Old Sep 08, 2003, 11:50 PM
jason_ices is offline
Find More Posts by jason_ices
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
How fast 400motor can go?????
did any body know how fast cheap 400 can motor can go..... what kind of plane and setup their using??? Want to try a high speed plane with low $$$
jason_ices is offline Find More Posts by jason_ices
Old Sep 09, 2003, 12:11 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
pylon racer w/ Rocket speed 400 motor.
soholingo is offline Find More Posts by soholingo
Old Sep 09, 2003, 01:28 AM
davidfee is online now
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
The fastest S400 model I have seen or flown is a Sobakin Stinger 400. It's a fully molded composite ARF, so it's not cheap. If you want low $$$, build yourself a small model like it. You can see a 3-view drawing at http://www.aerodesign.de/ .
have fun,
David
davidfee is online now Find More Posts by davidfee
Old Sep 09, 2003, 03:00 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
This is the model that wins most, if not all, pylon 400 races in Belgium. Fastest times around 80s for 10 laps. As the course is 100+100+20= 220m long, the "minimal" average speed thus calculates to ((220m*10)*3600)/(80*1000) or 99KpH. Straight line speed must therefore be way over 100Kph. This is with 7 cells and a 6V SP400 type motor. With 8 cells you can get it a bit faster still...
WimH is offline Find More Posts by WimH
Old Sep 09, 2003, 06:47 PM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
what kind of motor is that 6V SP400? any one have pic of Sobakin Stinger 400?
Old Sep 09, 2003, 07:26 PM
RocketRob is offline
Find More Posts by RocketRob
Size Matters!
RocketRob's Avatar
San Francisco Bay Area
Joined Dec 2002
If you do a search on Stinger you should find photos or I think there are several in this thread
http://www.rcgroups.com/forums/showt...hreadid=133165
RocketRob is offline Find More Posts by RocketRob
Old Sep 09, 2003, 07:58 PM
rroback is offline
Find More Posts by rroback
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
for a little cheaper you can go with a switchblade from cavasos. I used that as my first fast plane, I had it running a 6v speed 400 ( went through 4 differernt ones) spinning a 5x5 or a 4.7 x4 or 4.7 x 4.7 on 8 or 9 cells. 9 cells was a little faster but wasn't really worth it. the fibers in the glass wing were splitting becuase of the forces i put it through. 3/4 throttle climbs and then full throttle steep dives and quick/lows pullouts worked it hard.
rhett
rroback is offline Find More Posts by rroback
Old Sep 10, 2003, 11:39 PM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
last night do some modification to my gws 400 motor, i retimed it and turn CCW. Amps reading was 12 amp with 4.6 X 4.5 prop (modify), 8 GP 1500mah nimh cells and 30A speed controller. what do u guy think it's good or bad ? If bad how do i improve the peformance?
Old Sep 10, 2003, 11:53 PM
Peter Khor is offline
Find More Posts by Peter Khor
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
You can get a couple more rpm off a GWS 400 by removing the flux ring, which is standard iirc.
Peter Khor is offline Find More Posts by Peter Khor
Old Sep 11, 2003, 01:08 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
The fastest setup I have ever flown or heard of was the 4.8V motor on 6 cells and a 4.5-4.1 Well over 100mph in any 400 racer you have. Prior to that, the Rocket was the hot ticket. Neither of these last very long. You'll get 2 flights out of the 4.8V motor and 3-4 good flights out of a Rocket. All this is assuming you do a race prep on the motors, but doesn't include comm drops.
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Old Sep 11, 2003, 01:41 AM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
what is flux ring?? where does it local?
Old Sep 11, 2003, 01:56 AM
Peter Khor's Avatar
Joined May 2002
If this is the Speed 400 motor you got from GWS ... notice around the outside of the motor case there is a metal band? it's just clipped on and can be taken out easy. What flux rings are for, do a search on rcgroups ... basically lower amp draw of the motor, and rpm at the same time, increase efficiency.
Old Sep 11, 2003, 10:27 AM
Joined Dec 2000
In my travels to make the 'bestest' Sp400 pylon motor, I found the flux ring to have as much effect on the motors as two empty boxes of Kleenex. I haven't seen any amp draw reduction on the bench, something I was hoping would make the motors last longer.
Dave
Old Sep 11, 2003, 02:15 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
2 flights with a 4.8V...gasp!!!
even as cheap as it is, going brushless will soon be the choice.
Personally, due to the cheap brushless and esc around, I only have megas. What a great motor! last setup is over 350W..
luc is offline Find More Posts by luc
Old Sep 11, 2003, 02:40 PM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
w/ a flux ring the motor will produce less RPM if everything else
stays the same (prop, cells, gearing).
But it will be more efficient and draw less current.
The Other Dave is offline Find More Posts by The Other Dave
Discussion How Fast Did You Go? msnyder Micro Ready-to-Fly 17 Aug 14, 2007 03:46 PM
Discussion How Fast Will This Go? andrewwells13 Flying Wings 3 May 23, 2007 01:46 PM
how fast do they go? ifli2 On-road Cars 1 Aug 16, 2005 12:18 AM
how fast will this go NoS Electric Power Cars 4 Apr 10, 2005 12:23 AM
How fast do they go ? any way ? American Flyer Parkflyers 0 Jul 09, 2004 09:05 PM
