Old Sep 08, 2003, 11:36 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
1406/2y w/ 3.7:1 what setup and plane?
Looking to put this into a hotliner plane. Any idea on what props to put on this motor on which cell counts?
Jay
soholingo is offline Find More Posts by soholingo
Old Sep 09, 2003, 12:16 PM
Dr Spark is offline
Find More Posts by Dr Spark
Joined Jul 2000
Why your Wingo on eight cells and an 11*7 prop of course!
Dr Spark is offline Find More Posts by Dr Spark
Old Sep 09, 2003, 01:04 PM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
this motor has been used in 10 cell F5b with a 15" folder and about 70 amps. For short bursts, of course. For more sedate flying, 10 cells and a 13 or 14" prop will be fine.
With 7 cells, you would need a big prop.
twest is offline Find More Posts by twest
Old Sep 10, 2003, 11:07 AM
RobII is offline
Find More Posts by RobII
Oakland Ca. in an old warehouse, lots of room but no rooms...
Joined Sep 2002
Hey now,
I've got one of those motors, I haven't found anything like the right plane for it yet. I got it used in a "Jerry" it was slowish and not much fun to fly. Right now I've got it in a DCH Super Dragonfly
It's much better there, 70* climb out, plenty of power and almost fast. I'm running it with a 14x9 prop with a 25* hub on ten 2400cps I'm getting 48.6 amps with this set up.
I too would like a better model for this nifty motor although I s'pose I could put it on that old Wingo;-)
RobII
RobII is offline Find More Posts by RobII
Old Sep 10, 2003, 12:14 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Paul Willenborg has this set up in his Bonito. I Have the 1409 2y 2.5:1 in mine with a 14 9.5 prop.
Kirby
kepople is offline Find More Posts by kepople
Old Sep 10, 2003, 02:47 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
I am thinking of putting it into my Nike. With a 40 amp controller. with a 16x10 prop 10 cells....
jay
Old Sep 10, 2003, 10:48 PM
Paul Willenborg is offline
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
Jay,
You're going to need a lot more controller with that prop on 10 cells- it'll be drawing 70+ amps! My Bonito pulls 60+ on 10 cells with a 14 x 9.5. This is a great low-cost motor- I have literally several hundred flights on my Bonito over a five year period, all at 60+ amps, motor and gearbox are still humming along.
Just switched to 2600 nimh packs from 1250scr's, gained a bunch of weight but also gained a bunch of run time. I consistently get 30 minute flights in dead air. If I work a few thermals I often land without running the pack out.
Paul
Paul Willenborg is offline Find More Posts by Paul Willenborg
Old Sep 10, 2003, 10:54 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
RobII,
Just re-read your message- if you're using the 3.7:1 gearbox you should be seeing much higher current with that setup. Check the pack, or if you're running a higher ratio get a bigger prop or run more cells. For glider use this motor really wakes up at the 60+ amp range.
Paul
Old Sep 11, 2003, 10:25 AM
RobII is offline
Joined Sep 2002
Hey now,
You think? I got it used and was told that was the GB, but I could be wrong. I checked it with an astro watt meter, graumpner 14-9.5 with a 25 degree hub (I was told this was like running a square prop) I wonder if the hub is reversed? which side is front?
on ten 2400cp cells, 48.6 amps consistant.
According to the Aveox web site that's about right. Hmmm
They also say that's a lot of amps for this motor...
You guys are really running them at 60-70 amps?!? uff da! that's some power.
I'm really new at this big plane high power thing.
untill I got this my idea of high power was a CSD twister with a Kontronic fun 400-23 on 8 he cells...
RobII
Sold Aveox 1406/2Y Motor, 3.7:1 Planetary Gearbox with L260 ESC Don Leitz Aircraft - Electric - Power Systems (FS/W) 1 Oct 28, 2006 10:00 PM
b50-12XL w/3.7:1 gear,opto77-3p,ubec,battery packs ishu4u Aircraft - Electric - Airplanes (FS/W) 5 Jun 15, 2003 10:00 AM
Plane for sp 480 w/ 3.7 to 1 flying fish Sport Planes 2 Nov 15, 2002 06:14 PM
Aveox 1412/2Y W/3.7:1 PGB [F27 equival] Ray Fulks Aircraft - Electric - Airplanes (FS/W) 2 Feb 19, 2002 07:35 AM
Aveox 1406/2Y with 3.7:1 Planetary Gearbox (NIB) Ed Lyerly Aircraft - Electric - Airplanes (FS/W) 1 Jan 18, 2002 08:39 PM
