Old Jun 08, 2012, 03:48 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
ive been seriously considering buying this one too. problem is, i just bought the phase-3 f-16, so ive already spent my budget on it. you cant beat the price & quality HK offers. been eyeballing the 70mm viperjet too.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Jun 09, 2012, 11:20 PM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
u might as well go for the HK F-18 fibreglass 90mm jet. just a few more dollar to US$133....
viperviper is offline Find More Posts by viperviper
Old Jun 15, 2012, 08:04 PM
Refalovala is offline
Find More Posts by Refalovala
Joined Jun 2011
Here is a videoon the retracts that I put in it. and more.
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts 2 (6 min 59 sec)
Refalovala is offline Find More Posts by Refalovala
Old Jun 25, 2012, 11:09 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
I just receive this little F16 . I'm planning to bungee the plane. I did not receive any instruction. building is OK, but where is the CG ?
Thank you in advance.
J-C
bidule is offline Find More Posts by bidule
Old Jul 03, 2012, 09:17 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
I flew mine yesterday. Bungee . Guess all the control throw and Cg . Ailerons was to much and the first minute was tense . But flew very well.
Het fan, ARC 28/47/2 Turnigy 60 amp ESC 6 2200 mah GEN ACE cells .
Good jet for the $ and thank you for the CG info's.
Old Jul 16, 2012, 03:15 PM
Joined Jun 2011
Repaired F16
Finally had a chance to fix my f16. Here are the before and after videos.
Before:
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts (4 min 48 sec)
After:
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts (7 min 31 sec)
Old Aug 08, 2012, 10:47 AM
lomcevac913 is offline
Find More Posts by lomcevac913
RC Pilot!
lomcevac913's Avatar
United States, NC, Salisbury
Joined Sep 2011
Flew mine for the first time yesterday. Only mishap was the canopy flew off on a high speed pass. I decided to keep mine a little lighter by leaving out the aileron servos, and setting up tailerons. Used the E-flight V-15 fan and motor on four cells. Moved CG back to 81mm from LE and plane flies great, plus it is light enough to hand launch.
lomcevac913 is offline Find More Posts by lomcevac913
Old Aug 13, 2012, 08:27 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
The manual quotes between 70-75mm. 81mm isn't too much further back. There are reports that on HET F-16s going back to 85mm and even 90mm but I am wondering if this effects your elevator's neutral pitch?
Most F-16's I've seen - including HET's F-16 - have a bit of "up elevator" for neutral flying.
I would start at 75mm CG and have a bit of up elevator trimmed in as neutral. That is the leading edge of the Horizontal Stab is closer to the bottom of the fuselage fairing and the trailing edge is nearer to the top. About 3mm or so - better that it goes up rather than down as height is your friend
Slaanesh is offline Find More Posts by Slaanesh
Old Aug 15, 2012, 12:03 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
This one seems to be half the cost of the HET, is the performance/quality similar?
I'm looking for 120mph+ (Will a 6S 4000mah pack fit?).
Is there a manual online?
thanks for any help!
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Aug 15, 2012, 12:41 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
This is a 4S jet or small 6S.
It's supposed to weigh 1350g ready to fly! A 6S 4000mah pack weighs half that.
Old Aug 15, 2012, 06:19 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
I flew mine with a 6S packs but only 2200 GEN Ace or two 1300 6S in parallel.
4000 you will have problem with a very nose heavy. My last flight I use a CS 70 mm fan with a Het 2-25 but the motor is to hot ...Any suggestion for this fan? sounded great for a 3 min. flight!
Old Aug 15, 2012, 01:28 PM
Canada, ON, Vaughan
Joined Oct 2009
3min flight is really good only using a 2200mah pack. That motor on 6S is probably 90+amps, that's why it was so hot. Use 4 or 5S.
PS how do you launch it, and what kind of speeds were you getting?
Old Aug 15, 2012, 01:30 PM
Canada, ON, Vaughan
Joined Oct 2009
Whats the biggest 4S that would fit/balance?
I'm thinking of powering it with a CS10-70mm and Turnigy L2855 2800kv
Old Aug 15, 2012, 07:39 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
I "m using a catapult . 4S is not so good for this motor. I think you can fit a 3S 3300 mah
Sold sold Chopper1 Aircraft - Electric - Jets (FS/W) 1 Jul 26, 2011 04:47 PM
Discussion HK 70mm fibreglass F-16 Frenche Electric Ducted Fan Jet Talk 4 Jul 18, 2011 03:20 PM
Sold eRC F/A-18E Super Hornet, Freewing 70mm F-16, Starmax 90mm F-16 Roswalt Aircraft - Electric - Jets (FS/W) 13 Dec 31, 2010 12:03 PM
Sold GIANT 90mm F-16, 90mm F/A-18, 70mm F-16.. TX LPU Roswalt Aircraft - Electric - Jets (FS/W) 28 Nov 10, 2010 05:35 PM
Poll hobby lobby 70mm A-7 vs 70mm F-16 vs 70mm F-4 appleflyer Foamy EDFs 6 Jun 29, 2009 09:33 AM
