Old Aug 18, 2011, 08:11 PM
jjac is offline
Find More Posts by jjac
I'm tired.....
jjac's Avatar
Conway,Myrtle Beach SC
Joined Jul 2009
Originally Posted by igotit View Post
check out the 3racing 1/10 scale crawler winch.they are small,light and cheap...plus can pull 9 lbs.
you could run 1 controlling the booms,or 2 seperate boom winches.
I have seen that winch before. Looks great for a scale truck.
Originally Posted by wayne d View Post
I've looked through LoyalHanna and can't seem to fine it under Taubman's. Would you have a link to the actual plan?
They weren't listed when I ordered them either. Send him an email, he still has them.
jjac is offline Find More Posts by jjac
Old Aug 18, 2011, 08:19 PM
jjac is offline
I'm tired.....
jjac's Avatar
Joined Jul 2009
Here is a picture of a similar shrimper. The Linda Jo is a 77' trawler built in 1972 by St. Augustine. The first picture is an older model. The second is a 2006 I believe.
Old Aug 19, 2011, 03:17 AM
wayne d is offline
Find More Posts by wayne d
United States, FL, Stuart
Joined Dec 2010
Sending one now, Thanks
wayne d is offline Find More Posts by wayne d
Old Aug 19, 2011, 04:30 PM
tigman is online now
Find More Posts by tigman
palmcoastfl
Joined Aug 2003
This is a very neat project, i'm all eye's
tigman is online now Find More Posts by tigman
Old Aug 20, 2011, 12:02 AM
igotit is online now
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
this is my 8 lb jeep,the 3 racing winch pulls it pretty good.
the winch can eaisly be hidden below deck.
igotit is online now Find More Posts by igotit
Old Sep 07, 2011, 03:25 AM
wayne d is offline
Joined Dec 2010
Thought I would add a picture of a boat from your plans being converted to a gulf coast shrimper.
Old Sep 07, 2011, 03:29 AM
wayne d is offline
Joined Dec 2010
Here is a couple of videos I done.
Scratch Built Shrimp Boat (4 min 13 sec)
Scratch Built shrimp boat (2 min 53 sec)
Old Sep 07, 2011, 08:53 AM
A-37 is offline
Find More Posts by A-37
A-37's Avatar
Cortland OH
Joined Dec 2007
Jimmy,
Looks like a great project and one I might start as the winter project if I can find the plans.
Wayne,
Nice work on the shrimp trawler.
Ed
A-37 is offline Find More Posts by A-37
Old Sep 07, 2011, 09:05 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Hey Jimmy,
I got your plans for the 40" lobster boat and currently building it over at RCU. The only difference is I'm converting it to a shrimp boat.
Where did you get the plans for the "Linda Jo"?
Could someone tell me how to subscribe to this forum?
If you can find a set, Midwest had a kit of their 21'' lobster boat rigged as a shrimper and the plans show the simple rig used. May not be totally accurate but it is a Boothbay type of hull as a shrimp boat.
charlie eaton is offline Find More Posts by charlie eaton
Old Sep 07, 2011, 08:04 PM
jjac is offline
I'm tired.....
jjac's Avatar
Joined Jul 2009
Wayne nice work on the boat, looks real good! Ed I called up Taubmans for the plans. They were alright but there are a few things on the 2 sheets that didn't scale out right. I just picked one and went with it.
Old Sep 07, 2011, 08:36 PM
jjac is offline
I'm tired.....
jjac's Avatar
Joined Jul 2009
Here is a little update...I got the hull all planked up and ready to go. Just needs a little body work and some glassing. The deck was installed and will be textured when it come time to paint. I have used some textured paint in the past on some other projects that will be perfect for using on the decks of boats but I have to remember where I got it at. I have started building the wheel house and crew quarters and that is going very well.
I built a cnc router over the summer and have finally got it running. I have used it to cut all of my wheel house parts like the superstructure, all of the windows and window frames, doors and door frames and etc. I am going to try to cut out the ships wheel as soon as I get the file set up. We'll see how that goes! I also sealed up the bulwark and back filled it with some resin for added strength.Here's some more pictures of my progress.
Old Sep 08, 2011, 09:43 AM
Rmay is offline
Find More Posts by Rmay
Rmay's Avatar
Louisiana
Joined Sep 2006
What material are you using for the cabin? It looks like foamcore, if so how are you sealing it? I like Gatorboard but it’s so expensive as compared to foamcore I wouldn’t mind looking at foamcore.
Years ago I made an address sign (plate insert) for the front of my house and printed it at Kinko’s on foamcore. It’s lasted through 3 hurricanes and south Louisiana weather for years and still looks great, so I know it will stand up to moisture.
Rmay is offline Find More Posts by Rmay
Old Sep 08, 2011, 11:43 AM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Great work !
jjac, this is Great work !
Nice planking, inner bulwark looks very good, not easy to do.
I also am interested in the cabin material.
You make the window frames ? they look great.
I wish I could braze like that, there would be so much more I could do ....
Tim B. is offline Find More Posts by Tim B.
Old Sep 08, 2011, 03:38 PM
A-37 is offline
A-37's Avatar
Cortland OH
Joined Dec 2007
A super job, Jimmy. Might be my next project.
Ed
Old Sep 08, 2011, 04:44 PM
jjac is offline
I'm tired.....
jjac's Avatar
Joined Jul 2009
Originally Posted by Rmay View Post
What material are you using for the cabin? It looks like foamcore, if so how are you sealing it? I like Gatorboard but itís so expensive as compared to foamcore I wouldnít mind looking at foamcore.
Years ago I made an address sign (plate insert) for the front of my house and printed it at Kinkoís on foamcore. Itís lasted through 3 hurricanes and south Louisiana weather for years and still looks great, so I know it will stand up to moisture.
The material I used is 1/4 sintra. You can get it from your local sign supplies dealer.
I did make the window frames. I used the cnc router that I built to cut them out.
Discussion Wanted Shrimp Boat Plans Tug Guy Scale Boats 272 Jun 23, 2015 12:58 AM
Sold Carolinas Shrimp Boat Working Winches tugger Boats (FS/W) 5 Jan 24, 2010 12:45 PM
For Sale Carolinas Shrimp Boat Working Winches tugger Boats (FS/W) 1 May 14, 2009 06:55 AM
Discussion Shrimp boat marlon12 Scale Boats 15 Aug 07, 2007 03:09 PM
Discussion Lindberg Shrimp Boat Conversion Micronaut Scale Boats 11 Sep 12, 2006 02:14 PM
