Old Aug 22, 2011, 08:02 AM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Did not change anything just cut them the rest of the way off and have to drill out hole for the Robart hinges! Sorry I do not have a price on it Yet
Originally Posted by invertmast View Post
Billy,
Did you change the flaps ailerons over to a conventional style of hinging? I definitely want one of these. Any idea on pricing?
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Aug 22, 2011, 08:15 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Those hinglelines (other than the rudder which is correct) are bizarre.
Chris True is offline Find More Posts by Chris True
Old Aug 22, 2011, 08:40 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
You got to remember it is the first one build as a prototype! It just needs some finish work done to it.
Old Aug 22, 2011, 08:43 AM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Looks to me like someone wanted the rudder piece to be common with the elevator and the ailerons.
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Aug 22, 2011, 05:33 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Billy why did you cut through the live hinge?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Aug 22, 2011, 07:22 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
They were not live hinges. They were just NOT cut off yet.
Old Aug 22, 2011, 08:13 PM
flyboy1945 is offline
Find More Posts by flyboy1945
Were's the plane?
flyboy1945's Avatar
Warren,Ohio
Joined Feb 2005
Bill call me John!!
flyboy1945 is offline Find More Posts by flyboy1945
Old Aug 23, 2011, 11:14 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Can i make a suggestion for production ones? (i'm going to say it anyways )
If they aren't going to be live hinged, and are going to have a balsa LE cap, could they either
1. cut the surface free then install the LE cap.
or
2. Leave the LE cap to be installed by the customer.
While i understand this is a pre-production version, those LE's look horrible
invertmast is offline Find More Posts by invertmast
Old Aug 23, 2011, 11:21 AM
gjmjoe017 is offline
Find More Posts by gjmjoe017
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
I think Billy is going to regret putting up pics of a prototype!!!Based on the quality of my Jet Teng T-45 I would bet the production models will not look like these.The quality of mine is second to none!!!I do wish he would install the battery trays in these!
gjmjoe017 is offline Find More Posts by gjmjoe017
Old Aug 23, 2011, 01:06 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Ok all I need some input on were to put the elevator servos! There are to many great builders on RCG to not ask.. Here are some pics i took of the rear of the jet. I was thinking at first to put the servos into the elev. but there are 2 spars in the way of doing that? Any help will be much appreciated.. Thanks Billy D
Old Aug 23, 2011, 01:14 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I know the production version will be so so so much better then this one. Everything will be per-drilled and ready to install. Just like the L-39 and Hawk.
or
Old Aug 23, 2011, 01:19 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I would put the servo in the area I circled and run the linkage under the stab. I would also hysol in a heli-coil so I could use set screws and make the stabs removable for easy transportation
rvincent is offline Find More Posts by rvincent
Old Aug 23, 2011, 01:30 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
That's what the guys and I at the field were saying too!! The stab is drilled and taped for a screw inside the fuse..
Old Aug 23, 2011, 03:57 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Looks like a great model! Does it come with (or will it come with) 2 sizes of ducting for 90 and 100mm?
I agree with Bob, put it in that opening and run the arm down vertically. I'd still go with a removable stab, but for a model this size I don't think you need to remove it for transport on a normal basis. Plus you don't want to disconnect and reconnect every time. The rudder servo is done like this on my Skymaster sabre, being mounted in the fin.
If you think you'll run into an issue CG'ing the model then I'd put the elevator servos up farther in the fuse and run rods back with two 180deg bell-cranks to linkages outside the fuse hidden under the stab.
strictlyscale is offline Find More Posts by strictlyscale
Old Aug 24, 2011, 11:00 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Thanks for all the help guys!! This is what I did. It looked like the right place to put the servos.
Discussion HET L-39 VS Jet Teng L-39 skydve76 Electric Ducted Fan Jet Talk 48 Jan 23, 2012 03:46 AM
Build Log My new Jet-Teng Models (JTM) L-39 Albatros pajlotmato Electric Ducted Fan Jet Talk 37 Jul 14, 2011 07:37 PM
For Sale Jet teng 90mm Bae Hawk swiss rtf newly assembled $1500 jetfan20 Aircraft - Electric - Jets (FS/W) 1 Jun 05, 2011 02:00 AM
Jet Design Contest entry #2 -- Viperjet MKII berniep1 Electric Ducted Fan Jet Talk 10 Apr 18, 2008 11:30 AM
