSD is connected you will get somthing like I did in the screenshot.
5. Select "Memories" and browse to the two files. cl-osd.hex for the flash-memory, cl-osd.eep for the EEPROM. Click "Program" button for the Flash, wait until its done (like 3 to 5 seconds), then click "Program" button for the EEPROM.
Done.
PS: I cannot tell you if or how that works with ebay-programmers. No experience with that.
Old Sep 18, 2011, 02:32 PM
Baggus is offline
Joined Jun 2010
dammit... i only have a cheap usbasp ebay programmer, don't want to wait another month to get a proper one
is there a way to make avr studio think i have a genuine programmer?
does anyone have the command line needed by avrdude?
Old Sep 18, 2011, 02:36 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Parity: Are you sure it's a ATmega88PA? I have always programmed as a ATmega88. Maybee there is no difference?
The USBASP do not work in AVR Studio. At least not mine...
But my stk500 and my AVR mkII works.
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
