Old Aug 16, 2011, 07:26 AM
ryanrcflyer is offline
Find More Posts by ryanrcflyer
Joined Jun 2011
Question
Turnigy 6364-230Kv on 8s....but which ESC?!?
Hi there,
I am looking at installing the Turnigy SK 6364 230Kv motor into my
Hanger 9 P47 60 size and running it on 8s Lipo's ideally on a 3blade.
Would anyone have an idea about which ESC I should be using please?
Thanks in advance
Ryan
ryanrcflyer is offline Find More Posts by ryanrcflyer
Old Aug 16, 2011, 01:33 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
You have two options IMO, go with the Hobbywing platinum series HV controllers, I'd suggest the 100 or 120amp versions. Hobby King sells them under the K force brand. Be sure to purchase the Programming Box, it allows very easy setups without brain seizures listening for the beeps!!
The second is more $$,has the advantage of a useful warranty. It the Castle Creations line of HV ESC in approx the same sizes. If you go this route, do buy the Castle Link, computer based setup is about as simple as it gets.
I'd go with the 12S rated units here, at least 20% larger capacity than highest amps expected.
FWIW Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Aug 22, 2011, 07:21 AM
Joined Jun 2011
FWIW Doug B
Hi Doug,
Many thanks for the reply - apologies for delay coming back I was in Edinburgh for the Fringe festival!
Yes I was looking at the KForce ESC but they are still on backorder at the mo with HK.
I just read somewhere a way someone calculated his AMPs. As I was thinking about using 40c rated NanoTech Lipo's I am a little confused with what ESC I actually may need! Calculation below;
40c x 8000mah / 1000 = 320AMPs??? Is this right, or was this guy way off on his calculations??
Ryan
Old Aug 22, 2011, 09:51 AM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
Ryan
Check these out. A bit dearer than HobbyKing but in stock.
http://www.giantcod.co.uk/hobbywing-...-p-403870.html
http://www.giantcod.co.uk/hobbywing-...-p-403867.html
http://www.giantcod.co.uk/hobbywing-...-p-403901.html
I have been running the 70A version on 9S up to 65A static without any problems.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Aug 22, 2011, 11:59 AM
Joined Oct 2008
Series Battery amps and C
[QUOTE=ryanrcflyer;19111319]Hi Doug,
Thanks, Hi Ryan Battery C rating has nothing to do with the size of the ESC.
The prop size and voltage selected determines the amperage the motor uses to spin the chosen prop. The C rating on a battery shows the theoretical max amps the battery can deliver. IE: a 2000mah battery at 20C should be capable of dlivering 40amp, so yes, if there was such a thing as an 8000mah 40C, it should do 320 amps. Typically, for 8S, you would use a matched pair of 4S batteries in series, 2 4000mah bat in series is still 4000capacity, but double the voltage. Higher C rated batteries deliver a more consistant voltage,with less volt drop, and higher amp draws. A motor pulling say 50 amp from series connected batteries means 50 amps is being pulled from each battery. Confused yet, I hope this helps at little at least. Doug B
Off Site Turnigy c6364 230kv flyingcubby Aircraft - Electric - Power Systems (FS/W) 1 Apr 27, 2014 02:36 PM
Wanted Turnigy SK 63-64 230Kv Chuchuf Aircraft - Electric - Power Systems (FS/W) 1 May 03, 2011 06:09 AM
Sold Turnigy 6364-230 NEW Hunkus Aircraft - Electric - Power Systems (FS/W) 3 Apr 03, 2011 08:51 AM
Discussion Sync problem with Turnigy SK 63-64 230kv Shuffle Power Systems 1 Apr 10, 2010 07:45 AM
Sold Turnigy Aerodrive 6364-230 DMA, IN Aircraft - Electric - Power Systems (FS/W) 2 Jun 09, 2008 02:37 PM
