Old Feb 02, 2013, 06:59 PM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
I was talking about the stock firmware, I haven't flashed the G-OSD with the CL-OSD firmware.
So far only my E-OSD is running CL-OSD.
For the overflow check what text and graphics is enabled. You have too many stuff active.
IceWind is online now Find More Posts by IceWind
Old Feb 03, 2013, 02:35 AM
3zuli is offline
Find More Posts by 3zuli
Slovakia, Bratislava Region, Bratislava
Joined Jan 2013
In stock FW just press the on-booard button, it will cycle through various styles and metric/imperial units.
3zuli is offline Find More Posts by 3zuli
Old Feb 03, 2013, 06:04 AM
Frazz is online now
Find More Posts by Frazz
Sardinia, Italy
Joined May 2009
Hi, guys. First of all, thank you Callelj for the firmware.
I just flash my e-osd and try it with a gps emulator; for now it seems is working
Later I'll try to set it with a spare skylab skm53...I was thinking if its possible to supply it with the on board 78l05...mmm, maybe it's better to add a ldo on the osd's back..
Another thing, how can I change coordinates position on the screen?
Frazz is online now Find More Posts by Frazz
Old Feb 03, 2013, 07:15 AM
THeRioN is offline
Find More Posts by THeRioN
Scratch Builder & Video Pilot
THeRioN's Avatar
Turkey, Ankara
Joined Mar 2012
Is there any chance that we can adjust white level?
THeRioN is offline Find More Posts by THeRioN
Old Feb 04, 2013, 10:02 AM
3zuli is offline
Joined Jan 2013
THeRioN, adjust your LCD brightness/contrast. This helped me.
Old Feb 04, 2013, 04:12 PM
irun4fundotca is offline
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
my setup using parts without modifying the original cables for vtx and camera
and original firware ...for now (1500mw 1.2ghz with filter & inverted vee ,1800mah switched pack & E-OSD)
Still need to solder the gps pin to smd chip
going to wait on the flash until then
irun4fundotca is offline Find More Posts by irun4fundotca
Old Feb 06, 2013, 03:17 PM
3zuli is offline
Joined Jan 2013
But text and graphics are essential for the entire OSD, aren't they? Maybe you could give me your entire AVR Studio project, so that I can have a look at it and see, what things you have enabled? That would really help me
Old Feb 06, 2013, 04:47 PM
IceWind's Avatar
Joined Feb 2005
I'll push it to github or something like that. But when I was editing it I didn't had GPS so all that is disabled.
Old Feb 07, 2013, 02:41 AM
3zuli is offline
Joined Jan 2013
Oh I see... I actually want the GPS to be enabled, that's the reason I got an OSD
So can anyone tell me, what to do with this issue?
Old Feb 07, 2013, 05:04 AM
Flying Wood For Fun
Joined Jan 2012
I would sugest starting off with the basics enabled or tweaked and get the gps stuff working first
then slowly make changes to things that are next important in line until you get the error again and revert back to where it last worked , atleast you will have the gps home arrow ect
thats the reason I wanted it and also LOS distance , I find speed is too delayed anyway to be usefull & the coordinates are not any use on the screen for me
It's not like I know where xxxxx lon xxxxx lat is anyway, who does? Not like you can copy and paste it into google maps lol
so thats one less thing you do'nt need to display on screen, making room for more memory (unless you record everytime and then crash)
just my thoughts
Old Feb 07, 2013, 06:06 AM
Hasi is offline
Find More Posts by Hasi
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
Is it possible to turn the OSD off during flight?
Hasi is offline Find More Posts by Hasi
Old Feb 07, 2013, 07:37 AM
IceWind's Avatar
Joined Feb 2005
You can load the example .HEX's those have GPS enabled.
@Hasi, not possible with the current code. There is no connection with the RX and you'd need that to use a channel to turn it on/off.
Old Feb 07, 2013, 01:49 PM
Hasi is offline
Hasi's Avatar
Joined Sep 2011
And somehow with an external switch?
Old Feb 07, 2013, 02:45 PM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
remove define statistic or define alarm(s) they are eating a maximum bytes
or choose oly alarms you need
in config.h
Code:
#define STATISTICS_ENABLED
//#define ALARM_ENABLED
Code:
// ----------- ALARMS --------------
//Alarms (Comment to disable)
#define ALARM_BATT1_LOW 10.20 //Warn if below this level (in volt)
#define ALARM_BATT2_LOW 00.01 //Warn if below this level (in volt)
#define ALARM_BATT3_LOW 1.20 //Warn if below this level (in volt)
#define ALARM_BATT4_LOW 00.01 //Warn if below this level (in volt)
//#define ALARM_RSSI_LOW 50 //Warn if below this level (in %)
//#define ALARM_SPEED_HIGH 80 //Warn if above this level (in kmph/mph)
//#define ALARM_ALTITUDE_LOW 10//Warn if below this level (in meters/feet)
//#define ALARM_ALTITUDE_HIGH 100 //Warn if above this level (in meters/feet)
//#define ALARM_DISTANCE_HIGH 500 //Warn if below this level (in meters/feet)
//#define ALARM_CURRENT_HIGH 50 //Warn if above this level (in Ampere)
//#define ALARM_POWER_USAGE_HIGH 5000 //Warn if above this level (in mAh)
voltage 3 and 4 are formy personnal use
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Feb 07, 2013, 02:50 PM
fr3d-nexus's Avatar
Joined Apr 2007
take a look in layour.h
you have only 6 lines and each "options" have a place with "pos" value
Code:
// --------------- TEXT LINE 2 (From top) -----------------------
#ifdef SENSOR_VOLTAGE_1_ENABLED
	  if (!gAlarmBatt1 || gBlink1Hz) {
	    printAdc(gText[textId], pos, ANALOG_IN_1); // Voltage 1
	  pos += 7; pos is incremnted for next option
#endif
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
