Andover,MA.,USA
Joined Aug 2001
I will be very interested in finding out others' experience between the ALZRC and CopterX gyro. I have the CopterX on the EXI450 and just received the ALZRC. From what I see here, they seem to be the same thing. Am I correct ? The CopterX unit lock the tail pretty good but has a small wagging motion. Also, when doing very slow piro, the gyro seem to have a hard time and it just go like 20 deg at a time so it is not really smooth. Since I do not have the CopterX programming box, I am not able to fine tune it. Now that I know I can use the ALZRC box, I am going to follow MikeHRC's instruction and try it out today. Also, the ALZRC instruction has 2 selection for the 1520us tail servo with different freq but CopterX does not. Wonder if that is the problem. I am using the MKS DS480 servo for the tail.
MK |
Andover,MA.,USA
Joined Aug 2001
Just hook up the CopterX to the ALZRC programming box, it did not work with RX/TX plugged in. I then try the programming box on the ALZRC gyro with just the battery and it is also no go. Then I hook up the ALZRC gyro to the RX (only the rudder and gain ch) and wait for it to initialize. Then the programming box worked. I just got the ALZRC yesterday, apparently, they have changed the firmware. This is bad because I do not want to take 2 programming boxes to the field for 2 different gyro.
On the tail, as I mentioned that during a slow piro, the motion seem to be progressing in steps. What I did on both the CopterX and the ALZRC gyro is to observe the gyro with very little stick input. the servo will 'step' to a minimum of like 10 deg motion on both gyros which explain why the tail goes in step during slow piro. I have a BeastX so I try that on the BeastX and the servo is just smooth as silk in response to the very little stick input. If anyone know which parameter to tweak to eliminate the 'step' change in slow piro, please let me know. Other than that, the cyclic is quite good. MK |
Oxfordshire, UK
Joined Jan 2007
Kou,
Sorry if I confused you - I used the Copterx Prog box on the Copterx Gyro and the ALZRC box on the ALZRC gyro, what I had tried to do (unsuccessfully) was to programme the Copterx gyro before it had been fully initialised onto the Rx. Best wishes, Mike. |
I don't know their history or if they are trying to regain consumer confidence. Works for me. Todd |
Andover,MA.,USA
Joined Aug 2001
Change the ALZRC gyro dead band on the tail and tail servo is moving smoothly. Instead of changing the piro rate, I notice that the servo turn all the way up to half rudder stick and and any more stick input is not doing anything. So I change the ETA to 50 on the JR8103. I'll remove the CopterX gyro from the EXI450 and put the ALZRC on just because I do not have a CopterX programming box. The two gyro set up look virtually identical.
MK |
Don't be fooled by the rudder stick doing nothing after half way. In flight this will not be the case. It's only happening on the ground because the tail can't move, so the gyro keeps putting in more and more rudder to try to get it to move.
While reducing EPAs is another good method to increase the deadband effect on the stick, dropping it to 50 will probably give you a very slow piro rate. Think of it this way, whatever you set the EPA to is the percentage of the full piro rate, so 50 will give you 50% of whatever an EPA of 100 would have given you, 60 60%, 70 70%... |
Latest blog entry: RC Parts Suppliers - The Good and the...
Kauai
Joined Jan 2011
Hey Beenflying,
I read in one of these threads that you were trying the Ds115mg servos,I was wondering how they where working out for you?I just ordered a set to put in my Black Angel so was hoping I didn't make a mistake!Thanks for any info! Steve |
The bench test so far of the DST DS115MG is very good. When I get time I want to try it on a 450 tail. This showed the flaw in the MKS DS92 (slow to get moving, not good for gyro applications).
Here's a video with the DS115MG on both cyclic (FBL) and tail:
You're welcome. The emax should be good on the tail as long as the voltage is 5 volts.
Can I ask where you got your DS115MG's from? |
Joined Aug 2011
Also added a little bit of expo to don't catch the micro inputs when throttle up. Cheerz. |
| Thread Tools | |
| For Sale ALZRC 450 PRO FL Main Rotor Full Flybarless Upgrade Set (One Piece Design) | pttse | Aircraft - Electric - Helis (FS/W) | 10 | Aug 17, 2011 07:53 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Sold 3G Flybarless System Trex 450 Brand New | rundown | Aircraft - Electric - Helis (FS/W) | 0 | Apr 22, 2010 04:56 AM |
