New ALZRC 3GYS Flybarless System
I just found this new ALZRC 3GY FBL (flybarless) System on HK-Parts site:
http://www.hk-parts.com/alzrc-3-axis...ming-soon.html It says it's coming soon. Looks like lots of settings, including individual setting of P, I & D (PID = Proportional Integral Derivative) for tail and cyclic (most tail gyros use a PID system but usually a single gain for all three). I also found this ALZRC 450 Pro 3GYS video test flight on the ALZRC.com site: http://www.alzrc.com/en/InfoView.asp?/12.html Seems to fly really nicely. Could this be the low cost FBL system we have all been waiting for? Enabling the advance tuning menus Hold the BACK button when plugging in the programmer box, or powering on the helicopter with the program box connected. Keep the button held until "Basic menu" is displayed (see the below menu picture). I hold the skid with my fingers and have my thumb on the back button, while I plug in the programmer to the helicopter. You can also plug the data cable into the helicopter first, power on the helicopter and Tx, and then while holding the programmer box with the BACK button held, plug the data cable into the programmer. See the advance menu defaults attached below. Note: Only using these menus as a last resort. Most helicopters will fly well without changing anything in these menus. * USB link software: http://www.rcgroups.com/forums/showthread.php?t=1568592 Review posts: * Stand Alone Tail Gyro: http://www.rcgroups.com/forums/showp...8&postcount=19 * First impressions: http://www.rcgroups.com/forums/showp...5&postcount=20 * Installation 1: http://www.rcgroups.com/forums/showp...6&postcount=25 * Setup 1: http://www.rcgroups.com/forums/showp...0&postcount=62 * Setting the limits: http://www.rcgroups.com/forums/showp...&postcount=287 * Maiden flight: http://www.rcgroups.com/forums/showp...8&postcount=27 * Second flight: http://www.rcgroups.com/forums/showp...0&postcount=29 * Trex 500 3D flight: http://www.rcgroups.com/forums/showp...2&postcount=37 * Spectrum Rx connections: http://www.rcgroups.com/forums/showp...&postcount=258 Associated links: ALZRC 450 Pro SKD FBL (Flybarless) Head: http://www.rcgroups.com/forums/showthread.php?t=1491796 RC Logger Digital Pitch Gauge: http://www.hk-parts.com/trex-450-pro...tch-gauge.html Update: Official price: USD$115 with programmer, USD$75 Gyro only, USD$40 programmer only Programmer features: * Servo tester * Battery voltage monitor 3GYS features: * Size: 38.2mm x 26.2mm x 13mm * Voltage: 3.5 to 9 volts * Weight: 26g including cables * Full metal case * Has a status LED * Can be mounted on the side of the frame Note: The battery only needs to be connected to the programmer for voltage monitoring and servo testing. The Rx/3GYS power is used for programming the 3GYS gyro. Don't do servo testing using a battery connected to the balance port (like in the supplied pictures below), unless you are testing high voltage servos. The full voltage of the battery is presented to the servo power. For 5 and 6 volt testing connect a 5 to 6 volt battery/BEC/supply to the servo power socket, under the servo socket. |
Yes, I've been watching the progress of the KDS Ebar.
I think the Chinese are quite capable of doing this, but you are right that it requires a very good programmer to achieve something that will work well. I have faith that ALZRC will not release something that doesn't work well. Everything they are bringing out, at the moment, is such good quality. I'll be ordering one, when it's available, so I'll be able to let everyone know how well it works, especially compared to the 3G and 3GX, which I currently have. |
Latest blog entry: RC Parts Suppliers - The Good and the...
Here's another flight video I found for the ALZRC 3GYS:
http://www.alzrc.com/gb/InfoView.asp?/4.html |
If I made a guess, it would be beastX, but Skookum uses the programming box.
One thing I've found with FBL systems is that you can't have enough settings. You don't have to play with them all to start with. Let's say the heli flies pretty good but further down the track someone finds out that setting the P a bit higher in cyclic makes it fly even better, you can then go and change it, even if you have no idea what it does.
The ALZRC 3GYS is now released at RC711:
http://www.rc711.com/shop/alzrc-3gys...er-p-5395.html Price is USD$129.90. The programmer has some nice added features, like servo testing and battery cell voltage display. |
I've updated the pictures in the first post, since the 3GY has a nice new look.
Also, is that a metal case, like the beastX? |
I have the KDS Ebar and based on the settings and the programmer, it's definitely not a re-badged KDS unit. The gyro unit is also smaller than the Ebar. Hopefully I'll have more info soon...
| Thread Tools | |
| For Sale ALZRC 450 PRO FL Main Rotor Full Flybarless Upgrade Set (One Piece Design) | pttse | Aircraft - Electric - Helis (FS/W) | 10 | Aug 17, 2011 07:53 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Sold 3G Flybarless System Trex 450 Brand New | rundown | Aircraft - Electric - Helis (FS/W) | 0 | Apr 22, 2010 04:56 AM |
