Old May 12, 2012, 05:07 PM
IFHELI is online now
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
I wish they would have given some information on it but not hard to tell whats good or bad. It`s show a chart/graph for main rotor and tail rotor and gives RPM. Then has green,yellow,red lines at rpm readings.
IFHELI is online now Find More Posts by IFHELI
Old May 12, 2012, 05:20 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
Originally Posted by Dr.M View Post
An additional problem with stainless gear is that threadlock doesn't really work. So if you use a ss FS with ss screws, chances are you're gonna get a blade grip fly off in flight.
in old days, if two surface are passive metal like stainless steel, you have to apply primer fiirst before put threadlocker on.
Now, we have new loctite 243 that can use for passive metal without use of primer or activator. It has improved oil tolerance resistant and temp resistant up to 180F.
wlee1017 is offline Find More Posts by wlee1017
Old May 14, 2012, 06:27 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I just want to confirm this with others. With the new 0.97a update, my 3GY unit now has a green blink on the #2 led along with the blue solid light when in flight/operational mode. It is not a constant blink, justa once in a while thing.
boredom.is.me is offline Find More Posts by boredom.is.me
Old May 14, 2012, 07:04 PM
IFHELI's Avatar
Joined Apr 2010
Mine has been doing it since the upgrade also.
Old May 14, 2012, 07:07 PM
Joined Nov 2007
This is a test with no main or tail blades. My question is - how does it determine RPM? These are the highest at the given throttle points.
Old May 14, 2012, 07:11 PM
IFHELI's Avatar
Joined Apr 2010
I wish I knew the answer to that question.....They need to release some information on how it is working.
Old May 14, 2012, 07:34 PM
ZeroPitch is offline
Find More Posts by ZeroPitch
What goes up, must come down..
ZeroPitch's Avatar
United States, CA, Mission Viejo
Joined Sep 2011
Any chance on moving the Robird G31 FBL convo to a dedicated thread? Getting confused on which gyro we're talkin' about ;-)
ZeroPitch is offline Find More Posts by ZeroPitch
Old May 14, 2012, 07:52 PM
Joined Nov 2007
I've actually been thinking the same.
http://www.rcgroups.com/forums/showt...0#post21613681
Old May 14, 2012, 09:01 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
You guys have been busy...lol...ok let me finally flash this new firmware as well since I have been at work all these past days. Going forward I will use the new thread for anymore updates.
ridge_racer is offline Find More Posts by ridge_racer
Old May 16, 2012, 06:16 PM
Friman is offline
Find More Posts by Friman
Joined Jul 2011
I understand that now that they have the V2 of rhe 3gy fbl system, The ALZRC 450 fbl super combo doesn't include the programing box in the combo any more?
Does the programing box suits the new V2 fbl system?
I'm about to buy the ALZRC 450 super combo these days, is the programing box is a must have (to order seperatly or is it manageable with the PC?
Friman is offline Find More Posts by Friman
Old May 16, 2012, 07:12 PM
Joined Nov 2007
No need for a box. It doesn't have the same plug either which might mean it isn't compatible.
http://www.rcgroups.com/forums/showthread.php?t=1652630
Old May 17, 2012, 12:30 AM
Friman is offline
Joined Jul 2011
Is the new 3gy system is better than Tarot's zyx..? Thinking aconomicaly, both helis cost preatty much the same for the super combi but the Tarot fbl system is cheaper in case I'll want one for my 500 as well. Does the new Alzrc 3gy worth her higher price?
And What are the main upgrades from the old 3gys fbl system?
edit - reading more and more about the new 3gy fbl system, I get the impression that this is not an upgraded fbl system but a complete new and different system, isn`t it?
Old May 17, 2012, 12:39 AM
Joined Nov 2007
I'm still learning how to setup helis, but I don't see anything wrong with it so far.
Please lets separate the 3GY discussion.
Old Jun 27, 2012, 10:20 PM
pilotonovato is offline
Find More Posts by pilotonovato
Joined Aug 2011
Here goes a small video testing the helicox unit on a windy day.....
450 Class - Setting up 3G Helicox TG-1 in a windy day Anfiteatro por do sol (1 min 52 sec)
I guess it tracks pretty good.
pilotonovato is offline Find More Posts by pilotonovato
Old Dec 07, 2012, 05:44 AM
GoElectric is offline
Find More Posts by GoElectric
Canada, AB, Edmonton
Joined Jun 2002
First time setting up the G31 gyro. All the setup seems fine except the ruder limit setup.
[Never mind, I did not check it properly]
1) In the Setup Guide -> 8 Tail & Cyclic Limit, I set the rudder left and right limit using the slider without mechanical binding. But after I click save, finish and disconnect usb cable, I still have a lot of travel and hitting the limit at less than half of the stick movement, it seems the gyro does not "remember" the setting. Did I setup anything wrong or it is something wrong with the gyro ?
2) In the setup instruction, the radio should have linear throttle and pitch curve, but after setting up, It seems I still have to enter the normal throttle and pitch curve, for example pitch from -1 to +9 ?
Thank you
GoElectric is offline Find More Posts by GoElectric
For Sale ALZRC 450 PRO FL Main Rotor Full Flybarless Upgrade Set (One Piece Design) pttse Aircraft - Electric - Helis (FS/W) 10 Aug 17, 2011 08:53 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 05:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 07:09 PM
Sold 3G Flybarless System Trex 450 Brand New rundown Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2010 05:56 AM
