Old Oct 25, 2011, 05:22 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by kingjedix View Post
i try the old rc711 coupon for 20% discount for all alzrc parts thats fortunately include the gyro.
What's the 20% discount code please ?
MikeHRC is online now Find More Posts by MikeHRC
Old Oct 25, 2011, 05:59 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The RC711 ALZRC discount code is: ALZ20
beenflying is offline Find More Posts by beenflying
Old Oct 25, 2011, 07:52 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Bugger - tooo slow, on backorder. Oh well, ordered anyway
Old Oct 25, 2011, 11:53 PM
pilotonovato is offline
Find More Posts by pilotonovato
Joined Aug 2011
Can someone tell me the difference between the f3c and soft3d settings of this unit?
Btw, I just installed the helicox unit. Its same as this one, same menus and settings. Just my program box have a cool blue backlight.
If you follow the steps in the manual, setup process can be simple. And its important to set servo type before plug them or you may fry some fresh servos (I fried one, ROFL).
I' ve set in beginner mode. Arms movements are pretty soft. I bet this setting will be a coaxial 6ch heli. ROFL. I will change that as soon i maiden this unit.
I didn't find cyclic range too, but I read somewhere theses units, as vbars, don't work that way and we need to forget about cyclic degrees and think about gains and agility. Lot of info to learn. Btw, I am having 12 degrees on cyclic (damn, need to forget that, old habit).
I don't know if I am right, but that does not mean you will have a ultra cyclic uncontrollable berserker mode heli, but the unit, in my case, will have like 12 degrees to keep up the settings straight as programed. I don't know how to clearly explain that, my english sux.
Just one note:
Apparently D/R on tx did not change anything on arms movements.
Any ideas?
Thank you and GREAT TOPIC.
NICE FLIGHT VIDEOS!
pilotonovato is offline Find More Posts by pilotonovato
Old Oct 26, 2011, 12:13 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Hi. The difference between F3C and soft 3D is the F3C tail has less acceleration and a softer hold and the cyclic is more like beginner with slightly more agility.
My understanding is the blue backlight displays do not work well in the sunlight. Can you confirm this?
Re the cyclic range, see my post in the ZYX thread:
http://www.rcgroups.com/forums/showp...3&postcount=46
So DR will affect cyclic in flight, but not on the ground. With 12 degrees of collective range, try starting with 80% DR and see how it goes for you.
Old Oct 26, 2011, 12:33 AM
Joined Aug 2011
Thank you for your answer.
I will check the the program box at sunlight and post a feedback later. Its a very bright blue with white characters. Better, I will post pictures at night and day
Here goes some pictures of building process.
Cheerz!
Old Oct 26, 2011, 12:51 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks. Really nice job on that build.
How do you find the speed of those ES08MA servos? I have some ES08MD's coming.
Old Oct 26, 2011, 01:40 AM
Joined Aug 2011
I have both here, MA and MD
MA: 1.8~2kg - 0.12/0.10
MD: 2~2.4kg - 0.10/0.08
Using the program box servo test the MA version is doing 0.7~0.8, but no load on it. MD gave me 0.7 always.
http://test.yinyanmodel.com:7323/En/....asp?SortID=13
Old Oct 26, 2011, 01:52 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks for the info. Good to see those test results.
Old Oct 26, 2011, 02:23 AM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Cheerz!
That looks very nice. what heli is it?
Dr.M is offline Find More Posts by Dr.M
Old Oct 26, 2011, 06:46 PM
Joined Aug 2011
Frame is from a Storm 450 carbon flybarless
Electronics are ramdon. I picked the ones I know are good for a reasonable price. Its not a expensive setup, but suppose to be good enough for sport flying.
Motor is a leopard, 3500kv.
Emax cyclic servo (very good for its price, all metal and fast)
3g gyro is a helicox, same as this ALZRC
I use walkera 8ch 2801 pro tx/rx (very good in my opinion - I also have a v450d01)
Tail servo is a must have. Its same as the v450d01 tail servo: WK-2601H:
Torque: 4.8V:28.0 oz-in (2.02 kg-cm)
Speed: 4.8V:0.08 sec/60
Main Blades are HD320D 325D 3G Carbon Fiber
Tail Blades are 3k carbon ones.
Used Align HOLDTITE Anaerobics Retainer
Gyro pad is Align K10457A PU Adhesive Gel - Looks good and seems to be better than regular ones...
As soon I test this setup with this new gyro i will post feedback.
Old Oct 26, 2011, 06:54 PM
Joined Aug 2011
Beenflying
I have a tail blade question for you.
Did you follow the manual and setup the tail pitch to be approximately 8? Or did u use less pitch?
Cheerz!
Old Oct 26, 2011, 07:06 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Beenflying
Cheerz!
No I didn't. I always use roughly center of pitch slider, which on the 450 Pro is close to zero pitch.
That's not to say it might be better if it was set to 8 degrees, but it seems to work fine for me so far.
Old Oct 26, 2011, 07:16 PM
Joined Aug 2011
thank you!
Old Oct 26, 2011, 07:30 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Looks like a nice servo.
I've been running some tests on the Fitec FS9357:
http://www.rcgroups.com/forums/showthread.php?t=1278171
I like that it can run above 5 volts like the DS520, and has more torque than the DS520. And it only weighs 25g (not the 27g stated in the link above). Seems like a very good servo so far, for the price ($16.90 shipped).
For Sale ALZRC 450 PRO FL Main Rotor Full Flybarless Upgrade Set (One Piece Design) pttse Aircraft - Electric - Helis (FS/W) 10 Aug 17, 2011 08:53 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 05:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 07:09 PM
Sold 3G Flybarless System Trex 450 Brand New rundown Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2010 05:56 AM
