Old Aug 31, 2011, 10:21 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
that one is also a little bit heavier, I plan on putting this on a pretty small plane.
yzguy is offline Find More Posts by yzguy
Old Sep 01, 2011, 12:16 AM
foot8sativa is offline
Find More Posts by foot8sativa
foot8sativa's Avatar
New Zealand
Joined Mar 2009
looks like it has been removed off HK
foot8sativa is offline Find More Posts by foot8sativa
Old Sep 02, 2011, 12:59 AM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
There is also another cheaper OSD on HK now similar to the E-OSD but with video in and out instead of just running in parallel.
http://www.hobbyking.com/hobbyking/s...Mini_OSD_.html
volto is offline Find More Posts by volto
Old Sep 02, 2011, 03:10 AM
Jancis is offline
Find More Posts by Jancis
Joined Aug 2011
Can administrator delete those offtopic messages for other devices? Guys, let's keep on topic here, can we help somehow with improving code for G-OSD?
Jancis is offline Find More Posts by Jancis
Old Sep 02, 2011, 05:30 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
Jancis, I posted that because it looks like its the same exact hardware but cheaper, that is on topic. Your post on the other hand, is off topic. He posted the code on the first post, if you think you can improve it, download it and take a hack at it.
Thanks.
Old Sep 04, 2011, 01:32 AM
jkrah is offline
Find More Posts by jkrah
Joined Sep 2004
G-OSD circuit diagram
Anyone have a circuit diag if the G-OSD ?
jkrah is offline Find More Posts by jkrah
Old Sep 05, 2011, 03:25 AM
callelj is offline
Find More Posts by callelj
CL-OSD developer
Sverige, Östergötlands Län, Linköping
Joined Apr 2011
I was working last night with implementing distance calculations using avrfix but but eventually found that it took to much space and didn't have enough precision for short distances...
esreis: But I found a bug in wgs84ToSec100 so now distance and bearing works great! Yay!
Of course precision gets worse with longer distances but should be good enough for most people. Still have some testing left to sort out any bugs still there.
When the distance and bearing gets better I'm going to focus on the display design...
I'ts hard to find time to work on this project so thanks for being paitient!
callelj is offline Find More Posts by callelj
Old Sep 05, 2011, 06:42 AM
esreis is offline
Find More Posts by esreis
Joined Apr 2009
callelj: Was looking like a bug... There will be a precision limitation, but should not be a problem for FPV. Other, more demanding, applications should use larger systems. The G-OSD with this software should be just about perfect for small models in short flights (probably 85% of almost everybody's flights)
esreis is offline Find More Posts by esreis
Old Sep 05, 2011, 06:50 AM
callelj is offline
CL-OSD developer
Joined Apr 2011
Yes, true. Will do some test to see where the limit is for your implementation but my guess is that <1km should work without any problem.
Btw: I saw another osd that set home pos once speed was greater than a limit. I think that's pretty smart.
Old Sep 05, 2011, 07:16 AM
esreis is offline
Joined Apr 2009
yes. the best approach, no other things considered, is a button, but may spoil the G-OSD's size and simplicity. The apache OSD (from the same manufacturer as the G-OSD) defines home when senses speed > 10km/h. A tuning gps may send bad fixes with speeds greater than that, though.
Old Sep 05, 2011, 12:12 PM
Slaphappysamy is offline
Find More Posts by Slaphappysamy
United States, TX
Joined Oct 2010
There is a button on the G-OSD (The one I have has one).
Slaphappysamy is offline Find More Posts by Slaphappysamy
Old Sep 09, 2011, 04:06 PM
Jerry Campbell is offline
Find More Posts by Jerry Campbell
Jerry Campbell's Avatar
United States, OR, Blodgett
Joined Apr 2011
Hello Friends,
Well, I have the G-OSD and the programmer. As soon as I find some 2mm pins I'll be ready.
I'm wondering how the programmer hooks up to the pins on the board. The board has 6 pins 2mm pitch and the programmer cable has 2.5 mm pitch in two rows of 5 pins. Is there an adapter?
Thanks to callelj and esreis and anyone else who has worked on the software for turning a sows ear into a silk purse.
Thanks again and I will surely send a few bucks your way.
Jerry
EXI 450 soon to be FPV trainer
Jerry Campbell is offline Find More Posts by Jerry Campbell
Old Sep 09, 2011, 04:12 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Originally Posted by Jerry Campbell View Post
Hello Friends,
Jerry
is there a new firmware version already for use ?
i3dm is offline Find More Posts by i3dm
Old Sep 09, 2011, 04:19 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Jerry Campbell: No adapter as far as I know. You have to make your own...
Se the project page or first page for pinout on G-OSD.
i3dm: CL-OSD is not ready for use yet. But I hope I will get there soon.
BTW: Thanks for all the donations so far!
I will add all donators to the project page or in the code but if someone don't want that, please tell me.
Old Sep 10, 2011, 04:53 PM
callelj is offline
CL-OSD developer
Joined Apr 2011
Today I have done some emulations of different positions.
I selected one position in sweden, one in south america and one in north america.
Bearing and distance was correct for all positions.
I used different distances on all thre points (1km, 500m, 100m).
Also tested different distances at same angle (45 deg) and it gave good bearing and distance up to 10km.
At 25km it gave bad bearing and distance was to low.
So to summarize:
As long as you atleast stay under 10km you should find your way home.
Although I would recomend not to fly more than a 1-2km just to be safe.
Still have some work with GUI but seems like it's moving in the right direction.
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
