Espritmodel.com Heli Air
Old Sep 23, 2012, 11:48 PM
kremecheze's Avatar
queens,ny
Joined Jun 2007
put enough power through her and you can handlaunch it, i had 1400 watts in my het f16 and i could handlaunch her
kremecheze is offline Find More Posts by kremecheze
Old Sep 24, 2012, 11:46 AM
MAAC 79785
rcgeorge29's Avatar
Kimberley BC Canada
Joined Sep 2009
I got mine last week, have a few projects to finish up first..but I have a cool 42 for 4s that I'm gonna put in her...should be a bullet!
rcgeorge29 is offline Find More Posts by rcgeorge29
Old Oct 07, 2012, 02:47 PM
" EMBRACE THE DARK SIDE '
rudeboy579's Avatar
Joined Nov 2011
hi all
ok maidened my f-16 on saturday,all went well and hand lauched in less than 5kmh wind gust(as there was almost no wind)she seemed tail heavy on the first flite,we were using a 2600mah 45c bat but still went ok:
Rudy's Hobbyking F-16 70mm Fiberglass flight 1 at PP (4 min 42 sec)
,then we went for the 3700mah 45c with a revised c.g and seemed still a bit tail heavy but went better:
Rudy's Hobbyking F-16 70mm Fiberglass flight 2 at PP (3 min 13 sec)
all up she seemed very touchy and c.g has to be right to get that bird going properly.hand lauch is very possible with some head wind,landings were ok,not the best glider bust still ok,all up she a good flyer,fast but i still love my f-15's
cheers
rudy
rudeboy579 is offline Find More Posts by rudeboy579
Old Oct 07, 2012, 06:40 PM
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Nice one Rudy, your's as least is hand launchable and has good speed.
Mine is slower than some of my foamies and requires a bungee to launch- obviously something is wrong with mine. I suspect the battery isn't delivering the volts required.
Slaanesh is offline Find More Posts by Slaanesh
Old Oct 07, 2012, 07:40 PM
Jetnfast's Avatar
United States, MO, Warrensburg
Joined Feb 2008
Nice maiden, and hand launch! Fan sounds nice as well.
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 08, 2012, 08:10 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Good stuff Rudy!!
vettster is offline Find More Posts by vettster
Old Oct 09, 2012, 06:15 AM
rudeboy579's Avatar
Joined Nov 2011
cheers guys i'm just happy she came back in one piece to be honest
Old Oct 09, 2012, 09:40 AM
AMA#900532
rifleman_btx's Avatar
Joined Sep 2006
I have one of these on the way. I like the concealed servo setup. I think thats how I will set mine up. Not only clean, but also like the fact they are protected.
rifleman_btx is offline Find More Posts by rifleman_btx
Old Oct 21, 2012, 10:40 PM
AMA#900532
Joined Sep 2006
got mine together, went to fly, but didn't feel right so waiting for another day
Old Nov 02, 2012, 05:06 PM
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I picked this one up from Vettster BNIB, He has gone on to turbines and selling all his EDF stuff. I started with the tail, I used some 3/8" spruce stock that I counter sunk the bearings into to support it at the fuse. At the momment I am thinking taileron control only. This worked fine on my HET F-15 and the Phase3 F-16 and eliminates unnecessary weight.
davecrash is offline Find More Posts by davecrash
Old Nov 02, 2012, 05:38 PM
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Hey fellas I just bought one of these as well..Will start on it some time this week..
Looks like i will try to high power setup first and go from there..plan on bungee launching it because of weight but will see once built...
My 3300's slide in well and i will probably do away with the batt tray and put a piece of 1/16 ply in its place but as low as i can get it...
So it will be 6s 3300's 65c and the het 1w40 and a 120 hv castle esc.....
I appreciate all the pics and info you guys have posted so far as it should make the build easier..
Is it ok to throw a few build along pics in here when I get started?
How are you guys running the horizontal on this thing?Elevator and ailerons or taileron and aileron...It seems like the discovery channel documentary showed the jet using a pure elevator as I do not remember seeing the planes work independently of each other and seemed to work as a single unit?
I have a utube link for the documentary if you gus would like to see it?
Thanks fellas and take care.........Chris
Hover or die is offline Find More Posts by Hover or die
Old Nov 02, 2012, 05:44 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I have a bl32 motor, CS10 fan and going 6S or a 2W-20 on 4S.
Old Nov 02, 2012, 05:46 PM
Joined Mar 2011
Davecrash,
On your bearing block...did you just epoxy it to the inside of the fuse...
Great idea and i plan to do the same..i cannot undesrstand why there is not some wood in there to support that bearing...I guess this is why we can get it cheap and modify our selves...
Old Nov 02, 2012, 05:53 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Originally Posted by Hover or die View Post
Davecrash,
Yes, very simple mod. Using the supplied inner braces the tail surfaces are only on a slight downward angle, If you want more like the real plane you will need to make another hole. I used the existing one.
Old Nov 06, 2012, 02:59 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
The build is coming along, I have however come across the flaking issues others have reported. I will finish and fly it first before I address that problem. I also find hiding in my work shop one of Don's BL3600 motors in a HET fan. I had this in the HET F-15 before I lost it last summer. It was quite a hot setup. I'm thinking of putting it in this one. Don stopped selling those motors, I bought 2 on his close out sale.
Sold sold Chopper1 Aircraft - Electric - Jets (FS/W) 1 Jul 26, 2011 04:47 PM
Discussion HK 70mm fibreglass F-16 Frenche Electric Ducted Fan Jet Talk 4 Jul 18, 2011 03:20 PM
Sold eRC F/A-18E Super Hornet, Freewing 70mm F-16, Starmax 90mm F-16 Roswalt Aircraft - Electric - Jets (FS/W) 13 Dec 31, 2010 12:03 PM
Sold GIANT 90mm F-16, 90mm F/A-18, 70mm F-16.. TX LPU Roswalt Aircraft - Electric - Jets (FS/W) 28 Nov 10, 2010 05:35 PM
Poll hobby lobby 70mm A-7 vs 70mm F-16 vs 70mm F-4 appleflyer Foamy EDFs 6 Jun 29, 2009 09:33 AM
