Old Sep 11, 2011, 03:28 AM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
I did som tweeking of the code and now I get correct distance and bearing up to 100 km.
Don't see the point of going any further in the testing.
(Haven't uploaded that code yet...)
callelj is offline Find More Posts by callelj
Old Sep 11, 2011, 05:03 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Distance is certainly more useful than just the GPS coordinates that G-OSD displays. Does it show in meters or fractions of a kilometer?
Is a way point working? Even something simple like an 8 position indicator using ascii characters? If so, can I turn off or comment out the GPS coordinates all-together to reduce on-screen info?
-0-
patricklupo is offline Find More Posts by patricklupo
Old Sep 11, 2011, 05:10 AM
Cid156 is online now
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
If it is working fine, I think that hk will use your soft to update the osd
Cid156 is online now Find More Posts by Cid156
Old Sep 11, 2011, 07:21 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
patricklupo: Right now in meters or feet depending build options.
I have a "arrow home" even if it's right now just a circle with a line from the centre to the direction of home.
Old Sep 11, 2011, 02:06 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Can you post some screen shots ?
i3dm is offline Find More Posts by i3dm
Old Sep 11, 2011, 02:20 PM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Starting to regret buying this OSD a little less now.
Keep up the good job Callelj!
Freakazoid is offline Find More Posts by Freakazoid
Old Sep 11, 2011, 03:00 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Freakazoid: Thanks!
i3dm: Still a bit of work in the progress but here is the current layout below.
Any suggestions?
My thought was to make the layout as customizable as possible but it's proving harden than I first thought.
But still there is some room to move things around a bit.
I have two sizes of characters, this is the big one and I also have one that is half the size in both width and height.
No mixing of the two sizes is possible, only one size can be used.
But I could make characters half the width, half the height or both. :-)
Old Sep 11, 2011, 04:12 PM
schumixmd is online now
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi callelj.
My suggestion will be to separate 8S FIX somewhere away from distance(545M) this is not vital information. Let' say move 8S FIX to full right.
schumixmd is online now Find More Posts by schumixmd
Old Sep 11, 2011, 08:21 PM
esreis is offline
Find More Posts by esreis
Joined Apr 2009
what was the problem?
esreis is offline Find More Posts by esreis
Old Sep 12, 2011, 02:51 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
schumixmd: Yes, that sound good.
esreis: When taking the square of the two deltas and adding them together they could overflow the uint32_t for long distances. Specially at 45 deg since both values get big.
Added a check before for that special case.
Precision will of course suffer a bit but at that distance the error would not be a problem.
Old Sep 12, 2011, 03:41 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Freakazoid: Thanks!
Any suggestions?
This is my suggestion. please excuse 1st grade graphics
for me personally there was a lot of un needed info on the screen (note smallet text too).
Old Sep 12, 2011, 04:24 AM
Joined Jul 2009
+1 on I3DM's layout with smaller text, except I'd move the waypoint arrow to the bottom so I can focus on the scenery and only check the waypoint home when I'm panicking cause my lipo's low.
Calle, you really have a working waypoint arrow on the G-OSD?! Wow you get code optimizer of the year award.
Old Sep 12, 2011, 04:34 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
good idea.
Old Sep 12, 2011, 04:42 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
that look nice i3dm
Old Sep 12, 2011, 04:43 AM
Parity is offline
Find More Posts by Parity
Parity's Avatar
Joined Sep 2011
Finally registerd here, but was working with cl-osd since callelj published the code.
I use cl-osd as well, and I am able to customize it to my likeing.
I prefere only little information at the moment, you can see my screen layout here:
Altitude, LOS-distance, Speed, Voltage and RSSI and home arrow.
Parity
Parity is offline Find More Posts by Parity
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
