Old Sep 12, 2011, 05:18 AM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
i3dm: I like your design but there are some limitations in my design that prevents me from implementing your design exactly. These are the limitations:
1. Text lines cannot be too close together (about 25 lines between at least)
2. Text size only comes in two sizes. The large one 16x16 (as in image) and one half the size 8x8. (Can also do 8x16 or 16x8 but looks harder to read.)
3. Graphics (the "arrow home") cannot be on the same line as text lines
patricklupo: I Have moved the arrow to the side after seeing Parity's design.
Yes the arrow home should work but so far only tested in my apartment.
I thought about taking a ride on my bike with the gps and a small screen and see if I can find my way home using the gps. My girlfriend thought that she should drive me far away blindfolded and see if I find my way home. But I think that is a bit too extreme.
callelj is offline Find More Posts by callelj
Old Sep 12, 2011, 05:25 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Can you try to do it as close as possible to my design and post a screen shot ?
i3dm is offline Find More Posts by i3dm
Old Sep 12, 2011, 05:28 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Sure, I will add it to my todo-list.
Old Sep 12, 2011, 05:35 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
calle you have the chance to be a robocop. Put the goggles on your eyes, and stick the camera on the goggles ... and you will have the possibility to see the road and osd information as well
schumixmd is offline Find More Posts by schumixmd
Old Sep 12, 2011, 05:49 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Hehe, true! I have thought about that before. Might have to realize that some day...
Old Sep 12, 2011, 05:58 AM
Parity is offline
Find More Posts by Parity
Parity's Avatar
Joined Sep 2011
We may need to look at this "FIX" : "BAD" thing again.
I always had "FIX" as long as the GPS-Antenna was connected. I am pretty sure that it was when I was without GPS-signal too.
Parity
Parity is offline Find More Posts by Parity
Old Sep 12, 2011, 06:25 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Ok, I will have a look at it. Might be an error.
The GPS module will blink when it has no fix and be solid if it has a fix.
(If I don't remember wrong.)
Also I haven't added a fallback to BAD when GPS fix goes from good to bad.
Just realized that the other day. :-)
Some delay before actually going to bad would be required I think since you could get a bad fix and then a good one. Or do you want the full update resolution?
Old Sep 12, 2011, 06:30 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
I can't test right now, but try to connect the GPS module and power up the system. Will you see, FIX or BAD?
Old Sep 12, 2011, 06:46 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Can't test right now either, but will test it.
Old Sep 12, 2011, 09:38 AM
up there is offline
Find More Posts by up there
Joined Jun 2010
way cool, i cant wait till its done
by the way as a person how knows nothing about programing how would i put this software on to the g-osd unit?
up there is offline Find More Posts by up there
Old Sep 12, 2011, 09:44 AM
Slaphappysamy is offline
Find More Posts by Slaphappysamy
United States, TX
Joined Oct 2010
When its searching you get "int" and it blinks. Then you get "fix" and the led goes solid. Once I get the initial "fix" in never goes back to "int" and starts blinking again.
Slaphappysamy is offline Find More Posts by Slaphappysamy
Old Sep 12, 2011, 09:58 AM
Parity is offline
Parity's Avatar
Joined Sep 2011
We are talking about cl-osd, not g-osd. cl-osd does never display "IND".
Old Sep 12, 2011, 11:36 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Parity: Checked it now and you are correct. After looking at the code I see that fix isn't really fix but instead checksum ok. Hehe. Will fix that.
Btw: Stop finding bugs in my code.
Old Sep 12, 2011, 12:26 PM
esreis is offline
Find More Posts by esreis
Joined Apr 2009
I suggest not declaring home at the first fis, something like the 20th fix is a lot better.
The gps gives very bad fixes while tunning, the first fix can be VERY bad.
esreis is offline Find More Posts by esreis
Old Sep 12, 2011, 01:05 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
I built a test platform today and took the G-OSD out for a walk.
But I could not get a good fix (only 4 sats) so the position was jumping around +-300 meters.
Has anyone else had problems with aquiring a good fix?
I will make a new attempt tomorrow but right now it's a bit dark here.
Btw: I think it was a good idea not to test this yesterday since must have looked like a terrorist with blinking and wires all over.
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
