Old Dec 11, 2012, 12:08 PM
Ken Park is online now
Find More Posts by Ken Park
Ken Park's Avatar
Ottawa Canada
Joined Feb 2004
Hi Billy thanks for the Season Greetings Card
I guess I got prefered customer status with Billy as I got this in the mail today!
Ken Park is online now Find More Posts by Ken Park
Old Dec 11, 2012, 12:17 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
LMAO That is just great!!
Originally Posted by Ken Park View Post
I guess I got preferred customer status with Billy as I got this in the mail today!
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Dec 11, 2012, 01:35 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Pre orders
HI All, Just want to give all my Viper buddy's a heads up. I will be putting in a order for more 90mm Vipers. If there is a paint scheme you want now is the time to put your order in. You can email me at sales@usarcjets.com
Thanks Billy D
Old Dec 12, 2012, 08:19 PM
miclacom is offline
Find More Posts by miclacom
miclacom's Avatar
United States, NY
Joined Sep 2012
Main gear door
Just curious if any one has used a single servo to open both main gear doors
I am currently at this stage of building and it would seem that 1 hs 85 with a wheel control arm should do the trick ...Yet from post photos i have seen 1 servo for each door. Im trying to keep weight down as well as cost. Also ALL my servos are removable that also adds weight. Starting to worry about cg issues
Any suggestions helpful
Thanks mic
miclacom is offline Find More Posts by miclacom
Old Dec 12, 2012, 08:34 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Mate of mine is doing just that Mic and I will be doing the same shortly. Just don't have any pics right now but it's do-able. Mine is going aft of the main gear doors, up against the wing spare tube and will sit on a small block of ply to stand the servo off just enough for the arm and linkage to clear the door opening. Hardest part about this setup is getting the linkage geometry the same for both doors. May require some tweaking of linkages and lots of trail and error to get it right.
Probably why a lot of guys (with limited channels) use two servos and two ASSAN gear door sequencers. That way you can set the end points on each door, but like you - I want to keep the weight down.
Sorry I couldn't be more help.
vanderbrander is offline Find More Posts by vanderbrander
Old Dec 12, 2012, 08:35 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
The main gear doors are near CG so it shouldn't be that big a deal. The Viper can carry the extra weight of a gear door servo with no problem. That being said there is no reason a single servo wouldn't work as long as you can work out the linkages.
Double E is offline Find More Posts by Double E
Old Dec 12, 2012, 10:05 PM
miclacom is offline
miclacom's Avatar
United States, NY
Joined Sep 2012
2E your absoolutly correct but just trying to keep devices servicable and removable in this space is to say the least somewhat quite tricky.CG came to mind because my whole bild has removable and not glue in devices. Im including hardware etc. It all adds up .
Old Dec 12, 2012, 11:16 PM
lashmett75 is offline
Find More Posts by lashmett75
Not a Drone pilot
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
Take a look at the main gear door servo installation phots i posted. I am using 2hs65mg servos and they are removable even with the fan installed. Very easy.
James
lashmett75 is offline Find More Posts by lashmett75
Old Dec 13, 2012, 06:40 AM
KenM is offline
Find More Posts by KenM
United States, IN, Crown Point
Joined May 2007
Thanks mic
Yes, i used one servo to do my main gear doors with some helicopter links. I tried shoving my iphone into the plane the best i could to get a photo. Where the hinge attaches to the fuse i had to sand the opening around the hinge and then removed the lip. I also rounded the inside of my offset hinge to give me more movement. Last I belved the inside of my gear door at a 45deg angle where it meets the fuse so it would open easier. If you take your time its fairly easy to do and mine turned out really good. when the doors are closed they are perfectly flat with the fuselage. Works great with the ASSAN sequencer.
KenM is offline Find More Posts by KenM
Old Dec 13, 2012, 01:27 PM
miclacom is offline
miclacom's Avatar
United States, NY
Joined Sep 2012
Thanks for the photo Ken
Nice job.Thats exactly what I had in mind and simple enough to install..
Old Dec 13, 2012, 03:31 PM
icicles is offline
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
Very nice installation. I was thinking along similar lines.
Thanks for the ideas, thanks for sharing
Chris
icicles is offline Find More Posts by icicles
Old Dec 13, 2012, 03:43 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Very Nice!! That is the same way that im doing it.. I will post pics later.
Old Dec 13, 2012, 04:45 PM
RickyBoy49 is offline
Find More Posts by RickyBoy49
RickyBoy
Newmarket, Ontario, Canada
Joined Mar 2010
I did that ages ago.....and that Assan sequencer is awesome
RickyBoy49 is offline Find More Posts by RickyBoy49
Old Dec 13, 2012, 05:02 PM
miclacom is offline
miclacom's Avatar
United States, NY
Joined Sep 2012
Assan sequencer is out of stock and has been for quit some time at hk. I found this onehttphttp://http://www.hobbylinc.com/htm/emo/emoemo1042.htm Has any one installed this. Seems reasonably priced just curios about reliablity and comparability to the assan. Im in the market and looking. Anyone??
Old Dec 13, 2012, 05:05 PM
miclacom is offline
miclacom's Avatar
United States, NY
Joined Sep 2012
Sorry link did not go through
Try thishttp://www.hobbylinc.com/htm/emo/emoemo1042.htm
Discussion HET L-39 VS Jet Teng L-39 skydve76 Electric Ducted Fan Jet Talk 48 Jan 23, 2012 03:46 AM
Build Log My new Jet-Teng Models (JTM) L-39 Albatros pajlotmato Electric Ducted Fan Jet Talk 37 Jul 14, 2011 07:37 PM
For Sale Jet teng 90mm Bae Hawk swiss rtf newly assembled $1500 jetfan20 Aircraft - Electric - Jets (FS/W) 1 Jun 05, 2011 02:00 AM
Jet Design Contest entry #2 -- Viperjet MKII berniep1 Electric Ducted Fan Jet Talk 10 Apr 18, 2008 11:30 AM
