Old Oct 15, 2011, 11:13 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
I also saw the Clubheli FBL head for the 450 as well. It includes the swashplate for 36 dollars and they are in the states (PA)..
ridge_racer is offline Find More Posts by ridge_racer
Old Oct 16, 2011, 09:25 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
ALZRC 3GYS Setup 1
Firstly setup a new model in the Tx. This needs to be a single (1) servo 90 degree type helicopter with no mixing. In some Tx's this is known as H1 or HR1.
Make sure all of your subtrims and trims are set to zero/center.
Here's my Tx model setup (click to enlarge):
Description:
Description:
Note: Don't connect any servos to the 3GYS at this time. This is because the servo type has not been set yet.
Power up the transmitter and the helicopter, and when ready plug in the data cable to the 3GYS. The program box backlighting will come on and it will download the current parameters from the 3GYS. When completed the display will show "Basic setup".
Description:
The menu structure works by using up and down to scroll the menus and enter to select it. Back is used to exit out of a select menu.
Enter is used to edit a value and back is used to accept the change. Enter does nothing when a value is selected for editing and there is no way to abort the change. You must set it back to where it was and then press back.
Press ENTER to select Basic setup. The display will now show "Monitor". Press ENTER again to select Monitor mode.
Description:
Note: make sure your throttle stick is at mid position or pitch is locked at 0.
1/ The screen shows the 4 channel positions from the receiver (A: Aileron channel, E: Elevator channel, R: Rudder channel, C: Collective channel). The aim is to use subtrim to get all channels to read 0 and the Tx reversing to get all of the direction indicators (L, R, U & D) working the correct way. You can use these direction indicators to find the exact center by watching them change i.e. L <-> R or U <-> D. Remember that U stands for up stick and not up elevator.
Note: make sure only one channel number changes when you move a stick up/down/left/right. If more than one channel number changes you still have some mixing enabled and this will need to be corrected.
2/ Now you need to use the EPA's to get the range correct. Each channel should display 100 when the TX stick is moved to full travel. If it's less than 100, increase the channels EPA value until it reads 100.
The above two steps will ensure that the stick travel is equal in both directions. I would also point out that these two steps are optional, and do not affect how the 3GYS flies, other than perhaps resolution, if you don't set the EPAs and the full travel is less than 100. The 3GYS learns the center stick at power up and most would not notice the slight difference in stick travel.
3/ Now press the DOWN/DATA- to see the gyro gain channel. An A or a N is displayed after the G: (gain) to indicate what mode the tail gyro is in (A for (AVCS) heading hold and N for (Normal) rate mode).
4/ Set your Tx for a gain of around 36 in heading hold mode (A). This is done by adjusting the gyro gain channel or the Aux channel, depending on your setup.
Description:
I haven't figured out what the "Condition: 1" is yet. It says in the manual that there are two sets of parameters but I haven't found out where you can select them. Best to ignore it for now.
5/ Press BACK to exit Monitor mode.
That's all that's required for the monitor screen and that's most of the Tx setup done as well.
beenflying is offline Find More Posts by beenflying
Old Oct 17, 2011, 03:25 AM
Joined Nov 2010
Hey beenflying...Just tracked a few of the items I ordered recently. In a nut shell, I believe I will receive the ALZRC 3 axis gyro and ALZRC FBL heli first. I have an HK450V2 waiting for my LH520 gyro but that's going through the swiss post. I'll just use this gyro for the tail only on the FB 450V2 until I get my order from HobbyKing with the electronics for the FBL 450.
Old Oct 17, 2011, 10:48 AM
Brubache is offline
Find More Posts by Brubache
If it hovers I fly it.
Brubache's Avatar
Canada, BC, Vancouver
Joined Jun 2010
Wow! Ordered Friday. Due to be delivered to me today Monday! Now thats some unreal shipping from HK to Canada!
Brubache is offline Find More Posts by Brubache
Old Oct 17, 2011, 11:27 AM
Pigs dont fly is offline
Find More Posts by Pigs dont fly
How high does it go?..duh
Pigs dont fly's Avatar
Currently in...UK
Joined Jun 2004
Does this box work on a Trex 250, does it hold the tail ok? I'm liking the prices
Pigs dont fly is offline Find More Posts by Pigs dont fly
Old Oct 17, 2011, 02:20 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
Just landed on my door step. First impressions:
Nice box. The gyro unit itself is VERY well built. Solid metal case and feels well put together. The programming unit is all metal and very nice. Includes programming cable and some gyro pads. The unit is also very compact, smaller than my Mini Vbar. No instruction in the box.
Now waiting for the rest of my package
Old Oct 17, 2011, 03:10 PM
Joined Nov 2010
Nice...Did you use EMS shipping??
Old Oct 17, 2011, 06:05 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Gosh, I just fitted the Align 3GX (that came off the 450 Pro, that now has the 3GYS) on the Align 450 Sport (using the new v1.2 beta firmware and Leon Luke's settings), and it flew absolutely terrible.
The 3GYS flies so much better and without the complexity of all the PC settings to try and get it to fly right.
I can't wait to hear what others here think about it.
@Pigs dont fly, I don't think anyone has tried it on a 250 yet. I was going to get one for my 250 but I thought I would hold off and allow others to get one first. I'm also not sure what head to use. I have the Align SE black head at the moment and all of the 250 FBL heads are silver. I also hear they are very soft aluminum, as well.
The FBL conversion kit is quite cool, but it still leaves you with trailing edge control, which I not sure is the best. I'm hoping ALZRC will bring out a 250 FBL head in black and silver.
Old Oct 17, 2011, 06:08 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
RC711 ems shipping did an auto upgrade to DHL Express Oh ya!
Really looking forward to compare to my Vbar!
Old Oct 18, 2011, 04:24 AM
hkpartscom is offline
Find More Posts by hkpartscom
Joined Feb 2008
Hi All
This is HK-Parts . We rarely speak here, but some of the necessary let you know
The 3GYS manual has been translated . Because of ALZRC is not have official English version of the manual. we get to help a senior electronics engineer, he understand RC heilcopter operation, because he is also RC pilots. Therefore HK-parts to invite him to help translate. If you find that your 3GYS no English manual, Regardless purchased of store where. You can also use this manual to setup your 3GYS. You can also download from our facebook page get the latest version and we will update if necessary. http://www.facebook.com/pages/HK-Par...65542893501820
We are grateful David to help here . his is electronic engineer from New Zealand, is are really great man. Helpfulness!!!
Cheers
HK-Parts wish you a happy flight
hkpartscom is offline Find More Posts by hkpartscom
Old Oct 18, 2011, 09:21 AM
Currently in...UK
Joined Jun 2004
Thanks beenflying..I guess I could flip the grips over, I did that already on the flybarred version..it fly's nicer
I keep looking at the 'V1' badge though, is there any facility for re-flashing with newer firmware later on down the line? Knowing my luck its locked down and they'll release an new version just as this one arrives in my postbox.
Old Oct 18, 2011, 03:28 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by hkpartscom View Post
Hi All
Cheers
Thanks for the kind words. It's very good of you to release your English manual for the 3GYS, for everyone to use. I'm sure it will be a big help to many, as it will make setting up the 3GYS much easier. Thank you!
Old Oct 18, 2011, 03:36 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
Well tonite the build starts. Got my ALZRC Pro Super Combo with metal upgrades for the batt etc. Sadly they neglected to put my motor and esc in the box... oh well. Should be fun regardless. Reports to follow of the ALZRC Pro Super Combo with the Flybarless unit!
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm not sure what it would require to flash the firmware, but I did note the led status in the manual that says "Gyro in firmware upgrade mode". So it must be possible.
Old Oct 18, 2011, 04:44 PM
IFHELI is offline
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
My HeliCox TG-1 arrived today and the instruction are basicly word for word as the 3GYS. The Gyro itself is the same size also but G-box is smaller. Here`s a few pics. I have bought the KDS EBAR, ALZRC, and the HeliCox. I have only test hover the KDS unit. Mine is working fine so far. I have the KDS in a Trex 450 belt drive heli w/ Quad head & Quad tail.
IFHELI is offline Find More Posts by IFHELI
For Sale ALZRC 450 PRO FL Main Rotor Full Flybarless Upgrade Set (One Piece Design) pttse Aircraft - Electric - Helis (FS/W) 10 Aug 17, 2011 07:53 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Sold 3G Flybarless System Trex 450 Brand New rundown Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2010 04:56 AM
