Old Aug 16, 2011, 10:31 PM
Duane is offline
Find More Posts by Duane
Duane's Avatar
Arlington ,Tx ,USA
Joined Dec 2000
Can I hook up external servos on Cox/Nine Eagles Rx?
Lost the gears on the factory servos. I don't think I'll add too much weight, I'm only going to replace the elevator servo with a normal micro servo. I don't know how to wire it up, looking for ideas? Motor seems easy enough, two wires, but I'm not sure about the others. I hope the pic shows up ok...
Duane is offline Find More Posts by Duane
Old Aug 16, 2011, 10:57 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Don't think you can get a servo pulse out of that board and use a 3 wires servo, but you can get a spare Rx(Receiver Set COXL5818 )for it here as it is the same as Skyranger:
http://coxmodels.com/airplanes/coxa6...ger/index.html
coriolan is online now Find More Posts by coriolan
Old Aug 17, 2011, 09:36 PM
Duane is offline
Duane's Avatar
Arlington ,Tx ,USA
Joined Dec 2000
I've seen the parts for somewhere around $60.00, way too much for it. I think the bind n fly from 9 eagles is around that. This is someone elses, and I thought maybe I could fix it. I was hoping to wire something in.
Old Dec 16, 2011, 08:55 PM
Skippy_82 is offline
Find More Posts by Skippy_82
Joined Dec 2011
Servo connection for nine eagles RX
Hi all,
I have a sky eagle and lost the servo gear on the RX on the first night flying.
A dog in the local park took the plane after landing and broke the tail wing/elevator. The force knocked off the servo gear which was then lost as the dog took my plane for a wander around the park
Not wanting to buy a new RX which cost 2/3rds of a new plane. I managed to wire a micro servo to the RX board. It is possible!!!
You need to remove the original linear servo and trimpot on the PCB.
Then you can open up a standard micro servo. Run wires to the trimpot in the micro servo onto the PCB (connect in where the original trimpot was). Then extend the motor wires from the micro servo to the PCB (on the back where the original linear servo motor connected).
If the servo stalls/wont move but sounds like it's trying to move disconnect battery and reverse the polarity on the servo motor wires.
If you need to reverse the servo throw simply reverse polarity of the servo motor AND the outside contacts of the trimpot.
Hope this helps someone!!! Now you can replace the linear servo with micro servos. May add a small amount of weight but is a cheaper option then replacing the whole RX "brick"
Skippy_82 is offline Find More Posts by Skippy_82
Old Dec 20, 2011, 09:55 PM
Duane is offline
Duane's Avatar
Arlington ,Tx ,USA
Joined Dec 2000
Cool I need pics! I have about given up and started gutting this thing, I hope I can put it all back together.
Old Dec 23, 2011, 03:31 AM
Joined Dec 2011
Hi,
Only have a few pics hope they help. The servo is now installed and glued in so won't be able to show the finished wiring inside the servo.
Description:
Here is the back of the rc board. I replaced the rudder servo. Unsolder the red and blue wires going to the servo motor. Remove the tiny screws that hold the servo onto the pcb. Then unsolder the 3 trimpot legs for that servo. (If you look at the bottom pic you can see where the trimpot connects from the other side). Then remove the oem servo assembly.
Description:
Take the bottom cover off the micro servo (I haven't seen digital servos but im guessing they are diffferent!? use standard analog ones)
Remove 3 wires from the trimpot and solder on longer ones to connect to your rx board as shown in picture below. Extend the motor wires and solder onto the contacts where you removed the original servo motor wires. Refit bottom cover and then test servo direction before you mount the servo in the plane.
If the servo doesn't respond to your stick controls but tries to drive in one direction and stalls on the throw stops then reverse the motor polarity.
If the servo responds in the opposite direction to stick input (for the way you mount the servo) then reverse polarity on BOTH the motor and the trimpot outer wires only (leave center connection of trimpot where it is).
Once the servo tests ok and moves in the desired direction to the stick input you are ready to glue the servo into the plane. I found 3min epoxy works really well!
I used a small screw (cut down) put directly into the servo horn to connect the oem pushrod.
Description:
Your finished rx board should look something like this. Motor wires are soldered on botton of pcb.
Old Dec 23, 2011, 06:50 AM
Starry Xu is offline
Find More Posts by Starry Xu
Joined Dec 2011
May be you can look for some servos as replacement. Once I went to the International Shanghai Model Show on April 2011. I found the smallest servo that only weigh 1.7g, 1.9g, but they are digital ones.
Starry Xu is offline Find More Posts by Starry Xu
Old Dec 28, 2011, 09:47 PM
Duane is offline
Duane's Avatar
Arlington ,Tx ,USA
Joined Dec 2000
I think I understand now! Thanks!!!
Old Dec 29, 2011, 09:49 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Hobby King sells a rotary digital servo (the 5320 servo) that is "1.7g" (actually weighs about 1.9g on a scale). There is a RCGroups thread on it also:
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
http://www.rcgroups.com/forums/showt...1476183&pp=100
Hobby King also sells 2g to 2.6g analog servos (the 282 and 282A servos) that weigh a little more and have more torque.
flying-llama is offline Find More Posts by flying-llama
Old Apr 07, 2012, 03:43 AM
Tsport is offline
Find More Posts by Tsport
Tsport's Avatar
Poland, Mazowieckie, Warsaw
Joined Mar 2012
Hello I have noticed that you have quite good knowledge about Nine Eagles PCB.
Maybe you could help me with PCB in my Sky Eagle NE770B.
I try to explain my problem in this topic http://www.rcgroups.com/forums/showt...1240597&page=6
Do you have any idea how to repair it?
Thanx in advance for your help.
Tsport is offline Find More Posts by Tsport
Old Jun 13, 2012, 12:53 PM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
subscribed
bushpilotx1 is offline Find More Posts by bushpilotx1
Discussion Can I hook up my laptop for FPV? Canada Goose FPV Talk 5 Jul 28, 2011 01:14 PM
Discussion Need servos for Cox Extra/Nine Eagles Duane Scratchbuilt Indoor and Micro Models 7 Jul 17, 2011 09:55 PM
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold Nine Eagles / Cox Extra 300 (minus Tx) dhaizli Aircraft - Electric - Airplanes (FS/W) 4 May 01, 2011 07:36 PM
Discussion Cox or Nine eagles 300 extra range problems. shazamrc Scratchbuilt Indoor and Micro Models 0 Mar 15, 2011 07:27 PM
