Old Dec 04, 2012, 11:10 AM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Originally Posted by vanderbrander View Post
dont get me wrong - It's a beautiful 90mm sports jet and its exactly what I was looking for. But it's not going to win any scale competitions.
I'm choosing to keep the weight down by not adding scale details. That's all.
As I said each to his own.
Ah ok. It is a scale jet. But I see what you mean.
tulz43 is offline Find More Posts by tulz43
Old Dec 04, 2012, 05:38 PM
miclacom is online now
Find More Posts by miclacom
miclacom's Avatar
United States, NY
Joined Sep 2012
esc location for cooling
Im strugglin a little with the location of the esc for optimum cooling
Has anyone cut out the vent slits that are located in the nose of the fuse for actual cooling inlet. My thought was to dremel out the slits and have a cheater hole in the fan access hatch monting the esc just under the intake before the fan.
Then dress up the hole in the hatch cover. Any thoughts
Thanks in advance
miclacom is online now Find More Posts by miclacom
Old Dec 04, 2012, 06:04 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
I had the same dilemma. Eventually I decided to mount mine on a saddle below the fan with a cutout in the fan hatch. The cooling fins will protrude just slightly outside the fuse, providing adequate cooling for negligible drag increase. I'm working on it right now so can post some pics later tonight. I'm sure there's plenty of other ideas out there??
vanderbrander is offline Find More Posts by vanderbrander
Old Dec 04, 2012, 06:34 PM
miclacom's Avatar
United States, NY
Joined Sep 2012
vandebrander
That may be a good solution but im looking for somthing cleaner.
Im thinking that the slits up by the nose if cut out properly will crate a vacume effect pulling air from the cockpit area. You then install a small air scoop at the edf acccess hatch to complete the process.
I have been looking at photos of the (real) vj it looks to me thats what there purpose is for. Just my 2c . Heres the link
Old Dec 04, 2012, 06:43 PM
miclacom's Avatar
United States, NY
Joined Sep 2012
Sorry icant get the link to post or save any photos
Just googl viperjet youll find it
Old Dec 04, 2012, 07:21 PM
RickyBoy49 is offline
Find More Posts by RickyBoy49
RickyBoy
Newmarket, Ontario, Canada
Joined Mar 2010
I have a Stumax and I bought the Tail cone from Tam and my ESC is in the cone. Runs so cool
RickyBoy49 is offline Find More Posts by RickyBoy49
Old Dec 04, 2012, 07:23 PM
Ken Park is offline
Find More Posts by Ken Park
Ken Park's Avatar
Ottawa Canada
Joined Feb 2004
Tail Servo's hooked up
Got HS 125MG into Horizontal stab - epoxied into place on 1/8" ply plates I added
Hows it looking Ricky B
PS: Have a foamy for June in Ottawa we are going to have Noontime Foamy Olympics for S#%^& and Giggles goodtime!
Ken Park is offline Find More Posts by Ken Park
Old Dec 04, 2012, 07:50 PM
RickyBoy
Joined Mar 2010
Very nice, very nice Ken
Old Dec 04, 2012, 07:56 PM
miclacom's Avatar
United States, NY
Joined Sep 2012
FYI Stu max fans are hard to get If you want on for the holiday keep an eye on espirit and usa rc jets. These fans sell out fast.
Old Dec 04, 2012, 08:59 PM
Joined Nov 2010
Originally Posted by miclacom View Post
vandebrander
Yeap I thought about the same thing (cutting slots in the grills up front) to prevent heat buildup in the battery bay.
I'm running a 90mm Stumax with the thrust tube dia at 70mm so there is plenty of clear space around the exhaust. The high exhaust airflow will create a relative low pressure in the aft fuselage. The low pressure around the exhaust should pull air in through the slots - aft, toward the exhaust. Might not need additional scoops to keep the battery bay cool but the ESC...???
Old Dec 04, 2012, 09:13 PM
Joined Nov 2010
Some pics of my ESC mount made from 1/16 ply.
Needs to be sanded, glued and painted prior to installation.
Didn't get time to cut the fan hatch but you should get the idea.
The mount will be held to the fan with a couple of zip ties wrapped all the way around the fan, and through the cross braces on the "legs". Not too tight, but just enough to hold it in place. The hatch cover will be cut as a close fit to prevent the ESC from moving.
Once the cover is installed there will be very little protruding into the air stream.
I did something very similar on my SAPAC 70mm Viper and it worked great. Hope the results are the same here.
Old Dec 04, 2012, 10:05 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
ESC install
Ok guys, Im not a pro or claim to be one. But on the very first viper we got to fly i put the ESC in the fuse. It got to 170 degrease when it was 60 outside!! Then i put i into the inlet air flow with some hole in the ESC. Had over 250 flight on it this way and the ESC never got over 115 with temps outside @ 90+ I will post newer pick on the install soon. Thanks Billy D
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Dec 04, 2012, 11:25 PM
icicles is online now
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
Keep the photos coming guys. You are giving me some great ideas for when i do mine
Chris
icicles is online now Find More Posts by icicles
Old Dec 05, 2012, 02:22 AM
easy jets is offline
Find More Posts by easy jets
easy jets's Avatar
Germany, NRW, Gangelt
Joined Jan 2011
Cockpit
Here are a few more pics of the cockpit.
I separated the dash and mounted that on a painted piece of 3mm Balsa.
This was glued in the front of the nose.
The cockpit itself is fitted inside the canopy.
You need to widen the opening inside the fuselage a bit but the end result is OK.
Clifford
easy jets is offline Find More Posts by easy jets
Discussion HET L-39 VS Jet Teng L-39 skydve76 Electric Ducted Fan Jet Talk 48 Jan 23, 2012 03:46 AM
Build Log My new Jet-Teng Models (JTM) L-39 Albatros pajlotmato Electric Ducted Fan Jet Talk 37 Jul 14, 2011 07:37 PM
For Sale Jet teng 90mm Bae Hawk swiss rtf newly assembled $1500 jetfan20 Aircraft - Electric - Jets (FS/W) 1 Jun 05, 2011 02:00 AM
Jet Design Contest entry #2 -- Viperjet MKII berniep1 Electric Ducted Fan Jet Talk 10 Apr 18, 2008 11:30 AM
